Old 11-05-2011, 07:17 AM   #1951
Lortdadu
Joe Cool
Lortdadu's Avatar
Oddometer: 226
What's the original size of the clutch friction plates?
Lortdadu is offline   Reply With Quote
Old 11-06-2011, 12:08 PM   #1952
clintnz
Trans-Global Chook Chaser
clintnz's Avatar
Oddometer: 3,500
2.7mm for the 640 IIRC. Mine were still new spec at 95K km & a good bit of abuse, to trash an LC4 clutch at less than 10K...
Cheers
Clint
'03 KTM 640 LC4 Enduro
The wilderness, the desert - why are they not crowded
.................................................. .....with pilgrims?
clintnz is offline   Reply With Quote
Old 11-06-2011, 01:12 PM   #1953
Lortdadu
Joe Cool
Lortdadu's Avatar
Oddometer: 226
Cheers
Clint
Alright, thanks.
Yeah, I was horrified about this as well, but I came into the conclusion that the clutch plates must've been changed from another bike, as that one was used for salvage parts. So it might be that the clutch is from a bike that has seen more mileage.
But anyways, better swap them for new ones to pull the front wheel off the ground.
Old 11-07-2011, 01:53 AM   #1954
Alik
viertaKTMotor *****
Oddometer: 261
Hmm… are You sure of the mileage? It is easier to swap a odometer than the friction plates ;)
Alik is offline   Reply With Quote
Old 11-12-2011, 07:36 AM   #1955
Lortdadu
Joe Cool
Lortdadu's Avatar
Oddometer: 226
Pretty sure, the odometer was on the bike itself. While the cylinder head was swapped to a bent one so I had to take it for machining to get the surface straight again, it also had a busted e-starter. Therefore I wouldn't be surprised if the clutch was changed from another bike. But I'll never know.
Edit. Now that I have my clutch open, do you think a 400cc LC4 requires the main bearing change?
Old 11-12-2011, 06:46 PM   #1956
Low594
Adventuring Creep
Low594's Avatar
Oddometer: 1,157
good question! I dont know. But what i want to know is, where are the pics??
Low594 is offline   Reply With Quote
Old 11-12-2011, 10:10 PM   #1957
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,255
Take the clutch basket off an it is pretty easy to tell, If you see a roller bearing in the case holding the main shaft then you already have the upgraded bearing... If you see a ball bearing, then you have the old style bearing which many owners have changed out ... With the lower power of the 400 the ball bearing VS roller may be less of an issue...
gunnerbuck is offline   Reply With Quote
Old 11-13-2011, 02:51 AM   #1958
Lortdadu
Joe Cool
Lortdadu's Avatar
Oddometer: 226
Ha! Lucky I didn't order the new clutch set yet! I started to question my own measurements as well thanks to your posts, and had done a measurement error! The clutch friction plates were between 2.64-2.68cm, I guess I must have measured it a bit wrong. But anyways, probably would've bought a new set if I wouldn't have remeasured it.... Gotta be more careful when measuring.
Do you have any other idea then what could be causing the clutch to jerk? When I'm slipping the clutch to accelerate from stop, the bike starts to twitch? or kind of jump forward and then take revs again. Could a bad oil cause this or some scrap in the oil? Because my filters had quite a bit of old gasket material in it.
I'll post a pic later of the main bearing. How expensive is the new main bearing?
Old 11-13-2011, 05:46 AM   #1959
dirty_sanchez
Dirty_Sanchez
dirty_sanchez's Avatar
Oddometer: 2,972
Lort- I vote for less than stellar oil along with suspect floating contaminates.
My YZ450 with a Rekluse auto-clutch behaved in a similar way after it had set unused for about 9 months. It took a few oil changes and a few back to back weekend rides to get it back where it behaved normal again.
Dirty
No, really, the mustache means I love you.
dirty_sanchez is offline   Reply With Quote
Old 11-13-2011, 07:05 AM   #1960
mxchamp
Registered Lurker
mxchamp's Avatar
Location: The corn state,11 curves in 318 miles (Iafalls IA)
Oddometer: 1,610
Cool2
Take pic and let us know.
As for the bearing and puller I might have both.
The puller for sure but the bearing I will have to check in my spare parts after my LC4 rebuild.
I too just replaced my main bearing, then the motor went up in smoke. The new main bearing came in the kit with all the other new stuff.
Ride safe!!!!
2014 KTM 690 Enduro
Encouraging Serious Horseplay!
mxchamp is offline   Reply With Quote
Old 11-14-2011, 10:13 AM   #1961
BRYANDENNY71
BRYANDENNY71's Avatar
Oddometer: 116
Is there a Remote Tripmaster Switch for my '99 640 Adventure?
The one I found only shows it to fit '02+ 640 models.
It has this model Tripmaster Speedo. (Not my bike)
BRYANDENNY71 is offline   Reply With Quote
Old 11-15-2011, 07:27 AM   #1962
DesignerRider
Adventures Since 1984
DesignerRider's Avatar
Oddometer: 100
flywheel puller
Anybody around Orange Country or San Diego have a flywheel puller I can utilize? I have an exploded flywheel to tackle.
97' KTM 620 EGS-E Rally Adventure
97' KTM 620 RXC-E (the "e" part doesn't work)
88' Honda XR600
70' Yamaha DT175 Enduro
DesignerRider is offline   Reply With Quote
Old 11-15-2011, 08:29 AM   #1963
mxchamp
Registered Lurker
mxchamp's Avatar
Oddometer: 1,610
I have one but live in Iowa.
If you can't find one I will let you borrow mine.
Remember reverse threads!
Ride safe!!!!
2014 KTM 690 Enduro
Old 11-15-2011, 11:28 AM   #1964
TaxMan
TaxMan's Avatar
Oddometer: 115
i have a 2003 640 ADV, after digging around in the 640 forums I was able to sort out what i needed. I got this on ebay for around $35:
MOTION PRO FLYWHEEL PULLER M33x1.5 RH INT YAMAHA (140580540941)
Worked like a charm. sucked to have to buy it, but the sprag clutch doesn't seem to reliable and i expect to use the puller every now again over the years. if you were a little farther north, you'd be welcome to borrow mine!
2002 Triumph Bonneville
2003 KTM 640 Adventure
TaxMan is offline   Reply With Quote
Old 11-16-2011, 04:33 AM   #1965
laramie LC4
crash test dummy!
laramie LC4's Avatar
Oddometer: 2,411
finally got a sneak peak at some parts of my new engine rebuild.
ported and polished head...
and my new/old - 43mm Gen 1 FCR....
hopefully one of these days i'll have the rest of the engine to boot....
laramie
DON'T TRUST CUT 7! HE IS A CROOK! ASK ME HOW I KNOW.
'12 LC8 990R, '02 LC4 640, '05 WR 450f (part-out), '98 XR400R, '76 KE100, '05 525 (Step-Child)
laramie LC4 is online now   Reply With Quote
Times are GMT -7.   It's 06:21 PM.
