Old 03-31-2009, 09:17 PM   #766
Renazco
Formerly AKA Boejangles
Renazco's Avatar
Oddometer: 4,694
Originally Posted by Chrisbarnes1
I have a 2005 640 Adventure and have managed to acquire a plastic 28 litre fuel tank. The mounting looks the same as my standard tank--and I can't see much difference, if any, in the internal cutouts (do I need to remove the SAS?).
The real issue I think I have is mounting the frame for the fairing/front screen to the top of the tank--there are no threaded inserts or tapped holes?. I could use self tappers and gaskets and probably seal it ok as the holes will be in "air" most of the time. However, were the earlier fairings mounted in a different way as there is evidence (rub marks) in the right place?
Regards, CB
I'll take a pic of my set-up and see if it helps, give me a day or two..
Seats www.renazco.com
Parts & Accesories www.renazcoracing.com
Renazco is offline   Reply With Quote
Old 04-01-2009, 12:14 PM   #767
Chrisbarnes1
Oddometer: 374
28 litre Acerbis plastic tank
many thanks for the help--ADV comes up trumps again!
Regards, chris
Originally Posted by meat popsicle
Hey Chris,
There has been a thread or two on that issue... LukasM has had info... searching... here's one:
http://www.advrider.com/forums/showthread.php?t=443545
Chrisbarnes1 is offline   Reply With Quote
Old 04-02-2009, 01:40 AM   #768
Chrisbarnes1
Oddometer: 374
look forward to them--I now realise why the fixings are not there--but it looks like it comes from the same mould (my standard tank even has the tap locations for the RHS (rear))--not used on the bike but used on the plastic version (which doesn't use the standard crossover pipe).
My favourite for a "fix" is to use the fairing brackets off my tank but instead of bolting them use an outdoor grade of velcro in a strip which should have enough surface area for a good attachment plus allow a degree of vibration absorption (and no extra holes required in the tank--those that are there are into plastic internal "bubbles" so that the hardware never goes through to the fuel).
Regards, Chris
Old 04-12-2009, 07:47 AM   #769
neumie
neumie's Avatar
Oddometer: 121
'01 640 ADV tank leaking
My gas tank leaks where a small access panel resides on the clutch side of the engine above the petcock. I "repaired" this twice already and each lasted for some time.
The first repair was a clean-up of the gasket and refreshing it with a gasket dressing. This lasted for about a month.
For the second repair I removed the rubber gasket and used WaterWeld a JBWeld product. This was a field repair and lasted 3 1/2 months.
Here's a picture of the tank. Sorry it is linked and not imbedded.
http://www.facebook.com/photo.php?pi...&id=1673251487
I've searched the index.
Any suggestions?
2009 KTM 400 XC-W
neumie is offline   Reply With Quote
Old 04-19-2009, 05:18 PM   #770
i8lusaka
Guest
Oddometer: n/a
KTM 660 for Africa??
Hi there
I have a KTM660 and a DR350 and my question is as follow.
Shall I sell the DR350 and spend the money on a tank(28l),sub frame (alu original), 21" front wheel and sump gard conversion on my 660 and will it survive Africa UK to SA
Or keep the KTM for road fun until the trip in 2011 and sell it then and take the DR350.
would be nice with some pro and cons.
Old 04-20-2009, 08:38 AM   #771
meat popsicle OP
Ignostic
meat popsicle's Avatar
Oddometer: 13,844
Originally Posted by i8lusaka
Hi there
Probably the best place to ask this question is the LC4 "sign in thread" (in the index), but for long-distance touring the 625 is a better choice than the 350, but not critically-so. I need to find the posts of Carlos in Africa...
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 04-20-2009, 10:58 AM   #772
i8lusaka
Guest
Oddometer: n/a
sorry could you move it there then mate
Old 04-20-2009, 12:46 PM   #773
meat popsicle OP
Ignostic
Oddometer: 13,844
sorry but I'm not a moderator. You can post it again in there if you like.
Old 04-20-2009, 01:20 PM   #774
i8lusaka
Guest
Oddometer: n/a
Ok I thought you where sorry my mis I will do so Thanks
Old 04-21-2009, 04:25 AM   #775
skibum69
slave to gravity
skibum69's Avatar
Oddometer: 4,456
Send a message via AIM to skibum69 Send a message via Skype™ to skibum69
easy to make that mistake
Riff Raff 2012, 2011, 2010, 2009
Skibum Soiree 2012
Skibum Soiree 2011skibum soiree '10
RIP ITsteve, ride in peace my friend
save $5 on a new smugmug account, use this coupon7frrnSRiTt9Fk
skibum69 is offline   Reply With Quote
Old 04-21-2009, 06:31 AM   #776
Truckin_Thumper
low profile
Truckin_Thumper's Avatar
Oddometer: 26,100
what after market clutch perch will work with a stock cable on an LC4e 640?
I was told the cable end (jacket) is proprietary to KTM.
MC MC MC MC P/U MC MC Semi MC MC MC Car MC MC
Truckin_Thumper is offline   Reply With Quote
Old 04-21-2009, 06:40 AM   #777
NICO
NWGS's pwner!1!!1!
NICO's Avatar
Oddometer: 18,680
This will do in a pinch.
Then you might be stuck shelling out KTM money. I haven't found any aftermarket source, but I haven't looked that hard for them either.
NICO is offline   Reply With Quote
Old 04-21-2009, 08:35 AM   #778
meat popsicle OP
Ignostic
Oddometer: 13,844
It looks "bad" here, but that is the point of the Index thread - not to answer questions (NICO ), but to tell people where to go... and no, not to Hades.
Old 04-21-2009, 09:15 AM   #779
LukasM
Oddometer: 4,923
Hi there
It depends. 660 as in 660 SMC? Quite a few mods needed as you noted. The KTM will obviously be more fun and also more comfortable as long as you are riding, the DR is a bit easier to pick up in the sand and uses less gas.
What year and mileage? DR is a low powered and pretty much bullet proof bike. The LC4 has a somewhat mixed track record, you might make it - and lots of them do - without a single hiccup, or the engine could blow up on you without warning. Happened to me....
Proud member of the HUSABERG ADVENTURE TEAM!
'12 Husaberg FE570, 09 KTM XC-F/ 450 RFS hybrid, 07 KTM 450 SMR, 08+09 BMW F650GS twins/F800GS conversion, 03+05 YZF-R6
Old 04-21-2009, 10:44 AM   #780
i8lusaka
Guest
Oddometer: n/a
Thanks mate you are right I think I will stick to the DR350 for a long trip and keep the 660 for playing
Times are GMT -7.   It's 02:49 AM.
