Old 10-07-2011, 02:04 PM   #1891
Lortdadu
Joe Cool
Lortdadu's Avatar
Oddometer: 217
Originally Posted by WVhillbilly View Post
$2100
Hope mine stays together.
When I ride with folks that have not heard an LC4 run they always ask what is wrong with it
They can be a bit vocal even when they are running fine.
Yeah, the first time I showed my LC4 to my friends, they asked if the engine is supposed to be like that or will it die any minute.
If anyone is going to disassemble their tank cap anytime soon, could you take photo's of the assembly? When I got the tank, I had to break the lock to make a key for it, and I forgot how the vents are assembled into the cap... So now when I drive it, like every 2-4km it runs of out of fuel because it can't get the air back into the tank (that's why I have a second key on the tank now and open it every now and then lol).
Or does anyone know which way the valves inside the cap are supposed to go? It's getting annoying. Driving longer distances is impossible with that. I've taken it apart countless time and tried to clean all the air vents, but for some reason it doesn't want to cooperate.
Lortdadu is offline   Reply With Quote
Old 10-07-2011, 02:26 PM   #1892
Sumi
Sumi's Avatar
Oddometer: 1,796
I don't need my friends for that:) I'm keeping asking this exactly same question from myself every time I ride it
Old 10-07-2011, 06:39 PM   #1893
WVhillbilly
WVhillbilly's Avatar
Oddometer: 10,165
Check the lines under the seat that go back the the carbon canister, if you still have it.
I pinched one of mine with the seat once and it did the same thing.
WVhillbilly is offline   Reply With Quote
Old 10-07-2011, 07:42 PM   #1894
mxchamp
Registered Lurker
mxchamp's Avatar
Location: The corn state,11 curves in 318 miles (Iafalls IA)
Oddometer: 1,545
Bluhduh LC4 Problems
So was riding back home today and the bike was sounding fine. Stopped to check my messages on my phone and started her up again to keep going and wham I thought my exhaust fell off.
Stopped again and my exhaust was still there so I headed home (10 more miles) to check it there.
Got it home and found the problem:
#34 and #35 Between the exhaust outlets.
Anybody have a spare one of those? Can I still ride the bike? It's only very very loud!
And lastly how do you install that back in there??? I hope I don't have to remove the motor.
TIA
Ride safe!!!!
2014 KTM 690 Enduro
Encouraging Serious Horseplay!
mxchamp is offline   Reply With Quote
Old 10-08-2011, 01:17 AM   #1895
Lortdadu
Joe Cool
Lortdadu's Avatar
Oddometer: 217
TIA
You're going to have to remove the header's, and then the exhaust flanges. Put the little cap there, and put everything back on, not a big process.
Happened to me as well, it seems as if the pressure "vibrates" or moves that little cap there if it's not a tight fit and it get's eaten away a bit by bit...
And that's also where a rattling noise can come if it vibrates between the flanges.
Old 10-09-2011, 02:03 PM   #1896
clintnz
Trans-Global Chook Chaser
clintnz's Avatar
Oddometer: 3,426
After my rebuild I put that cap back in with a dab of exhaust cement which seems to have held it in place with no rattles.
Cheers
Clint
'03 KTM 640 LC4 Enduro
The wilderness, the desert - why are they not crowded
.................................................. .....with pilgrims?
clintnz is offline   Reply With Quote
Old 10-10-2011, 02:32 AM   #1897
Aivasovsky
Aivasovsky's Avatar
Oddometer: 155
Cold vs. Hot engine valve lash
I have checked and adjusted my valves. Thanks for the guide!
They were a bit tight.
Then i remembered that i ran the engine for a minute.
So it was a bit warm.
Does it make any problem?
How the valve lash change when the engine warm? (get looser or tighter)
How much it changes? (just curious)
2003 KTM 640 LC4e 18000km (High Flow top)
1993 Yamaha XT350 40000km
Rebuilding XT350 project pics:
http://s263.photobucket.com/albums/i...350/?start=all
Aivasovsky is offline   Reply With Quote
Old 10-10-2011, 02:45 AM   #1898
Sumi
Sumi's Avatar
Oddometer: 1,796
I'm also planning a valve check, but I have a question:
How do you reseal the valve covers? Just reuse the old gasket? or put on a new one?
Thanks.
Old 10-10-2011, 04:13 AM   #1899
Aivasovsky
Aivasovsky's Avatar
Oddometer: 155
Thanks.
I opened them several times, cleaned the surfaces and used old gaskets without any problems.
Don't worry about it.
If you happen to damage the gasket you may use RTV gasket silicone or something similar.
You can cut a new one easily from a gasket sheet like here as well
Best wishes!
Kagan
Old 10-10-2011, 07:05 AM   #1900
Sumi
Sumi's Avatar
Oddometer: 1,796
Best wishes!
Kagan
Thank you
Old 10-10-2011, 07:28 AM   #1901
dirty_sanchez
Dirty_Sanchez
dirty_sanchez's Avatar
Oddometer: 2,915
Thank you
Sumi- I'll post up a link to the Loctite thread, but be warned, If you choose the wrong type of RTV the valve cover will leak. Additionally one of the by-products the acetoxy gas features is it's corrosivity to electrical components and ferrous metals.
RTV's which smell like vinegar do not withstand exposure to fuels, oils, ethylene glycols, etc. These are called acetoxy-cure or acetic acid cure RTV's. An example of this is most all types of cheap RTV. Red "High-Temp" RTV's such as Dow Corning 736 is also a corrosive RTV.
All RTV's are not created equal.
Don't use any vinegar-smelling RTV to seal up that valve inspection cover.
The debate has gone on for years as to what to use, but here's what I've done and my inspection covers don't leak a drop.
Remove each cover and make note of the raised metal bead in the center of the mating surface.
Sand the tiny ridge off by placing a sheet of fine grit sand paper lubricated by WD-40 or the like on a flat surface and work the inspection covers around on the sand paper until the ridge had been removed.
Clean both covers, place a thin bead of any of the Loctite Gasket Eliminators on the freshly lapped inspection covers and reinstal them.
You'll never have another leak.
If you think about it, by sanding off the ridge and NOT using archane cut gaskets we're dramatically increasing the amount of mating surface for the application. And off of the KTM assembly floor, the mating surface is pencil thin. The cut gasket takes a compression set and relaxes and a leak rears it's ugly head.
Here's a thread to read over if you like:
http://advrider.com/forums/showthread.php?t=265016
Dirty
No, really, the mustache means I love you.
dirty_sanchez is online now   Reply With Quote
Old 10-10-2011, 07:33 AM   #1902
Sumi
Sumi's Avatar
Oddometer: 1,796
Dirty
Thanks, If everything else fails (old gasket, new gasket), I'll give this is a shot!
Old 10-10-2011, 08:04 PM   #1903
rz35027
rz35027's Avatar
Oddometer: 234
Dirty
Nice...
rz35027 is offline   Reply With Quote
Old 10-10-2011, 08:57 PM   #1904
dirty_sanchez
Dirty_Sanchez
Oddometer: 2,915
Originally Posted by rz35027 View Post
Nice...
Thanks, this is what I do for a living.
Such is the life of a Loctite guy.
Dirty
Old 10-11-2011, 11:12 AM   #1905
bmwktmbill
Traveler
Oddometer: 5,107
Dirty,
Last I sealed the top of the engine I used Red hi-temp RTV.
It worked OK, leaked a little.
What are you recommending for that these days?
Also on the road it might be necessary to reuse a base or head gasket if the engine has to come apart and fresh spares aren't available.
Can you recommend anything for reuseing these and if so does the torque spec stay the same?
Should the head be retorqued?
Should the engine top?
bill
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill is offline   Reply With Quote
Times are GMT -7.   It's 09:21 PM.
