Old 11-11-2010, 05:25 PM   #1156
frdbronco8
frdbronco8's Avatar
Oddometer: 245
Originally Posted by rxcrider
Looks like the factory exhaust minus the super trap discs, hardware and deflector that tried to keep the heat off the fender extention (sometimes successfully) I'm guessing it is a bit louder than it is supposed to be at the moment, but I'm sure that big mess of steel is deadening things a bit. You can sometimes find a slightly newer factory supertrapp with internal discs dirt cheap. doesn't save much weight, but looks better and keeps the discs out of the mud (and keeps the hot gasses away from the plastic bits better)
I think theres one on Ebay for $160. Think Ill just sandblast this one for now and see if I can get another year out of it unless something cheaper comes along.
2005 Yamaha Roadstar 1700
2008 KTM 450 XC (540) ATV
2005 KTM 450 EXC
frdbronco8 is offline   Reply With Quote
Old 11-11-2010, 05:35 PM   #1157
Zecatfish
XTique Rider
Zecatfish's Avatar
Oddometer: 7,927
Originally Posted by gunnerbuck
It would likely be the waterpump leaking... A leaking head gasket usually causes noticeable steam in the exhaust stream....
Replacing just the seal will probably work if the waterpump shaft is not grooved too deeply... The seal #s are DG 15 24 7... A bearing shop can likely supply it for about $10... Make sure you get a double lip seal which is probably what the DG in the part # refers to...
Found it, not going to order it but got a good part number.
http://www.houstonbearing.com/storef...49&itm_index=0
Google Earth GPS Howto (still a work in progress) use USGS TOPO Maps to layout trails.
http://home.windstream.net/catfish/GPS
The Early Bird gets the worm, but the second mouse gets the cheese.
https://sites.google.com/site/ozarkadventuretours/
Zecatfish is offline   Reply With Quote
Old 11-11-2010, 07:20 PM   #1158
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,221
As long as it is a 2 lip seal it should work.... A while back an inmate was frustrated after installing seals a couple times and finding his pump would still leak shortly after... It turns out the seals he was using were the single lip variety designed to only seal from one direction... The waterpump seal must work from both: keeping the oil in the engine side and the coolant in the waterjacket/rad...
gunnerbuck is offline   Reply With Quote
Old 11-12-2010, 12:20 AM   #1159
makazica
makazica's Avatar
Oddometer: 746
Originally Posted by veetwo _tls
my 640 fcr carb are set at idle 1500rpm. which is about right.
i've noticed my fast idle flex screw is all the way in to get it to idle at this.
what do i do to have some play in that cable if need to up the idle ?
the pull throttle cable adjuster at the carb is at the max too.
The idle thing doesn't sound right, are you sure you have a correct idle jet and that you mixture is set up right?
M.
makazica is offline   Reply With Quote
Old 11-12-2010, 03:27 AM   #1160
veetwo _tls
RENOVATIO:
veetwo _tls's Avatar
Oddometer: 1,849
M.
the carb came off a good running 640ADV - GreyDawggg's bike
all i done to the carb was install this Air Fuel Jet Screw (set to what the OE was) - to suit KTM EXC SX FCR Carb (the seller said it the one i needed)
http://cgi.ebay.com.au/Air-Fuel-Jet-...item2a0505784b
did i buy the wrong one
here it is before i installed it NOTE the fast idle spring you can see it's wound right up.
Sent from my HTC ONE X - Using Rooted S-OFF , Open Home 6 & Buuf icon pack
http://forum.xda-developers.com/ BUILD YOUR OWN PHONE
CHEERS: brett
MY07 950 SER
veetwo _tls screwed with this post 11-12-2010 at 05:27 AM
veetwo _tls is offline   Reply With Quote
Old 11-12-2010, 04:58 AM   #1161
makazica
makazica's Avatar
Oddometer: 746
The mixture screw is ok, but what I was thinking is the idle jet, the jet that passes fuel into the air flow at idle....
Maybe Laramie could chime in and explain thing better than me.
M.
Old 11-14-2010, 11:31 AM   #1162
Zecatfish
XTique Rider
Zecatfish's Avatar
Oddometer: 7,927
Rear Fender?
I've got an LED taillight on the LC4E and the oem tail light lens is MIA, and the OEM fender is rough too.
So is there a KTM rear fender that will fit the Enduro without a Taillight?
I plan on ordering all new plastic also. 10 years has left the parts faded and looking like crap anyway.
TT, I could use those green parts now.
Old 11-15-2010, 02:40 PM   #1163
Zecatfish
XTique Rider
Zecatfish's Avatar
Oddometer: 7,927
Caution....
Hey guys,
I was pulling the impeller cover and just broke a bolt off flush.Seized
So I would suggest everyone go out to their LC4 and pull the bolts one at a time and clean the rust off with the Wire Brush and add some anti-seize to each one.
This is going to be a PITA job now.
Old 11-15-2010, 03:00 PM   #1164
wrk2surf
on the gas or brakes
wrk2surf's Avatar
Oddometer: 6,772
UFO and Cemoto make a fender that has no light..
wrk2surf is offline   Reply With Quote
Old 11-15-2010, 07:11 PM   #1165
rallyelc4
rallyelc4's Avatar
Oddometer: 143
http://cgi.ebay.com.au/UFO-KTM600-SM...item41498d2778
this guy is in the uk but preety cheep and superfast shippping
2004 KTM 640lc4 enduro/rallye cam/FCRRGV rims
came with a sxc comp pipe
rallyelc4 is offline   Reply With Quote
Old 11-15-2010, 07:14 PM   #1166
rallyelc4
rallyelc4's Avatar
Oddometer: 143
Hey guys,
on ythe waterpump??
Old 11-15-2010, 07:24 PM   #1167
Zecatfish
XTique Rider
Zecatfish's Avatar
Oddometer: 7,927
Originally Posted by rallyelc4
on ythe waterpump??
Yes the waterpump.
Old 11-16-2010, 05:20 AM   #1168
NitroAcres
MotoBiggots Suck
NitroAcres's Avatar
Oddometer: 517
Yes the waterpump.
Do you know a really good TIG Welder??
If you do..he can build up whats left of the bolt , weld a nut to that...while it cools spray with PB Blaster...let sit for a few min...back out the broken bolt, have a cold beer..replace the bolt and be happy.
NOTE: I have had to repeat this a few times on the same bolt, but have yet to have one I couldn't get out. Including the rear/top exhaust bolt on a 99 Ultraclassic..that had never been out in it's life and was 2 threads below the surface..it took 5 tries. (engine was still in the bike).
NitroAcres is online now   Reply With Quote
Old 11-18-2010, 09:40 AM   #1169
BRYANDENNY71
BRYANDENNY71's Avatar
Oddometer: 116
Will that.....& the later model side panels fit my '99?
My plastics are faded & I was looking to do an update.
Can you not get that rear fender here in the US??
BRYANDENNY71 is offline   Reply With Quote
Old 11-18-2010, 03:09 PM   #1170
Zecatfish
XTique Rider
Zecatfish's Avatar
Oddometer: 7,927
Rallylc4 thanks for the ebay link.
I think I found it from an etailer.
http://www.btosports.com/p/UFOREARFEND
For $26.99
Let me add one more link.
http://www.denniskirk.com/jsp/produc...=13042#fitment
Zecatfish screwed with this post 11-18-2010 at 03:17 PM
Times are GMT -7.   It's 05:46 AM.
