Old 12-10-2012, 05:37 PM   #3391
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,354
Originally Posted by Boon Booni View Post
Need some help.
Replacing the front wheel bearings and seals on my 2002 640 Adventure. Bearings are coarse. Seals and bushing surface are shot.
This is what I've got comparing the old parts (top) to the new parts (bottom)...
The new bearings fit perfectly on the axle, the old bearings ride on a bushing which fits on the axle. New seals and bearings won't fit the hub bore.
Any ideas on what I need to order to redo the front end? Anyone want to buy spacers, seals and bearings for a 2002 640 ADV?
Thanks...
FWIW, also ordered bearings and seals for the rear wheel, and everything looks right.
Looking at your old take out units, it appears to me that your bike has the recall front wheel with the Excel rim.... When they recalled the original wheel in 03 due to spoke breakage problems they replaced it with the wheel off the RFS bikes and made the adapter spacers for it to fit the 640 A...
What you need to do is order a bearing and seal kit for a 03 KTM 450/525, even an aftermarket kit will work... You will then need to order the spacers through KTM : part #584 09 012 000... These spacers will take a couple of weeks to arrive as they are a special order item...
gunnerbuck is online now   Reply With Quote
Old 12-10-2012, 06:35 PM   #3392
juames
Have Fun, Don't Die!
juames's Avatar
Oddometer: 2,546
My '02 has the top bearings and spacers. Just bring the old bearings to a bearing shop and they can match them up for you, and clean up the spacers and re-use them...worked for me.
2005 KTM 950 Adventure
Roaming Rally 2011RR12 RR13 RR14 RR15
"I don't hate people...I just feel better when they are not around." - Henry Chinaski
juames is offline   Reply With Quote
Old 12-10-2012, 07:16 PM   #3393
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,917
Yes it does have the Excel Rim.
Thanks.
Yep, I was thinking about cleaning up the spacers, or perhaps taking them to a machine shop and seeing what it would cost to machine them down and having a stainless slip ring made for the seal surface.
Boon Booni screwed with this post 12-10-2012 at 07:50 PM
Old 12-10-2012, 09:41 PM   #3394
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,354
I had my machinist friend make me up a set of spacers for my project bike after I had the wrong parts sent from a KTM dealer as outlined in this thread:http://advrider.com/forums/showthread.php?t=839121
Old 12-10-2012, 10:48 PM   #3395
HydroDog
Oddometer: 141
Thanks.
Why not just go to your favorite bearing store and get a speedy sleeve to fit the seal area?
08 Buell Ulysses
07 GasGas 300
02 MZ Skorpion Traveller
99 KTM 640e
HydroDog is offline   Reply With Quote
Old 12-11-2012, 04:40 AM   #3396
juames
juames's Avatar
Oddometer: 2,546
Anyone know if there is a water pump rebuild kit available, or do I have to order all the part separately?
Planning on doing my first water pump rebuild on my '02, and not sure of what parts I need.
Old 12-11-2012, 05:45 AM   #3397
tdreyer
KTiM
tdreyer's Avatar
Oddometer: 508
Did you not look at the first page of this thread? It is the index for most everything LC4. Anyway, look here. First post gives you the parts breakdown. Bearings and seals can be had cheaper if you've a supplier near by. Just order 2 of everything so you'll have a kit waiting on the shelf for any future emergency or an inmate in need.
~Tim
"04625 SXC
'04 625 SMC 76,xxx mi.
'97 CR500 Sold
tdreyer is offline   Reply With Quote
Old 12-11-2012, 06:43 AM   #3398
skibum69
slave to gravity
skibum69's Avatar
Oddometer: 5,598
have you checked your cam rollers while you're in there?
Beerthief
skibumsoirée2009 skibumsoiré2010
Riff Raff 2015, 2012, 2011, 2010, 2009
RIP ITsteve, ride in peace my friend
save $5 on a new smugmug account, use this coupon7frrnSRiTt9Fk
skibum69 is online now   Reply With Quote
Old 12-11-2012, 06:52 AM   #3399
juames
juames's Avatar
Oddometer: 2,546
Haven't opened it up yet, but it's around 30,000kms now so its probably ready.
Old 12-11-2012, 06:55 AM   #3400
enduro0125
Sticks and Stones™..
enduro0125's Avatar
Oddometer: 14,687
Do it.
DAMHIK
AMA 487807A
enduro0125 is offline   Reply With Quote
Old 12-11-2012, 07:33 AM   #3401
juames
juames's Avatar
Oddometer: 2,546
Worth doing both intake and exhaust?
Old 12-11-2012, 07:35 AM   #3402
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,917
I'd never heard of a speedy sleeve before. That's exactly what I'm looking for.
Good idea.
Old 12-11-2012, 02:11 PM   #3403
enduro0125
enduro0125's Avatar
Oddometer: 14,687
Yes.
AMA 487807A
Old 12-11-2012, 03:38 PM   #3404
skibum69
slave to gravity
skibum69's Avatar
Oddometer: 5,598
Do it, don't end up like I did
Beerthief
Old 12-11-2012, 03:44 PM   #3405
enduro0125
enduro0125's Avatar
Oddometer: 14,687
Or me.
AMA 487807A
Times are GMT -7.   It's 09:26 AM.
