Old 05-31-2013, 02:31 PM   #61
Gryphon12
Gryphon12's Avatar
Oddometer: 1,326
I agree. And while the Duke 390, EX300R and CBR250 aren't what we want, they demonstrate that today's economies and the demand of a world market for 250-400cc bikes just might get us there, eventually.
[400cc bikes sell in Australia, and the Chinese and Indian economies are growing stronger. You will see them in Hong Kong long before we see them in the USA, however.]
1990 Honda NT-650 Hawk-GT
Never doubt that a small group of thoughtful, committed citizens can change the world;
indeed, it's the only thing that ever has. - Margaret Mead
Gryphon12 is offline   Reply With Quote
Old 05-31-2013, 02:38 PM   #62
Kennon OP
Kennon's Avatar
Oddometer: 286
true but they only sell in other countries if they are old stock unsold or happen to fit in the markets requirements the Kawasaki Ninja 400R/ER4F was sold in Canada briefly as the insurance was just right for the capacity, what I would lvoe is Aprilia to get into the Superstock market with a 600CC V-twin in a beautiful Italian frame, they're going to make a 250 most likely a V-twin to compete in the the future 250cc WSBK class.
Kennon
2009 Yamaha Jog 50RR LC sold 2011
2011 Rieju Marathon Pro 125 SM sold 2013
1990 Honda VFR 400 NC30 purchased 2013
Kennon is offline   Reply With Quote
Old 05-31-2013, 04:20 PM   #63
Gryphon12
Gryphon12's Avatar
Oddometer: 1,326
And KTM is supposedly making a Moto3 version of their 373cc 390, for similar reasons. Just have to wait and see.
I'm not stuck on any one design, but in a smaller, lighter, nimble bike, I still want as broad a power (torque) band as possible. The V4 was better than the I4, same with a triple. I won't turn down the right twin or thumper as long as the chassis and components are all top shelf. Unfortunately, I'm in a very small minority.
Old 05-31-2013, 04:24 PM   #64
Kennon OP
Kennon's Avatar
Oddometer: 286
Thumpers and twins are something special when made to be as powerful as they can be, I do believe you learn more on a single as if your not carefeul the way it thuds can off you if your too soon on the power one day I would love to own a CBR 250RR the old inline 4 that revved to 20,000RPM a CBR400RR NC29 and hopefully stilll own my NC30 with its engine abit more heated up.
Kennon
Old 06-12-2013, 06:03 PM   #65
Kennon OP
Kennon's Avatar
Oddometer: 286
Alright back on focus now should hopefully start working next week to put some well needed cash injection into my NC30, have contacted a guy about stainless steel collars as the mild steel collars on the NC30 SS system always rust away so will need four, two for the original standard system to store away in the garage and another two for my standard cut system, jets will be ordered soon and will give a good day to taking apart fitting the jets and rebuilding the carbs to suit the exhaust properly, since i'll be working in various locations I'll get more miles closer to changing the wheels over and the oil change scheduled mileage.
Kennon
Old 07-03-2013, 10:59 AM   #66
Kennon OP
Kennon's Avatar
Oddometer: 286
nothing much has happened to my bike recently just clocking up more km on the bike starting to square off the tyre now riding to and from oxford on motorways need to find some bends on the weekend to round then out again found a good website for guys in the US if your keen for a 400 Kawasaki ZXR 400's, Suzuki GSXR 400's, Honda CBR/VFR/RVF 400's and a array of 2 stroke 250's
http://exoticrarebikes.com/bikes-in-stock.html
Kennon
Old 07-12-2013, 10:10 AM   #67
Kennon OP
Kennon's Avatar
Oddometer: 286
sorry about not doing much at all trying to find a summer job is becoming allot trickier than I thought it would be but I'm getting round to changing out the exhaust now I found out one of the previous owners was stupid enough to weld the front down pipes solid to the rear down pipes so now I'm having to remove the whole system then having to cut the welds and fix it properly a welded up exhaust is only worth 100 when a properly sorted out original with SS joint collars is worth 900 but it has forced me to change to my more freer flowing exhaust in but god is it messy probably hasn't been done in over 10 years the heat guard I thought only had abit of surface corrosion the other side is a whole other story used a metal brilo pad to clean her up put will just put a clear coat over it and put it in the garage waiting to get payment details to get a carbon fibre heat shield no need to worry about corrosion there.
Kennon
Old 07-13-2013, 03:02 PM   #68
Kennon OP
Kennon's Avatar
Oddometer: 286
Finally got the exhaust off took allot of effort and swearing to pivot enough to get her off the bike, don't think the down pipes have ever been off managed to get the far side nuts and studs out okay the near side another story the nut was on so tight it snapped the studs thankfully have at least 10mm poking out enough to get some leverage or use a stud remover using plenty of WD40 tonight to loosen her up then use a jet lighter to heat the surroundings tomorrow have a set of new studs and nuts ordered having to source nuts that will fit the rear manifold as mine have corroded so badly that the 12mm socket couldn't be used had to force a 11mm on and managed to get them off slowly but surely little V4's are a pain to work on here she stands currently have loosely fitted the rear manifold, silencer and the right side front down pipe left the other off to remove the snapped studs tomorrow thankfully got a guy popping over with the tools to give a helping hand.
here's the silencer its a bit longer and wider than the stock but it is straight through.
Kennon
Old 07-15-2013, 02:22 PM   #69
Kennon OP
Kennon's Avatar
Oddometer: 286
even with a stud extractor, mole grips and heating still couldn't get the studs out having to get it booked in to have the studs drilled out, hopefully without damaging the studs, once its free to have new studs put in I'm making my own studs with a titanium threaded bar I was given and SS nuts and washers to replace the original steel ones.
Kennon
Old 07-22-2013, 08:02 AM   #70
Kennon OP
Kennon's Avatar
Oddometer: 286
a quick update still waiting to have my bike picked up to have the studs drilled out should be picked up on thursday morning, until then I have the Candy green Kawasaki "ER-6F" aka Ninja 650R to ride about on in the good weather.
have had genuine honda studs and nuts arrive will probably not use these and jsut use them as reference to make my own better quality ones i'm sure they last well if not left on the bike 23 years but would rather use my titanium threaded bar.
also have had my Carbon heat shield arrive this morning its smaller than the original and only mounts to the foot pegs not the frame but she will do a good job and look better in doing so I cleaned up the metal heat shield as it had some surface rust. I bought it off another NC30 owner, won't fit it until the bike is back together but here are some pictures of it fitted to a type 1
Kennon
Kennon screwed with this post 07-22-2013 at 09:47 AM
Old 07-27-2013, 04:12 PM   #71
Kennon OP
Kennon's Avatar
Oddometer: 286
Got my bike back this evening was working so haven't started to put her back together a early morning and hopefully she will be running well by early afternoon.
Kennon
Old 07-28-2013, 07:34 AM   #72
Kennon OP
Kennon's Avatar
Oddometer: 286
got the Rads buttoned up but don't have enough coolant to fill the rads fully so only did a brief start up to hear her purr a pure honda V4 bark now
as she stands for now:
Kennon
Old 07-30-2013, 02:26 PM   #73
Kennon OP
Kennon's Avatar
Oddometer: 286
only a small thing to sort now having one side light out and the other very dim new LED ones should arrive tomorrow or thursday, have her running and sorted the cooling out now she sounds super loud at low revvs and cools properly, did a run up to 130 mark then barked off to enter a town to about 30ish mph normally the temp would bang straight up past 90 degrees towards the red H mark but now she went from 70ish to 80ish and never went up very happy rider now, have missed the small sports bike handling and with the exhaust she has more shove to her, will get a proper clean picture of her all buttoned up tomorrow.
Kennon
Old 08-01-2013, 10:08 AM   #74
Kennon OP
Kennon's Avatar
Oddometer: 286
ordered the wrong side lights but thankfully got refunded and don't even have to return them win win there got a official set making there way from Japan as well as a set of Yamamoto exhaust decal as my ART one is so faded at a distance it looks like its none existent.
Kennon
Old 11-22-2013, 05:08 AM   #75
Kennon OP
Kennon's Avatar
Oddometer: 286
sorry for not updating for a while been pretty much flat out busy with university and work and the bike is still at my parents have bought new parts though a type 2 nose cone and RHS mid piece to tidy up when I return home for 5 days over Christmas, a new clutch cable, new alloy race clip ons as my left one is bent abit, a new chain adjuster hub in mint condition now thinking of getting a pro bolt set of fairing bolts so I have a matching set as mine are mismatched and some are missing but a new fairing set will be bought next year to tidy her up properly will upload some pictures later of my bits and pieces
Kennon
Times are GMT -7.   It's 02:12 AM.
