Old 04-05-2011, 09:17 AM   #1456
gunnerbuck
I.Hopp.
Oddometer: 3,080
Originally Posted by flying_low View Post
Hi,
Anyone here know of anyplace that might be able to supply a new or secondhand motor?
Debating with the cost of repairs (new cylinder, crankshaft, piston, bearing etc etc) .. and asked at a couple of dealers that i have access to (Dubai, Germany and denmark) but am told tht KTM dont supply this engine complete anymore.. and that i have to buy it in parts.
Just wonderong/hoping there might be someone who has some older stock, or other bikes that have been put out to pasture and theres an engine somewherein a back room??
any ideas?
thank you you wonderful people!
Stay safe!
Pretty tough to find any deals on new engines... Ebay has quite a selection of parts if your willing to gamble on used stuff to build a second engine...
640 A x 2
gunnerbuck is offline   Reply With Quote
Old 04-05-2011, 11:49 AM   #1457
cjm1219
cjm1219's Avatar
Oddometer: 92
Hi,
I have a 99 LC4, bought with a few more miles on it than the one yu are talking about. Absolutely brilliant bike for dirt and trail, and maybe a bit f road transfers inbetween, but cannot stress enough how inportant it will be to get that mainshaft bearing checked out. I wish i had asked exactly this question because after putting 4000k on mine, this is what happened, (see link below) and it will cost me half of what the bike cost me to fix.
http://www.facebook.com/album.php?ai...0&l=e6db2514dc
Almost unbelievable how bad it caused damage. Just glad the rear wheel didn't lock up on me completely because i was doing 120km/h at the time ... it jut shut off and rolled to a stop.
Check the mainshaft bearing.... and good luck!
YIKES!
Is there an easy way for me to check if my bearing has been replaced? I have a 2000 lc4e with 7800 miles that i bought used a few months ago with very little maintance history. It runs like a champ. It seems like people that have had issues with the bearing they have them with much less miles than I have on mine.
Can I take off the left side cover when i do my next oil change and see it? I am not a mechanical expert but am learning.
cjm1219 is offline   Reply With Quote
Old 04-05-2011, 12:21 PM   #1458
Bushmaster271
BigSky Adventurer
Bushmaster271's Avatar
Oddometer: 25
Thanks guys for the info. Yes it was the one on the mt craigslist but he hasn't replied to any of my messages so I don't think I'll be getting it. He probably already sold it.
Bushmaster271 is offline   Reply With Quote
Old 04-05-2011, 06:25 PM   #1459
mxchamp
Registered Lurker
mxchamp's Avatar
Location: The corn state,11 curves in 318 miles (Iafalls IA)
Oddometer: 1,193
Send a message via MSN to mxchamp Send a message via Skype™ to mxchamp
Talking
Originally Posted by cjm1219 View Post
YIKES!
Take off clutch cover.
Take off clutch. There she is.
I have a puller if you need to borrow one to do the job.
Ride safe!!!!
J
There are 3 kinds of people in this world:
Those that make it happen-
Those that watch it happen-
And those that stand around sayin---WHAT HAPPENED?
2001 KTM 640 Adventure R (back home in my garage with a fresh brand new engine! She is purring like a kitten!
2002 KTM 520 EXC (plated)
BMW MOA #137435
mxchamp is offline   Reply With Quote
Old 04-05-2011, 06:30 PM   #1460
WVhillbilly
WVhillbilly's Avatar
Oddometer: 4,566
I've never changed mine, LC4 400 with 6400 miles. Bought it new with .7 miles on it.
Reckon I should.
WVhillbilly is offline   Reply With Quote
Old 04-06-2011, 03:38 PM   #1461
thechickencow
Oddometer: 470
Hey guys-
I could use a pointer in the right direction. I just can't seem to find what I'm looking for.
03 640 adventure-
My issue is I've got a choke that's stuck. I've taken apart the actual lever and that's not it, the cable does not seem to freely move in/out of the carb. It is not stuck in the on position, it won't come on. Any pointers or tips?
I haven't done anything to the carb, it's stock, about 9k miles.
'03 ktm 640a
thechickencow is offline   Reply With Quote
Old 04-06-2011, 04:59 PM   #1462
clintnz
Trans-Global Chook Chaser
clintnz's Avatar
Oddometer: 2,699
Originally Posted by thechickencow View Post
Hey guys-
03 640 adventure-
Take the cable off at the carb end & find out if it's a stuck cable, or if the piston on the end of the cable is stuck in it's bore in the carb. They are a fiddly fucker to remove, be careful not to wreck the plastic nut.
Cheers
Clint
'03 KTM 640 LC4 Enduro
The wilderness, the desert - why are they not crowded
.................................................. .....with pilgrims?
clintnz is online now   Reply With Quote
Old 04-06-2011, 05:03 PM   #1463
thechickencow
Oddometer: 470
Cheers
Clint
I think I did this - when I had the lever apart I was able to pull back the cable housing from the carb, the cable does not appear to pull through at all or push, it's like it's seized in there.
If that's the case, do I need to remove the whole carb and clean it out where the choke is?
'03 ktm 640a
Old 04-06-2011, 07:32 PM   #1464
clintnz
clintnz's Avatar
Oddometer: 2,699
You are in the index thread, go to p1, look up Laramie's guide to the BST carb for details & pics.
It's not an actual choke but an enrichener valve - the lil piston may be stuck in the bore, it might just need to be pulled out & cleaned up with some scotchbrite, this can be done with the carb in the bike.
Cheers
Clint
Old 04-07-2011, 09:23 AM   #1465
thechickencow
Oddometer: 470
Thanks for the help, I feel dumb but don't know how I missed it.
'03 ktm 640a
Old 04-08-2011, 05:25 AM   #1466
meat popsicle OP
Ignostic
meat popsicle's Avatar
Oddometer: 13,843
Right at the top of P1 but don't feel bad, Laramie was back here promoting it so many must miss it too.
I think I should have called this thread a "Table of Contents" instead of an index thread, so people would have looked for the ToC at the beginning.
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 04-08-2011, 08:06 AM   #1467
roger K
roger K's Avatar
Oddometer: 9
Looking for a parts list for a 99 LC4 640 SM. I Need to find out what bulb the headlight takes. But on another note I would like to see if I can find some other things outside of going to the dealer every time.
Thanks,
Roger
roger K is offline   Reply With Quote
Old 04-08-2011, 12:22 PM   #1468
SpencerCompton
The DingDandKid
SpencerCompton's Avatar
Oddometer: 1,565
Send a message via AIM to SpencerCompton Send a message via MSN to SpencerCompton Send a message via Skype™ to SpencerCompton
Thanks,
Roger
Fill out your location so we can give more accurate device
Anyways, if your in the U.S. I would call munnracing or mikescyclektm.com I've ordered from each of these locations while doing my lc4e rebuild with great success.
2006 TW200 85mpg
1981 Honda CM400T
How about some camping in Pennsylvania?
How am I supposed to think out of the box; if they don't let me out of the box?
SpencerCompton is offline   Reply With Quote
Old 04-08-2011, 07:19 PM   #1469
roger K
roger K's Avatar
Oddometer: 9
Originally Posted by Low594 View Post
I got that one too! Its not totally complete, but i've never seen one that was! I have an extra of the '99 supplement, if someone needs it!
I have a 99 Supermoto, I would be happy to take that off your hands sir.
Old 04-08-2011, 07:31 PM   #1470
roger K
roger K's Avatar
Oddometer: 9
Done
Times are GMT -7.   It's 04:49 AM.
