03-16-2013, 09:43 PM
#16 |
Sleep, Wrench, Ride
Oddometer: 4,513
If you've been thinking about building a custom bike, it's a great idea to start with a free bike. That way if you get into it an decide it's not for you, you haven't lost a lot of money. Just make sure you get a title before you put any effort into the bike.
Here's my free '86 Honda Rebel 450 (Before): ![]() After - This was my first custom bike build. It took years. I sold it for $2200 and probably had less than $1000 in parts into it. ![]() Here's a $400 bike I got from the pawn shop: ![]() This build took a little less than a year. It's worth a more now than a mint version of the stock bike would be worth. ![]() Here's a $400 '75 CB400F that I bought last fall: ![]() ![]() Here's what it looked like a month later (I've had a lot of bike building experience since that Rebel). I sold this one for $2500.
Bikes: DR350 | GR650 Street Tracker | NX650 Turbo | Catamount Cycles Events: 2013 Monkey-Butt 500 | BreckTrek 2013 |
03-17-2013, 02:27 PM
#17 |
old school
Oddometer: 1,082
Now add your cost up for those builds and include labor costs. As with most builds, labor costs will easily and often far exceed parts/supplies.
Nice job on those bikes, BTW.
A good bike mechanic only needs two tools, WD40 and duct tape. If it doesn't move, but should, use the WD40. If it does move but shouldn't use the duct tape. ![]() http://www.facebook.com/pages/Checke...22319847810910 |
03-17-2013, 06:29 PM
#18 | |
Sleep, Wrench, Ride
Oddometer: 4,513
That last one I made $30/hr which was a goal I was trying to hit, but on the first 5 or 6 bikes I built/restored I probably made $3/hr. I'm just trying to tell the OP that if he wants to know what it's like to build a custom bike, a free bike is the right one to start with. Happy St. Patty's Day!
03-24-2013, 03:38 PM
#19 | |
Dave E.
Oddometer: 470
Generally speaking, the "L" series Suzukis (or Honda Customs, Kawasaki LTDs, Yamaha Maxims, etc.) more lend themselves to a bobber mod than cafe due to the small rear wheels, stepped seats, long forks and forward-mounted front axles. |
03-24-2013, 04:30 PM
#20 |
bikaholic
Oddometer: 1,540
The smaller Suzook inline 4s had plain bearing cranks.
03-25-2013, 08:40 PM
#21 |
Oddometer: 8
The guy says case bearings then says crank bearings. I have the bike now it runs but is kinda doggy when you crack the throttle. and for some reason RPMs just around at idle a little bit. one second they will be low almost low enough to stall out then they jump up pretty good i dont know i have not had time to get into it yet with work and all. im just going to keep it all original for now get all the kinks worked out and ride it for the season back and forth to work then in the winter i will dig into it.
03-25-2013, 09:07 PM
#22 |
Oddometer: 10,722
The crank bearings are in the cases.
The hessitation could come from a number of things. Gummed up carbs, intake leaks, out of tolerance valves, etc.
I am a conservative, not a Republican. There is a difference. |
03-28-2013, 06:57 PM
#23 | |
Oddometer: 41
