Old 03-11-2013, 09:10 AM   #1
BikeMan OP
smoke, drink, screw, ride
BikeMan's Avatar
Oddometer: 304
Thumb 2005 V-Strom DL1 100k write up
other than regular maintenance and replacement of normal wear items such as tires, brake pads, chain & sprockets, battery, the bike runs perfect and has never let me down.. at 100k miles I'm knocking out a yearly average of 46 mpg. (see fuelly link below) and the inside of the air box is clean & dry. in addition, I'm still running original stock bearings, suspension, brake rotors, fuel pump & filter, clutch & basket, and a 07 pure stock ECU. i give this bike a grade of A+ .. undoubtedly the best bike ive ever owned. IMHO, i contribute my good luck to,
1. the OverDrive Trannie, for 30% less wear & tear on engine.
2. the use of mc specific motor oil.
3. use of regular automotive grade fuel with the highest AKI rating.
4. street use only. no dirt or trails.
fuelly: http://www.fuelly.com/driver/jbw/dl1000[/FONT]
BikeMan is offline   Reply With Quote
Old 03-11-2013, 04:36 PM   #2
KLR771
Oddometer: 68
100,000 miles ! Thats Awesome ! I got a 2012 with only 1,200 miles so far .
KLR771 is offline   Reply With Quote
Old 03-12-2013, 12:11 AM   #3
EVLED
EVLED's Avatar
Oddometer: 629
Looking forward to the 200k write-up!
EVLED is offline   Reply With Quote
Old 03-12-2013, 05:12 PM   #4
SStiffler
Oddometer: 250
Congratulations! What do you mean by the overdrive tranny? A change in the countershaft sprocket?
"If you have to worry about the risk, you're dead already." Paul Newman
SStiffler is offline   Reply With Quote
Old 03-12-2013, 05:21 PM   #5
Superstar
Superstar's Avatar
Oddometer: 500
So BORING!!!!!!
(I kid, I owned 2 DL1000's...great bang-for-the-buck bike).
Superstar is offline   Reply With Quote
Old 03-12-2013, 06:08 PM   #6
D.T.
Difficult but useful
D.T.'s Avatar
Oddometer: 11,918
I hear at 199,999 you can bring the ODO in for a new one @ no charge?
50k on my SV.
Originally posted by burgerking So?
Holland is about the most expensive country in Europe when it comes to bikes and fuel..Stop whining and go riding It's just money and you only live once...
D.T. is online now   Reply With Quote
Old 03-13-2013, 07:32 AM   #7
BikeMan OP
BikeMan's Avatar
Oddometer: 304
No.. 5th.gear is high gear, 6th.gear is a overdrive.
Old 03-13-2013, 09:26 AM   #8
SStiffler
Oddometer: 250
I was curious about what you meant with overdrive. I bought an 2007 Wee in late October. The previous owner installed a 16 tooth front sprocket. When I did get to ride it before winter, it seemed to be gear plenty high as I would rarely get out of 4th gear riding back roads.
I switch the sprocket back to stock over the weekend but have not had a chance to ride the bike.
Looking forward to spring. Will this winter ever end?
Old 03-13-2013, 01:12 PM   #9
precarious
precarious's Avatar
Oddometer: 558
Mine had 96k when i totalled it. Replaced wheel bearings once, set valve clearances twice, and had an annoying issue with the throttle body sync for a couple months. Otherwise, it was so reliable it was boring. I think i need another one. RIP, Strom....
Awesome bikes. Happy motoring
precarious is offline   Reply With Quote
Old 05-01-2013, 06:19 PM   #10
markcap
markcap's Avatar
Oddometer: 362
The '05 DL1000 only had 5 gears? It never had a 6th gear. What are you referring to?
Cap
'07 DL650
Lehigh Valley, PA
markcap is offline   Reply With Quote
Old 05-02-2013, 01:34 AM   #11
Pecha72
Oddometer: 4,430
DL1000 has 6 gears.
Pecha72 is online now   Reply With Quote
Old 05-02-2013, 09:24 AM   #12
whipit1k
Oddometer: 313
I also have an 05 DL1000. Only 75k on my bike. I cant see replacing it any time soon. It was dirt cheap, is pretty damn good at everything I ask it to do, very reliable. I suppose I could go out and pay $10000 more for a bike I may enjoy 10% more than the vstrom...but that would not be too bright given my financial situation. This thing is a no brainer for anyone on a budget. Have you seen what used DL1000's go for these days? Unreal value
whipit1k is offline   Reply With Quote
Old 05-02-2013, 11:00 AM   #13
CalicoJack
Oddometer: 238
Mine Does.....
Only 2 things are keeping me from going pro: Skill & Luck
CalicoJack is offline   Reply With Quote
Old 05-02-2013, 11:12 AM   #14
svs
All Hands on Deck!
svs's Avatar
Oddometer: 25,371
That's it right there.
If a physical fact can produce a psychological state, a psychological state can produce a physical fact... The whole of creation is asleep within the deep of man and is awakened to objective existence by his subconscious assumptions.
svs is offline   Reply With Quote
Old 05-02-2013, 01:52 PM   #15
DSM8
Where fun goes to die....
DSM8's Avatar
Oddometer: 4,072
I have an 07 DL650 with 110K on the odo.
Exact same story, gas, tires, chain, filters, oil, pads.
That's it.
Still doesn't use enough oil between 5K mile changes to have to add any and still gets 55mpg.
Want a new bike but cant justify selling this one, it just plain works.
DSM8 - A different kind of mean
SQL > SELECT finger FROM hand WHERE id=3
http://share.findmespot.com/shared/f...d5LbKWMz6cHxaH
DSM8 is offline   Reply With Quote
Times are GMT -7.   It's 04:33 AM.
