Old 12-23-2012, 08:22 PM   #3436
gunnerbuck
I.Hopp.
Oddometer: 3,076
Originally Posted by dolphins13 View Post
Anyone ever have an adjuster screw (for chain tension) freeze up? It is basically just a screw going into threads. How can it be froze up? No outter signs of rust? I tried heating it up. Am I missing something simple here? Any help would be much appreciated?
I have used a bit of heat on the swing arm around the adjuster to expand it, then coat the bolt threads with oil and work it back and forth ... Once it frees up then coat the threads with grease and repeat coat it every once in a while...
640 A x 2
gunnerbuck is online now   Reply With Quote
Old 12-23-2012, 09:41 PM   #3437
bmwktmbill
Traveler
Oddometer: 4,000
Do you have one of the old manual hammer impact drivers.
I'd do everything recommended so far and then try some impact and prayer to the gods of small things.
This:
http://en.wikipedia.org/wiki/Impact_driver
I'd use propane for heat first before something else...?
bill
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill is offline   Reply With Quote
Old 12-23-2012, 09:58 PM   #3438
Aussie Steve
Aussie Steve's Avatar
Oddometer: 1,312
The swingarm fills up with water which cant escape and the adjuster screw rusts. Can be helped with very small holes to drain and prevented with regular greasing of the screws.
Aussie Steve is offline   Reply With Quote
Old 12-23-2012, 11:00 PM   #3439
warewolf
Tyre critic
warewolf's Avatar
Oddometer: 2,168
Send a message via MSN to warewolf Send a message via Skype™ to warewolf
Yep, known issue. For the last 5 or 6 years KTM have put big plastic plugs in the SX/EXC swingarms to help them dry out.
I've freed mine up sometimes, and have stuffed the thread on one or two bolts early on. Try flooding the inside with wd40 or crc556 or something, put the bent straw through the chain guard screw holes to spray the end of the bolt.
As has been mentioned, they get wet inside and rust, and then when you screw the bolt out to take up the slack in the wearing chain, you draw the rusty end of the bolt into the captive thread. If you force this, it will end in tears. Instead, screw them in as much as you can, spray/soak with penetrant, and then ease them out. Remove the axle so you can get a good socket on the end, rather than a spanner; it helps to hit it with a better connection.
Once you get it sorted, dry it out, spray with crc/wd again, and then seal up all the holes in the swingarm with silicone (screw the chain guard back on through the silicone before it sets). I haven't had a problem since doing this.
Cheers,
Colin
KTM LC4 640 Question? Check here first --> KTM LC4 (640) Index Thread
Originally Posted by Steve McQueen
All racers I know aren't in it for the money. They race because it's something inside of them... They're not courting death. They're courting being alive.
warewolf is offline   Reply With Quote
Old 12-23-2012, 11:33 PM   #3440
dolphins13
orange rules
Oddometer: 117
thx for the good advice people. So I will heat, lube, beat, twist, jerk. Then I will work on the bike. I figure I will end up cutting it off and drilling the rest out. So aggravating when all you wanna do is adjust chain.
dolphins13 is offline   Reply With Quote
Old 12-24-2012, 05:33 AM   #3441
laramie LC4
crash test dummy!
laramie LC4's Avatar
Oddometer: 2,059
i would also take a small drill bit and drill a drain hole on the bottom of your swing arm so that if you do get any water inside it can easily drain out and not cause more problems. i did this when i got my bike new, then added the anti-seize and have never had a problem with them.
good luck with those bolts.
laramie
DON'T TRUST CUT 7! HE IS A CROOK! ASK ME HOW I KNOW.
'12 LC8 990R, '02 LC4 640, '05 WR 450f (part-out), '98 XR400R, '76 KE100, '05 525 (Step-Child)
laramie LC4 is offline   Reply With Quote
Old 12-24-2012, 06:48 AM   #3442
dirty_sanchez
Dirty_Sanchez
dirty_sanchez's Avatar
Oddometer: 2,094
Team-
We don't want to use a Copper Anti-Seize on those axle adjusters. Copper and Aluminum don't play well together.
Dirty
No, really, the mustache means I love you.
'09 KTM 250SXF for Sale, take a look: http://advrider.com/forums/showthrea...7#post21410167
dirty_sanchez is offline   Reply With Quote
Old 12-24-2012, 12:26 PM   #3443
mgorman
Crashing since 1964
mgorman's Avatar
Oddometer: 4,241
Originally Posted by dirty_sanchez View Post
Team-
Dirty
Now you tell me!! I guess I've been lucky, so far they keep coming out. I have another can of marine grade, I'll make sure to start using that instead
Michael
mgorman is offline   Reply With Quote
Old 12-24-2012, 01:34 PM   #3444
dolphins13
orange rules
Oddometer: 117
This:
bill
Actually went to 2 stores to find an old style hammer impact driver. They looked at me like I was nuts. Used my old one all the time. I like the idea of drain holes. I cant believe I never had this problem before.
dolphins13 screwed with this post 12-24-2012 at 01:37 PM Reason: To add information.
Old 12-24-2012, 06:04 PM   #3445
Droptarotter
Oddometer: 827
I drilled a 1/8 drain hole in my swingarm today...........got about 100cc's of water out of it.
I remember when I drilled the swingarm on my 520.......there was tons of water in there, but that bike had been through quite a few water holes!
Thanks for the reminder Laramie!
Cheers
HP2 Sport, R1200S, R100S, KTM 640 Adventure, KTM 520 EXC/Motard, Yamaha RZ350, Hodaka 125 Wombat
Droptarotter is online now   Reply With Quote
Old 12-24-2012, 08:17 PM   #3446
dirty_sanchez
Dirty_Sanchez
Oddometer: 2,094
Marine Grade or a Heavy Duty Anti-Seize are the two I use....just stay away from that copper.
Dirty
Old 12-24-2012, 11:21 PM   #3447
bmwktmbill
Traveler
Oddometer: 4,000
Now I know for sure I've lived a charmed life.
Merry Christmas all.
bill
Bill Shockley
Old 12-25-2012, 08:06 AM   #3448
mgorman
Crashing since 1964
mgorman's Avatar
Oddometer: 4,241
Michael
Old 12-25-2012, 11:01 AM   #3449
skibum69
slave to gravity
skibum69's Avatar
Oddometer: 4,456
Send a message via AIM to skibum69 Send a message via Skype™ to skibum69
Meeryxmas folks, thanks for the tip on the drain holes, my swingarm is probably full
Riff Raff 2012, 2011, 2010, 2009
Skibum Soiree 2012
Skibum Soiree 2011skibum soiree '10
RIP ITsteve, ride in peace my friend
save $5 on a new smugmug account, use this coupon7frrnSRiTt9Fk
skibum69 is offline   Reply With Quote
Old 12-25-2012, 11:06 AM   #3450
Lortdadu
Joe Cool
Lortdadu's Avatar
Oddometer: 183
Merry Christmas and Happy Holidays!
I may not have gone where I intended to go, but I think I have ended up where I needed to be. - Douglas Adams
KTM LC4 400 2002 - Military version
Lortdadu is offline   Reply With Quote
Times are GMT -7.   It's 10:53 PM.
