Old 01-13-2013, 05:21 PM   #3541
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,602
Originally Posted by biensur22 View Post
I see what you're saying, but my frame hole is definitely threaded. I wonder if I should just drill it out.
I like the idea of both, an I would generally prefer the kick over the center for convenience, but the stock kickstand is so flimsy I'm always affraid it's about to break off.
Well, my bike is a 2002 so there are probably some differences. The KTM side stand for my bike uses both bolt holes on the left side, one of which is the bottom "stamped" hole for the center stand. If that hole is not blocked on your bike, then maybe you can just drill it and use the side stand and center stand together. Or maybe there was a different design of center stand for your bike?
EDIT: Just looked your bike up on the Fiche, looks like it's the same setup as mine, so I don't know why that bottom bolt hole on your bike is threaded.
Boon Booni screwed with this post 01-13-2013 at 05:31 PM
Boon Booni is online now   Reply With Quote
Old 01-13-2013, 05:31 PM   #3542
biensur22
biensur22's Avatar
Oddometer: 179
Originally Posted by Boon Booni View Post
Well, my bike is a 2002 so there are probably some differences. The KTM side for my bike uses both bolt holes on the left side, one of which is the bottom "stamped" hole for the center stand. If that hole is not blocked on your bike, then maybe you can just drill it and use the side stand and center stand together. Or maybe there was a different design of center stand for your bike?
So it sounds like the best solution would be to drill it out. I'm ok with that, I've had a some time to morn the loss of arbitrary threading and I've accepted it.
Did you have a stomp pad (can't think of the right name for it) welded onto your center stand for ease of use, of do you just use it as it came?
Current Rides:1998 KTM 620 Adventure
Past Rides: 1994 KTM 400 EXC WP/D LC4 - Plated; 2001 BMW F650GS Thumper; 1970 CB175; 2003 KLR250
biensur22 is offline   Reply With Quote
Old 01-13-2013, 08:17 PM   #3543
bmwktmbill
Traveler
Oddometer: 5,143
You get to the point where you have had it...
The hot wrench, custom bend and BTW!
Please note only one spring(extra carried for a spare because the smack two springs will give your lower leg makes water boarding seem like child's play).
My center stand is shortened for lowered suspension and has the infamous step from back in the day which ID's me as an old fool.
And yes the whole kickstand broke off and the bike and I fell on my tent and I almost died.
bill
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill screwed with this post 01-13-2013 at 08:27 PM
bmwktmbill is offline   Reply With Quote
Old 01-13-2013, 08:20 PM   #3544
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,602
No I haven't.
Originally Posted by bmwktmbill View Post
That's a SW Motech that's been welded?
Old 01-14-2013, 02:10 AM   #3545
640 Armageddon
-oo-
640 Armageddon's Avatar
Oddometer: 2,671
It certainly looks like a Motech. The ''death trap'' as some of us call it .. It will damage your shin big time if it happens to get in its way while it is retracting ...
A word of caution. Welding is way better. If you use the same bolt for the side and the center stand, there is a good chance that the center stand bolt breaks if the load on the bike is high. It has happened and the only way to avoid was to drill through the center stand and put bolts. If it is left on its own (the center stand I mean), it should be ok.
I have seen other bike which have both the side KTM stand and the center but have no idea how they do it
Aurora Rally Equipment - Rally parts with lifetime warranty
"Do or Do Not. There is No Try" - Yoda
640 Armageddon is offline   Reply With Quote
Old 01-14-2013, 02:19 PM   #3546
Droptarotter
Oddometer: 1,250
Here's how you install a SW Motech stand with a KTM centre stand the proper way................
Cheers
HP2 Sport, R1200S, R100S, KTM 640 Adventure, KTM 520 EXC/Motard, Yamaha RZ350, Hodaka 125 Wombat
Droptarotter is offline   Reply With Quote
Old 01-14-2013, 07:35 PM   #3547
bmwktmbill
Traveler
Oddometer: 5,143
That's nice Drop, I'm not sure what's holding my center stand on, a piece of the old stud?
The kickstand is a SW Motech.
The death trap..perfect, never heard that.
bill
Bill Shockley
Old 01-15-2013, 09:20 AM   #3548
Droptarotter
Oddometer: 1,250
Bill;
It looks like on the left side of your bike, the centre stand is held on by whats left of the stud.
My old 640 was like that when I got it.
It might be an idea to get the left side fixed up with a welded bolt like I used.
Get a bolt that has a bit of a shoulder so any threads that might be there do not dig into the frame or wear out.
Cheers
Old 01-15-2013, 08:36 PM   #3549
bmwktmbill
Traveler
Oddometer: 5,143
Originally Posted by Droptarotter View Post
Bill;
Cheers
Drop,
Now I get it and know for sure I need to fix mine like you did.
Darn, better get on that.
The center stand should pull off with the kickstand in place. Right?
Wish my bike was cleaner.
I rode it just before the snow flew.
Thanks,
bill
Bill Shockley
Old 01-16-2013, 10:39 AM   #3550
Droptarotter
Oddometer: 1,250
Bill;
The centre stand should remove with the side stand staying in place with the upper bolt.
Your side stand is welded on, correct?
If you weld on a longer bolt onto the centre stand.........try to get a bolt with a shoulder long enough to go through the frame and your side stand.
Use a 10mm bolt. The stock stud has a 10mm shoulder, but drops to an 8mm stud.
You will need to use a nylock or stover nut with a flat washer as you can not tighten the nut up completely. It needs to swing with the centre stand.
Once you install the nylock/washer, cut the excess bolt off.
Cheers
Old 01-16-2013, 09:49 PM   #3551
bmwktmbill
Traveler
Oddometer: 5,143
Bill;
Cheers
Got it.
Nylock is an easy idea.
Thanks,
bill
Bill Shockley
Old 01-18-2013, 06:00 PM   #3552
T3/T4 Hybrid
Lone Rider
T3/T4 Hybrid's Avatar
Oddometer: 72
Hello, I'm a new to me KTM owner. I purchased a 2000 640 LC4 in Dec of 2012 and was hoping someone here could direct me to where I could purchase a decal for my gas tank. Im looking for an orange decal like the one in this post on ADV Rider. http://www.advrider.com/forums/showthread.php?t=253464
Thanks for any assistance.
It's kind of strange, how the mountains pay us no attention at ll. You laugh or cry and the wind just keeps on blowing.
T3/T4 Hybrid is offline   Reply With Quote
Old 01-18-2013, 06:37 PM   #3553
Gerst
Gerst's Avatar
Oddometer: 250
Hi all, this is a premature post on my part. But I think I have this bracket, new, in a box somewhere.... If anyone wants it I'll let it go for shipping plus a donation to Baldy. I'm posting before I confirm this as I know I'll forget about it if I don't do it now. With my current work schedule it may take a few weeks before I can dig it out and ship it. If your interested PM me, be patient and I will get back to you. Just trying to help out an inmate and ADV which has given me so much.
Gerst
Gerst is offline   Reply With Quote
Old 01-18-2013, 10:21 PM   #3554
Low594
Adventuring Creep
Low594's Avatar
Oddometer: 1,148
Gerst
I could definitely use it if its the SW-Motech, which is what that looks like. Mine was left loose for too long and needs alot of help! Sending PM
Low594 is offline   Reply With Quote
Old 01-19-2013, 09:27 AM   #3555
Droptarotter
Oddometer: 1,250
Low;
If Gerst has the exact stand mount that is on my bike, then it IS a SW Motech mount.
Cheers
Times are GMT -7.   It's 06:34 PM.
