Old 12-14-2012, 11:58 AM   #3421
tdreyer
KTiM
tdreyer's Avatar
Oddometer: 448
~Tim
"04625 SXC
'04 625 SMC 76,xxx mi.
'97 CR500 Sold
tdreyer is online now   Reply With Quote
Old 12-14-2012, 01:09 PM   #3422
Droptarotter
Oddometer: 833
Originally Posted by Superpacman13 View Post
Thank you guys for making me check my rocker bearings! Just saved myself some serious dough, the inlet one was close to going kaboom.
How does the cam look?
Do all the top end bearings while you are in there.........you should be able to find most of them at a bearing house.
Cheers
HP2 Sport, R1200S, R100S, KTM 640 Adventure, KTM 520 EXC/Motard, Yamaha RZ350, Hodaka 125 Wombat
Droptarotter is offline   Reply With Quote
Old 12-15-2012, 05:17 PM   #3423
skibum69
slave to gravity
skibum69's Avatar
Oddometer: 4,456
Send a message via AIM to skibum69 Send a message via Skype™ to skibum69
My parts list was $1000
Riff Raff 2012, 2011, 2010, 2009
Skibum Soiree 2012
Skibum Soiree 2011skibum soiree '10
RIP ITsteve, ride in peace my friend
save $5 on a new smugmug account, use this coupon7frrnSRiTt9Fk
skibum69 is offline   Reply With Quote
Old 12-17-2012, 11:40 AM   #3424
supercoyote
Oddometer: 46
Hopefully the great LC4 hivemind can help me, i`m looking at a 2007 450 SX-f muffler to replace the boat anchor hanging off my tail end right now. Anyone know about if the header sizes are similar to stock?
There's only one rule that I know of, babies - God damn it, you've got to be kind.
supercoyote is offline   Reply With Quote
Old 12-17-2012, 12:35 PM   #3425
TaxMan
TaxMan's Avatar
Oddometer: 83
Originally Posted by NSFW View Post
same here.
the front wheel, i mean the hub, bearing and seal must be from a 525exc and using a bushing with a 20 mm bore to fit the 640 front fork.
boon boon, measure the bushing od, and if it is 26 mm, then our hunch is right.
if that's the case, you need the bearing and seals for the 525 exc, i have a 2003 (first year model) 525 exc and has 26mm axle.
Big thanks for all this info. I've been shopping for a second front wheel on my 03 (to run street tires) for a couple of months. I knew I had the smaller axle but wasn't sure exactly how the setup changed with the wheel replacement.my assumption was that they used the 03 OEM hub with just a different rim, so my assumption was that the spacers I had were for a 20mm hub. Thus, I was shopping for a wheel with the old style hub. But seeing these pics make me realize i need to take it back apart to check the OD of the spacer because the top portion of the pic looks like what i remember seeing on mine. the bigger hub used on the newer bikes is good news for buying a new wheel. it opens up better options for buying much newer used.
2002 Triumph Bonneville
2003 KTM 640 Adventure
TaxMan is offline   Reply With Quote
Old 12-18-2012, 10:02 PM   #3426
stumpy-ktm
stumpy-ktm's Avatar
Oddometer: 64
pride in orange !!!
ok so , i posted a little while ago in the ouch forum , and someone said i wasnt orange enough in my dedication , so i thought about it , and then hand painted my leg covers up .... !!!!! the only thing that could top it is a tattoo ....
" lost a leg .....still riding "
2004 ktm 640 supermoto
stumpy-ktm is offline   Reply With Quote
Old 12-19-2012, 04:38 AM   #3427
liferider
Never It's enough
liferider's Avatar
Oddometer: 559
Great job, you have your personal fork protector, that makes you the most KTM rider of all...!
We are proud to have you as a rider and as an inmate, man.
By the way, your bike's side plates would be highly appreciated by our inmate bmwktmbill
Cheers!
'Long Life to Dirt Riders'
__________________________________________________ _______
Argentina-Chile-Peru - Home of the Dakar ... again ... and again... and again!
liferider is offline   Reply With Quote
Old 12-20-2012, 08:00 PM   #3428
liferider
Never It's enough
liferider's Avatar
Oddometer: 559
Cheers!
Old 12-21-2012, 03:10 AM   #3429
enduro0125
Sticks and Stones™..
enduro0125's Avatar
Oddometer: 9,946
Send a message via Skype™ to enduro0125
Cool!! And same to you.
AMA 487805A
enduro0125 is offline   Reply With Quote
Old 12-21-2012, 11:39 AM   #3430
mgorman
Crashing since 1964
mgorman's Avatar
Oddometer: 4,250
Ditto!!!
Michael
mgorman is offline   Reply With Quote
Old 12-21-2012, 11:59 AM   #3431
laramie LC4
crash test dummy!
laramie LC4's Avatar
Oddometer: 2,059
Originally Posted by liferider View Post
Cheers!
Hey! that's not an LC4!
what are ya doing, trying to start a fight? oops, forgot, i have one of those now too.....
Merry Christmas ya bunch of Nut's!
laramie
DON'T TRUST CUT 7! HE IS A CROOK! ASK ME HOW I KNOW.
'12 LC8 990R, '02 LC4 640, '05 WR 450f (part-out), '98 XR400R, '76 KE100, '05 525 (Step-Child)
laramie LC4 is offline   Reply With Quote
Old 12-23-2012, 04:09 PM   #3432
dolphins13
orange rules
Oddometer: 119
Anyone ever have an adjuster screw (for chain tension) freeze up? It is basically just a screw going into threads. How can it be froze up? No outter signs of rust? I tried heating it up. Am I missing something simple here? Any help would be much appreciated?
dolphins13 is offline   Reply With Quote
Old 12-23-2012, 04:16 PM   #3433
enduro0125
enduro0125's Avatar
Oddometer: 9,946
Steel and aluminum don't play nice together.
The bolt should always be slathered with never-seize.
As a long time KTM rider this has been a known issue since the late 80's,I do this to all my bikes.
Unfortunately its Too late for you now.
I think someone posted on this(maybe early in this thread?)
AMA 487805A
Old 12-23-2012, 04:58 PM   #3434
nfranco
over macho grande?
nfranco's Avatar
Oddometer: 707
Try some PB blaster on the screws overnight and tap on the head of with a hammer in the morning.
nfranco is offline   Reply With Quote
Old 12-23-2012, 06:13 PM   #3435
mcguyver
mcguyver's Avatar
Oddometer: 1,087
Yep what he said. I too have had this happen. No easy fix as far as I know.
My Blog
www.seqtrailrider.typepad.com
mcguyver is offline   Reply With Quote
Times are GMT -7.   It's 09:09 AM.
