Old 06-02-2009, 05:22 PM   #796
NICO
NWGS's pwner!1!!1!
NICO's Avatar
Oddometer: 25,999
I hope I didn't come off like a dick, but most folks don't look into this thread but for the links. Hopefully, someone will be able to hook you up with a jet.
Originally Posted by NWGS
This post has zero to do with civility and more to do with stupidity.
NICO is offline   Reply With Quote
Old 06-02-2009, 06:58 PM   #797
balance
balance's Avatar
Oddometer: 1,239
Not at all, I've just had a truckload of obstacles in getting parts for my 640 and wanted to reach out to the LC4-specific crowd. Sudco's shipping out some new jets and, pending any other delays, I'll have KTM Adventure Tours 'RALLY 10' buttoned back up in time for the weekend.
And not to get all sentimental and shit, but HUGE thanks to all who contribute to the LC4 (640) thread index. All the write-ups, how-to's and friendly/fatherly advice are definitely appreciated.
Scott
'09 KTM 530 EXC
'00 Kawasaki Super Sherpa
balance screwed with this post 06-03-2009 at 05:25 AM
balance is offline   Reply With Quote
Old 06-08-2009, 09:42 PM   #798
thebrown
likes beer
thebrown's Avatar
Oddometer: 73
g'day
loads of good info here
anyone know if there has been a thread on my current problem
ive a 2004/5 lc4 640 enduro
it has been in the shed for the last 5 months or so
so i pulled it out and charged the battery as it went dull pretty quick when i checked if it would turn over
it wont start
this has been a problem before after a couple of months in the shed
but on previous occasions a jump start off the car or kicking has eventually got it going not too long after ive flattened the battery
i have tried it for a lengthy couple of times jumping it off the car battery
have cleaned the air filter
have checked the spark
its getting fuel as the plug is wet if i pull it
have drained the carb and although there may have been a little silt in the fuel there was plenty in there
any ideas on the most likely cause(s) would be greatly appreciated
cheers
browny
thebrown is offline   Reply With Quote
Old 06-08-2009, 10:07 PM   #799
meat popsicle OP
Ignostic
meat popsicle's Avatar
Oddometer: 14,248
oi browny,
I don't recall that specific suite of issues, and that type of troubleshooting bit is best put in its own thread. Well, maybe there could be a "trouble starting my LC4 thread" but nobody's started it yet... of course now one would have to find all the other similar threads/posts and link them in
meat popsicle is offline   Reply With Quote
Old 06-08-2009, 10:12 PM   #800
thebrown
likes beer
thebrown's Avatar
Oddometer: 73
thanks mp
new thread coming up
Old 06-09-2009, 08:53 AM   #801
the88tlc
Oddometer: 14
625 sxc - spring wrenching - do i need to burp this big boy?
thanks to all for all the help on the maintenance, and the repairs needed on my 03 625 sxc.
The forks were leaking a bit, so off they came, and when its down, i just tend to take it apart and fix much of the other broken, repaired, and snotty areas.
oil leaking in the top front of the engine - removed the rocker cover, and applied new sealer. also sealed the upper exhaust bolt.
ducttape and allen wrench on front brake line - the stiffener had cracked bent blew to bits. i had repaired in the field with ductape and a 6mm allen wrench. now i had to buy and replace the whole line.
rebuilt waterpump
adjusted valves
replaced turn signal module that was smashed
put it all back together, and it runs great! only question i had, do i need to somehow burp this big boy? is there a process to make sure there isnt a bubble in the engine block?
thanks again for a great resource!
adventure is not a race....
http://web.mac.com/bhartlieb/iWeb/bh...adv.logan.html
the88tlc is offline   Reply With Quote
Old 06-09-2009, 08:57 AM   #802
Truckin_Thumper
low profile
Truckin_Thumper's Avatar
Oddometer: 28,890
bleed the frame fill up hole like a brake line
snug it down by hand
put 8mm wrench on it
start engine
when oil weeps out, tighten it up
Problem solved
P.S. might have to loosen it up until it leaks oil
gimmie the button!
Truckin_Thumper is offline   Reply With Quote
Old 06-09-2009, 12:51 PM   #803
the88tlc
Oddometer: 14
ktm 625 sxc - coolant burping
thanks for the reply.... my 625 does not have a frame reservoir, but i do bleed the oil from one of the banjos....
but my concern was on the coolant (sorry for not explaining WHICH liquid i needed burping out of the boy).
i have had a friend fry a 300 2 stroke for not burping it, so HE is most concerned... i would have just ridden off into the sunset...
Old 06-09-2009, 01:07 PM   #804
Laromonster
Vesperado !
Laromonster's Avatar
Oddometer: 1,328
The coolant burp plug is in the head
Loosen the bolt a couple of turns, fill rads untill you see coolant seep past the bolt, snug it down.
Fill rads completely , massage the hoses and tilt the bike to both sides to let trapped bubbles escape.
Start the bike and let it idle with the cap off for a minute or so
Done
'99 Road king
'09 XR1200
Laromonster is offline   Reply With Quote
Old 06-09-2009, 01:42 PM   #805
ChrisC
Amal sex?
ChrisC's Avatar
Oddometer: 6,316
Ah, no... that's the sparking plug
Chris
1974 Bultaco Sherpa T 350
1943 BSA M20WD
ChrisC is offline   Reply With Quote
Old 06-09-2009, 01:51 PM   #806
Laromonster
Vesperado !
Oddometer: 1,328
oy vey..
'99 Road king
'09 XR1200
Old 06-09-2009, 02:30 PM   #807
meat popsicle OP
Ignostic
Oddometer: 14,248
I still thought he needed to burp the oil... so ChrisC is going to be busy until we get off our butts.
Burping the coolant in the engine? I never heard of this; the only thing I knew was to run the newly filled radiators with the cap off to let them bubble away. Then once the bubbling was done, top off to level, and closer 'em up.
Old 06-09-2009, 03:38 PM   #808
the88tlc
Oddometer: 14
thanks again for the help and for all antics! yes that looks like the spark plug to me....
i will look around in this vicinity for a head bolt for burping. the rads are already full, so i will just let the air escape, and then top off.
Thanks also for all the helpful tips on the other 625 improvements, and maintenance, doing all this without a manual, so some good instruction, and a couple photos goes a long way!....
Old 06-09-2009, 03:54 PM   #809
meat popsicle OP
Ignostic
Oddometer: 14,248
Chris, that was a direct translation of the Norwegian...
Old 06-10-2009, 08:30 AM   #810
the88tlc
Oddometer: 14
625 sxc burp bolt
glad to report that i found the head burp bolt.... it was a little harder to get to with tank on and everything assembled. but was a satisfying little burp it made, with some air, then a little blip of coolant.
i tightened it down, and it seems to run great and holding fluid level.
thanks again for all the how tos - rocker cover sealant (used hondabond ht and it worked great), valve adjustment, waterpump overhaul, radiator fan wiring, and brake line replacement.
I ran it around last night, the mandatory ride, and found that it runs great, ready for a summer of adventures!
Times are GMT -7.   It's 03:17 AM.
