Old 10-14-2011, 09:16 AM   #1921
skibum69
slave to gravity
skibum69's Avatar
Oddometer: 5,502
Originally Posted by juames View Post
What's wrong with this picture?
Picked up a 2002 640 Adventure about a month ago and I'm loving it!
Needs a bit of jetting, but other than that its in great shape! Shouldn't there be a snorkel on top of the airbox? How would this affect the way the bike runs? It idles a bit rough, and I get some surging at low rpms between 0-1/4 throttle.
you definitely wouldn't have wanted to try running that on the water crossing that sank so many on the Roaming Rally
Beerthief
skibumsoirée2009 skibumsoiré2010
Riff Raff 2015, 2012, 2011, 2010, 2009
RIP ITsteve, ride in peace my friend
save $5 on a new smugmug account, use this coupon7frrnSRiTt9Fk
skibum69 is offline   Reply With Quote
Old 10-14-2011, 10:24 AM   #1922
juames
Have Fun, Don't Die!
juames's Avatar
Oddometer: 2,469
You got that right! Guess I'll be looking for a replacement airbox.
2005 KTM 950 Adventure
Roaming Rally 2011RR12 RR13 RR14 RR15
"I don't hate people...I just feel better when they are not around." - Henry Chinaski
juames is offline   Reply With Quote
Old 10-14-2011, 10:29 AM   #1923
skibum69
slave to gravity
skibum69's Avatar
Oddometer: 5,502
I like knowing mine is well protected, at least as well as you can protect from my poor decisions and riding ability
Beerthief
Old 10-14-2011, 10:42 AM   #1924
juames
juames's Avatar
Oddometer: 2,469
Same here...i drowned a bike once, and once was enough! Any ideas for a replacement source?
Old 10-14-2011, 11:14 AM   #1925
skibum69
slave to gravity
skibum69's Avatar
Oddometer: 5,502
put up a post here and KTM talk. That reminds me to check on a fender, maybe the same dude has one? I'll ask him
Beerthief
Old 10-14-2011, 05:37 PM   #1926
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,221
I have a spare airbox kicking around if you can't find one elsewhere...
gunnerbuck is offline   Reply With Quote
Old 10-14-2011, 10:38 PM   #1927
bmwktmbill
Traveler
Oddometer: 5,147
Juames,
Don't panic, just tape the top pf the box half shut or rivit a sheet metal half top on it.
The machine will run fine like that with stock jets but raise the needle a notch.
If the water is that deep I would stay out of it!!!
As for the filter you can go a couple a thousand miles between cleanings if need be, the filter cleans up with gas from the tank, wet it and wring it 3, 4 times. You can re oil with motor oil and carry on if need be.
Anyway buy some premium fuel, try the stock jets, raised needle and ride it before you get radical. You have the 'low flow' head like my machine(2002 640a).
I have a KTM Comp pipe and a half open air box and stock jets.
45mpg, plenty of power.
Good running at any altitude.
bill
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill is offline   Reply With Quote
Old 10-15-2011, 05:14 AM   #1928
juames
juames's Avatar
Oddometer: 2,469
Thanks for all the advice guys! I'm going to take the carb apart and clean it one of these days...that way I'll at least know what jets are in there.
Old 10-15-2011, 09:29 AM   #1929
Colemanfu
King of all manfu
Colemanfu's Avatar
Oddometer: 3,599
My 640e is a real swimmer and I don't have much more of airbox than pictured above. +1 on the tape job before you ride in the wet.
If you keep moving and use a little bow wake you can ride in about 3.5 foot - about seat high. If ya keep in the seat and not stand up it will help keep that air box dry as well.
Anything higher and your askin for it.
Guns keep society safe.
Colemanfu is online now   Reply With Quote
Old 10-17-2011, 09:34 AM   #1930
ScorpionExoRider
Oddometer: 19
Lights fuse keeps blowing
All my lights quit working a while back and a highly qualified garage mechanic replaced a fuse, I believe somewhere behind the headlight assembly. I did my first ride over the weekend and the lights blew out again. Is there possibly some other electrical component (that little square box with fins in the airbox) that is causing the problem? Sorry if this post is in the wrong place. I'm not a regular visitor. -Scott
ScorpionExoRider is offline   Reply With Quote
Old 10-17-2011, 10:39 AM   #1931
Lortdadu
Joe Cool
Lortdadu's Avatar
Oddometer: 224
You could have some wires that are worn out and rub against each other, and thus creating a short circuit in your electrics that blow the lights fuse. You might want to take a look at the wiring under the mask to see if you find any wires that are open.
Lortdadu is offline   Reply With Quote
Old 10-17-2011, 01:14 PM   #1932
mxchamp
Registered Lurker
mxchamp's Avatar
Location: The corn state,11 curves in 318 miles (Iafalls IA)
Oddometer: 1,567
Just check your fuses under the dash. Leave the fin box (cdi unit) under your seat alone.
Make sure your fuses are sealed properly and use LOTS of dielectric grease on them.
Or this is what will happen!!
Water ruins everything!!
Ride safe!!!!
2014 KTM 690 Enduro
Encouraging Serious Horseplay!
mxchamp is offline   Reply With Quote
Old 10-17-2011, 05:08 PM   #1933
rz35027
rz35027's Avatar
Oddometer: 236
Check out the wires first... then maybe the voltage regulator
rz35027 is offline   Reply With Quote
Old 10-17-2011, 09:18 PM   #1934
bmwktmbill
Traveler
Oddometer: 5,147
Scorpio,
You don't say which machine.
Check your ground for the lights first.
bill
Bill Shockley
Old 10-21-2011, 06:26 AM   #1935
Fener6
The Container Man
Fener6's Avatar
Oddometer: 284
TDC sight glass vibrating
The TDC sight glass on the right hand side of the engine has come loose and is vibrating in and out.
Am I suppose to use red rtv silicone? And how long should I let it cure?
Fener6 is offline   Reply With Quote
Times are GMT -7.   It's 06:26 AM.
