Old 09-23-2011, 04:14 PM   #1861
Baja Dad
Baja Dad's Avatar
Oddometer: 1,951
I found a Right side LC 4 rear Rallye tank.
I still need the Left side tank
Hear are the two KTM part numbers
#5851219600004 Right side
#585209500004 Left side
Baja Dad is offline   Reply With Quote
Old 09-24-2011, 05:59 PM   #1862
Sumi
Sumi's Avatar
Oddometer: 1,780
Hi, my 640adv has developed some strange sound comming from the engine.. It only happens when it's warmed up well (after 15-20 min riding), and for example in second gear, cruising at a steady speed, rpm at about 4-5000, and then I'm not closing off the throttle fully, just backing it up a little and holdig it there (for example, for slowing down slowly, avoiding hard engine braking). Then I get this sound (during the steady, but small throttle opening) .. It sounds like the whole bashplate would be rattling, it's realy noisy like putting marbles in a metal pan and shaking it.. However my bashplate is rock solid mounted.
Any ideas?
Thanks in advance!
Sumi is online now   Reply With Quote
Old 09-24-2011, 08:48 PM   #1863
Zecatfish
XTique Rider
Zecatfish's Avatar
Oddometer: 7,927
Any ideas?
Thanks in advance!
Pull the clutch cover and clutch assembly and check the bearing back there if you have a pre-03 model.
you might also see some rub marks on the inside of the cover and the clutch hub before you ever get the clutch assembly off.
Google Earth GPS Howto (still a work in progress) use USGS TOPO Maps to layout trails.
http://home.windstream.net/catfish/GPS
The Early Bird gets the worm, but the second mouse gets the cheese.
https://sites.google.com/site/ozarkadventuretours/
Zecatfish is offline   Reply With Quote
Old 09-24-2011, 09:53 PM   #1864
rz35027
rz35027's Avatar
Oddometer: 228
Do you have any rocks between bashplate and motor?
rz35027 is offline   Reply With Quote
Old 09-25-2011, 02:03 AM   #1865
Sumi
Sumi's Avatar
Oddometer: 1,780
Thank you for you answer!
It's a 2005 model. Do I need to drain the oil for taking off the cover, or is it enough to lay it on its side?
Old 09-25-2011, 02:04 AM   #1866
Sumi
Sumi's Avatar
Oddometer: 1,780
No:( It's clean, and the rubbers are good as well.
Old 09-25-2011, 07:25 AM   #1867
Low594
Adventuring Creep
Low594's Avatar
Oddometer: 1,130
Originally Posted by Baja Dad View Post
I am looking for a set of LC4 Rallye rear tanks?
Anyone ??????????????
I think you will have to resort to calling dealer directly, watching the flea market here, ebay and craiglist wide search programs(like searchtempest). My buddy got his from touratech, 5 yrs ago, long after they were off their catalog, but they had a pair collecting dust in a corner.
Low594 is offline   Reply With Quote
Old 09-25-2011, 07:46 AM   #1868
Zecatfish
XTique Rider
Zecatfish's Avatar
Oddometer: 7,927
05 shouldn't have that problem they changed the bearing used to the better design in 03.
But if you want to pull it apart you can lay it on its side and pull the cover.
Old 09-25-2011, 08:14 AM   #1869
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,111
Any ideas?
Thanks in advance!
Check over the whole bike for loose fasteners/bolts... Often when something comes loose on the 640 you'll get a rattle up front at certain revs... I've had this happen on several occasions: a couple times when my pannier frames had developed cracks, another when my barkbusters {handguards} had come loose...
640 A x 2
BC RIDING 2014
gunnerbuck is offline   Reply With Quote
Old 09-26-2011, 12:54 AM   #1870
bmwktmbill
Traveler
Oddometer: 5,048
My engine was noisey so I pulled the skid plate, I was down on power too so I washed the filter in petrol and reoiled with spare engine oil.
After 600 miles of dirt in Idaho.
bill
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill is offline   Reply With Quote
Old 09-30-2011, 03:27 PM   #1871
cjm1219
cjm1219's Avatar
Oddometer: 107
I am looking of a Decal set for a 2000 640 18L in orange. Can anyone tell me if part #953156 on this link is right. http://www.bikebandit.com/2000-ktm-6...5267#sch462471
It seems right, but the picture doesn't show much.
Also, if anyone has a better source that would be good to. I probably shouldn't spend money on making the bike look good since it will get all scratched again, but I took off the old faded/scratched decals and replaced the faded/scratched/oxidized/turning to powder plastics and now the blank tank is bothering me.
I picked up plastics from an inmate who is parting his bike out
http://advrider.com/forums/showthread.php?t=710212
Before:
2000 KTM 640 LC4e
1998 Triumph T509 Speed Triple
cjm1219 is offline   Reply With Quote
Old 09-30-2011, 03:28 PM   #1872
cjm1219
cjm1219's Avatar
Oddometer: 107
After:
Not sure why the insert image thing isn't working for me.
Seat is still faded...oh well
2000 KTM 640 LC4e
Old 09-30-2011, 05:47 PM   #1873
WVhillbilly
WVhillbilly's Avatar
Oddometer: 10,156
What didja do with the faded plastics?
I have a use for them
WVhillbilly is offline   Reply With Quote
Old 09-30-2011, 07:35 PM   #1874
DingDangKid
El Lechero
DingDangKid's Avatar
Oddometer: 2,315
Originally Posted by cjm1219 View Post
After:
Attachment 291791
Good to see they are being put to good use!
I think the decal set on the number plates came from ridepg
2006 TW200 85mpg
1981 Honda CM400T
ISO: 198X Honda TA
DingDangKid is offline   Reply With Quote
Old 09-30-2011, 08:23 PM   #1875
cjm1219
cjm1219's Avatar
Oddometer: 107
If you can use them you can have them. They are pretty trashed, but not broken or anything. Just a bit ugly.
PM me your address. You can paypal me to cover shipping, should be about 15 depending where.
2000 KTM 640 LC4e
cjm1219 screwed with this post 09-30-2011 at 08:34 PM Reason: .
Times are GMT -7.   It's 05:38 AM.
