Old 08-18-2012, 09:10 PM   #3016
WVhillbilly
WVhillbilly's Avatar
Oddometer: 10,165
Nope, the heavy stocker.
There were many changes I had planned for the bike, but I have gotten caught up riding, and everything works so well I just leave it alone.
And I have at times (yesterday for one) taken it some stupid places.
WVhillbilly is online now   Reply With Quote
Old 08-19-2012, 08:39 AM   #3017
fastdadio
Still gettin faster
fastdadio's Avatar
Oddometer: 2,105
I tried to leave mine alone. It ran like chit when I bought it. OP had the carb messed up. Typical complaints you read in the LC4 sticky. I pulled the carb and gave it a good sonic soaking. While ordering parts, the guy at JD Jetting told me that the BST40 needs to be rebuilt about every 5-6 thousand miles. He hit it right on the head. At 5500mi. the slide, slide guide and mj needle were groved pretty bad. Never seen a carb with a plastic slide before. Even with new parts, it's still a dog. I can't be a slave to this thing and throw 70-80$ at it every 5k mi. Weather or not I replace the exhaust remains to be seen, but the carb has got to go.
fastdadio is offline   Reply With Quote
Old 08-19-2012, 11:05 AM   #3018
Superpacman13
Superpacman13's Avatar
Oddometer: 252
Interesting issue today in the garage. I was starting to do a valve adjustment by finding TDC, but at TDC the valves are still very tight. The only way I could get past this issue was to be a couple degrees off of TDC in both directions. Is this normal or WTF is going on, never seen it before. Thanks.
KTM's:14' 150XC 08' 450SX-F 06' 560SMR,'77 RD 400, 73' G3SS-C
Superpacman13 is offline   Reply With Quote
Old 08-19-2012, 11:15 AM   #3019
enduro0125
Sticks and Stones™..
enduro0125's Avatar
Oddometer: 13,878
I'm no expert but I think it's normal.
Mine did the same thing.
AMA 487807A
enduro0125 is offline   Reply With Quote
Old 08-19-2012, 11:26 AM   #3020
slackmeyer
Don't mean sheeit. .
slackmeyer's Avatar
Oddometer: 3,075
Sounds to me like you're at top dead center on the exhaust stroke, not the compression stroke. Otherwise it's WTF. Rotate the engine 360 degrees (as indicated by the timing mark on the flywheel) and check again.
Zak
ktm
old bmw
others
slackmeyer is offline   Reply With Quote
Old 08-19-2012, 02:03 PM   #3021
dirty_sanchez
Dirty_Sanchez
dirty_sanchez's Avatar
Oddometer: 2,915
With the bike in top gear and the rear wheel off the ground remove the spark plug and place a drinking straw in the hole to help you confirm TDC.
The easier way is to take advantage of the sight glass on the stator side of the engine. Rotate the rear wheel-still in top gear until you see a plainly visible notch in the flywheel as you shine a bright flashlight into the site glass.
Dirty
No, really, the mustache means I love you.
dirty_sanchez is online now   Reply With Quote
Old 08-19-2012, 05:25 PM   #3022
Superpacman13
Oddometer: 252
It was definitely TDC with spark plug out etc. I had to move it slightly off of the notch to get the valves to go slack. So WTF. Damn
Old 08-20-2012, 01:48 AM   #3023
warewolf
Tyre critic
warewolf's Avatar
Oddometer: 2,564
That's pretty extreme. Yep, the BST is notorious for needle/jet/slide/slide-guide wear, but if all those parts are new it should stay good for a lot longer than 5-6 thousand miles.
Mine has had only the needle jet replaced at 40,000km (should have been 30) and now has 50,000km and runs sweet as. I will probably replace all the aforementioned parts at 60,000km. This seems fairly typical; a far cry from replacement every 8-10,000km as you suggest.
My slide and guide appeared "scuffed" but not "grooved"; that is, nothing you can catch a fingernail on. If you are getting that kind of wear, then perhaps start looking for dust ingress.
Cheers,
Colin
KTM LC4 640 Question? Check here first --> KTM LC4 (640) Index Thread
The Stable
warewolf is offline   Reply With Quote
Old 08-20-2012, 01:40 PM   #3024
slackmeyer
slackmeyer's Avatar
Oddometer: 3,075
My bike ran great at 26,000 miles, but the parts showed wear, so I rebuilt the carb with new slide/guide/emulsion tube/needle. Those parts may have been replaced before I bought the bike, but they had been in there for at least 12,000 miles.
My bike isn't a dog, either, and it gets around 50 mpg. . . running a significantly larger main jet than most on here, apparently (now I can't remember what it is, I think it's a 162.5). Works for me, so I'm not changing it.
Zak
ktm
old bmw
others
Old 08-20-2012, 01:56 PM   #3025
fastdadio
Still gettin faster
fastdadio's Avatar
Oddometer: 2,105
Dunno guys. The only thing on the list that I didn't change was the main jet and emulsion tube, and I couldn't see anything wrong with them. As far as the grooving goes, like warewolf said, "dust ingress" Mine wasn't just scuffed, it was chowed out. As covered in the sticky, there is a filter on the port that equalizes the top of the diaphram. Thats where the dirt gets in. Can't plug it, so what to do then? You guys that report high miles with little wear, how much dust do you ride in? And how often do you clean your air filters? Just curious, but I think I might be on to something.
Old 08-20-2012, 02:07 PM   #3026
slackmeyer
slackmeyer's Avatar
Oddometer: 3,075
Not that much dust, you may be right, I often ride alone, and 50/50 street/dirt.
Derek, the Motolab guy who is a BST guru, reports that carbs with the slide holes drilled out larger will wear much faster- not sure if your carb has that. Asking these questions in the big BST-40 thread may get some more views/opinions.
Zak
ktm
old bmw
others
Old 08-25-2012, 12:12 PM   #3027
MNCherryinCA
KTM Noob
Oddometer: 577
totalled my SXC - some LC4 parts on flea market
FYI all. I have some 04 625 SXC parts over on Flea Market...
I want to thank all the LC4 people who have helped me with my SXC over the past couple of years. You guys in this thread have been invaluable and so helpful. Unfortunately, my SXC was totalled and I am not riding anymore. maybe we'll cross paths some day in the future. It's time for me to learn how to surf...
MNCherryinCA is offline   Reply With Quote
Old 08-25-2012, 12:16 PM   #3028
WVhillbilly
Oddometer: 10,165
Sorry to hear your bike was totaled.
I have two that I couldn't replace with new if they were crashed, the LC4 and SD.
Old 08-25-2012, 01:02 PM   #3029
skibum69
slave to gravity
skibum69's Avatar
Oddometer: 5,477
My cam roller bearing just failed, need a new one of those and a new cam. Still got me home, or at least to where my buddy picked me up.
Beerthief
skibumsoirée2009 skibumsoiré2010
Riff Raff 2015, 2012, 2011, 2010, 2009
RIP ITsteve, ride in peace my friend
save $5 on a new smugmug account, use this coupon7frrnSRiTt9Fk
skibum69 is offline   Reply With Quote
Old 08-25-2012, 01:28 PM   #3030
enduro0125
enduro0125's Avatar
Oddometer: 13,878
How many miles?
AMA 487807A
Times are GMT -7.   It's 08:14 AM.
