Old 06-02-2011, 08:11 AM   #1576
frdbronco8
frdbronco8's Avatar
Oddometer: 245
idle problem when warm
Ok The valves are next to check on my list but I was wondering if anyone knew what the reading should be to test the spark plug wire and how to test the pulsar coil? those are next on my list.
THanks
2005 Yamaha Roadstar 1700
2008 KTM 450 XC (540) ATV
2005 KTM 450 EXC
frdbronco8 is offline   Reply With Quote
Old 06-02-2011, 08:22 AM   #1577
laramie LC4
crash test dummy!
laramie LC4's Avatar
Oddometer: 2,392
i would check the plug wire by reading ohms to the coil like before. if it has the same reading with and without plug wire, then it should be good.
one of these days your gonna figure this thing out.
laramie
DON'T TRUST CUT 7! HE IS A CROOK! ASK ME HOW I KNOW.
'12 LC8 990R, '02 LC4 640, '05 WR 450f (part-out), '98 XR400R, '76 KE100, '05 525 (Step-Child)
laramie LC4 is offline   Reply With Quote
Old 06-02-2011, 08:37 AM   #1578
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,177
THanks
I'm thinking you should of started your own thread on this... Your posts are spread out over several pages and it has become quite fractured to follow along....
I see now that you have turned to electrical rather than carb problems... When you replaced the parts in the carb did you make any adjustments to the settings or just leave them stock?
640 A x 2
BC RIDING 2014
gunnerbuck is offline   Reply With Quote
Old 06-02-2011, 02:11 PM   #1579
frdbronco8
frdbronco8's Avatar
Oddometer: 245
Good point, If this doesn't do it I will start a new post with everything I have done.
I tried it stock and messed with setting in the carb and no matter what I did the problem never changed. I have a different low mileage carb in it now with the exact same issues.
2005 KTM 450 EXC
Old 06-02-2011, 02:49 PM   #1580
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,177
It seems strange that this problem is off idle... Usually an ignition problem will see the engine run better near idle and crap out with revs...
Here is something to try in the carb that is simple: Move your jet needle down 2 clip positions and see if there is any difference { move clip away from pointy end}... An overly rich needle setting can cause a stumble like you describe...
640 A x 2
BC RIDING 2014
Old 06-02-2011, 03:40 PM   #1581
meat popsicle OP
Ignostic
meat popsicle's Avatar
Oddometer: 14,224
David,
do you think it worthwhile to check valve lash? WHY I ask, seems close to this fella's issue.
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 06-02-2011, 04:16 PM   #1582
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,177
Originally Posted by meat popsicle View Post
David,
For sure, always try to check off the list the easy less expensive potential solutions before you start forking out money to replace components you may think faulty...
640 A x 2
BC RIDING 2014
Old 06-03-2011, 02:52 AM   #1583
Sumi
Sumi's Avatar
Oddometer: 1,796
Originally Posted by bigboyxl View Post
I had the same problem 2 times:
1. There was a problem with the ignition key connection cable (specifically with contact near the key), I noticed where the problem was when tried to turn the steering wheel to the maximum
2. There was a basic bad contact on the battery
Dunno maybe it will help you.
Well I inspected the battery connection and the ignition switch, and they look OK.
I'll try to describe my problem better:
I've pulled the tripmaster and the rev meter from the bike, so now if I turn the ignition key, no consumers are on the bike by default.
Multimeter - Continuity tester is on the Battery negative and positive pole. If I turn on the key, nothing happens. But if I switch on any consomer, let's say the horn for expample: it starts beeping (the multimeter). I don't know if this is normal or not.
Voltage in the battery is 13V if it's not connected to the bike. As soon as I connect it, it drops to about 0.5V. If I turn on any consumer (horn for eg.) voltage immediately drops to 0.0V.
I've checked the cables and can't find a pinch on them.. What should I do now? Please help:)
Thanks,
Sumi
Old 06-03-2011, 05:07 AM   #1584
Sumi
Sumi's Avatar
Oddometer: 1,796
Oh boy... Found it:)
Terminal was sometimes making the contact, sometimes not.. It had a movement in it.. Time for a new battery
Thanks for the help!
Sumi
Old 06-03-2011, 06:42 AM   #1585
meat popsicle OP
Ignostic
Oddometer: 14,224
Sumi
What brand of battery?
Old 06-03-2011, 08:25 AM   #1586
makazica
makazica's Avatar
Oddometer: 746
Sumi
Not necessarily, a friend had this happen and he "hard" soldered the terminal back onto the battery. Still works. If the battery is good try that and save yourself some money.....
M.
makazica is offline   Reply With Quote
Old 06-03-2011, 09:44 AM   #1587
Sumi
Sumi's Avatar
Oddometer: 1,796
M.
I don't have the tools to solder it back, so I've bought a new one.
Old 06-18-2011, 05:42 AM   #1588
DobroDog
Oddometer: 47
Ohh thanks for the info!
But still, I have a question:
I've heard about the issue that for some models of Adv it restraints the movement of the kickstarter. What can you say about it? How does the kickstarter work with this side stand?
On my 99 the side stand does block the swing of the Kick Start. I have to stand to the left side of the bike and use my right leg to kick it. Felt a bit odd a first but I love the side stand. Check the bolts frequently at first. Even with a medium thread lock mine vibrated loose.
Tim
DobroDog is offline   Reply With Quote
Old 06-18-2011, 06:33 AM   #1589
Sumi
Sumi's Avatar
Oddometer: 1,796
It was a noname? (MotoBatt) battery.. not the yellow one, but something like this:
Old 06-20-2011, 06:27 AM   #1590
meat popsicle OP
Ignostic
Oddometer: 14,224
It was a noname? (MotoBatt) battery...
I guess we won't have to worry about buying that one.
Times are GMT -7.   It's 09:09 PM.
