Old 09-05-2013, 02:13 PM   #241
EastSideSM
Isn't that dangerous?
Oddometer: 1,490
Originally Posted by Sporting Wood View Post
I have plenty of plates but the new 990 kit orders have stripped me clean of filters. I have more coming in next week, so that'd be a quick as I could ship. Could send it out the same day I receive them.
I do however have the domed version of the filter for the SuperEnduros that would fit but its more$ and you'd have to cut down your velocity stacks to fit it. Probably best to wait, sorry.
Not a problem as i am not in a hurry. i can check in next week. I would prefer to run the "regular" version so as not to have to cut my stacks, etc. Thanks for the quick reply! Your setup looks really good.
EastSideSM: '06 950SM Black
EastSideSM is offline   Reply With Quote
Old 09-13-2013, 08:04 PM   #242
gaspipe
Wandering Soul
gaspipe's Avatar
Oddometer: 11,352
Thanks, SW. Nice kit, well done.
Are you going to offer a kick start kit for the LC8?
gaspipe [the original]
Hair of the dog....
gaspipe screwed with this post 09-13-2013 at 08:13 PM
gaspipe is offline   Reply With Quote
Old 09-14-2013, 06:56 AM   #243
Sporting Wood OP
I <3 Energizer Bunny
Sporting Wood's Avatar
Oddometer: 896
950 kits back in stock. Get'em while they're hot.
More 990 kits are in the works.
Sporting Wood is offline   Reply With Quote
Old 09-14-2013, 06:57 AM   #244
Sporting Wood OP
Oddometer: 896
Thanks GP. Hope you enjoy it!
Old 09-14-2013, 11:55 AM   #245
DirtJack
DirtJack's Avatar
Oddometer: 1,580
Just had surgery on the leg, I'll have to pass on the kick start.
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2014 KTM 1190 Adventure R
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack is offline   Reply With Quote
Old 09-16-2013, 12:07 PM   #246
gaspipe
Wandering Soul
gaspipe's Avatar
Oddometer: 11,352
Hair of the dog....
Old 09-20-2013, 07:45 PM   #247
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,331
Thanks for the great deal and looking out for me Chris!! Another Happy Customer!!
Bike runs fantastic with your baseline recommended jetting, runs better than it ever has!
2012 KTM 990 Adventure
Chuckracer is offline   Reply With Quote
Old 09-21-2013, 07:41 AM   #248
Sporting Wood OP
Oddometer: 896
Great Chuck!
It took over a hundred jetting combos to get to that Holy Grail combo. Huge pleasure to know its working out for you.
Old 09-21-2013, 03:26 PM   #249
ultrachrome
Poser
Oddometer: 274
I'm in the middle of installing this on my 990 SMT and have a couple of questions.
The plate with grommets goes right on the throttle bodies and the velocity stacks hold it in place, correct? Any grease at this junction advised?
Regarding the crankcase breather, why wouldn't I remove that last length of hose and fasten the breather filter directly to the check valve?
ultrachrome is offline   Reply With Quote
Old 09-21-2013, 03:33 PM   #250
Sporting Wood OP
Oddometer: 896
On the SMT, no biggie with breather height. ADV and SE hitting high water would want it high. I'm partial to running a line from the pcv valve to above the countershaft. I'm working of finding just the right tubing to include with the next batch of kits...to make it complete.
A little grease is recommended at the mounting surface and where the velocity stacks clamp. Also put a thin bead around the filter seal. Enjoy! Let me know how it works out!
Old 09-21-2013, 08:24 PM   #251
ultrachrome
Poser
Oddometer: 274
On the SMT, attaching the breather filter to the pcv valve puts it at pretty much the same height as the adapter plate.
Old 09-22-2013, 05:48 AM   #252
Sporting Wood OP
Oddometer: 896
True.
Old 09-22-2013, 07:58 PM   #253
chatleyg
Oddometer: 11
Great Chuck!
What is the Holy Grail combo? I am at 100 ft, cannister and SAS removed with Wings and db killers?
TIA
Chatleyg
chatleyg is offline   Reply With Quote
Old 09-24-2013, 08:29 PM   #254
DirtJack
DirtJack's Avatar
Oddometer: 1,580
SportingWood 990 Filter Installation
I'm supposed to be taking it easy due to a medical issue, but SportingWood's air filter has been sitting there for 2 weeks and my Dr. doesn't read AdvRider, so out to the garage.
Off with these bits (easy to do, but sometimes not so easy to get back on, but in my case no problem since I have studs for the crash bars and thru bolts for the lower tank mounts).
Next, the tanks need to come off (need an oil change? now's the time). I have an oil drain tube, so I'll do that another time.
Now that the tanks are off your bike might look like:
Next you need to remove the snorkel (if you have one) and the air box top, crankcase breather and ambient air temperature sensor (I unscrewed the sensor since you need to install it on the air cleaner base later) giving you something like:
You also have to remove the velocity stacks and paper air filter. You will use the velocity stacks to hold the new filter base plate on later.
Now you have some fiddly issues to deal with. Take off the air box side covers, loosen the fuel line from the FI fuel rail and release the FI electrical connector on the right side of the frame. This one is always a bitch on my bike. I have to move my second fan and shroud and the radiator catch bottle to loosen the connector.
Next loosen the top hose clamp holding both throttle bodies and lift them up and out of the way. I zip tie them to the handlebars. You don't have to disconnect the throttle cables.
Then you should loosen the bottom clamp for each throttle body boot and remove the boots. Finally, lift the air box bottom up off the intake tubes and your bike might look like:
(Need to check valve clearance? Now's maybe the time. Loosen the radiator mounts and oil tank moving those forward for additional room for the front cylinder.)
Next you can reinstall the throttle body boots, tightening the bottom clamps.
Now you can lower the throttle body assembly back onto the boots and tighten the top clamps. I oriented the clamps so all connections could be accessed from the same side, but this is not necessary since we are not working through a air box side hole anymore. This is also a good time to check/adjust the throttle cables. Keener pointed out that these should be pointed to the rear so you can remove the carbs/throttle bodies without taking off the tanks. Great idea Keener.
Now you are almost ready for the SW's neat stuff. First install the ambient air temperature sensor in the filter base plate using the supplied hardware. You can now slip the base over the throttle bodies. Note that the Dzus connectors should be on the right and the temp sensor towards the front. The
velocity stacks are used to hold the base plate in place and compress SW's neat rubber rings giving a tight seal and firm attachment of the base plate.
Now you should oil up the filter (I use NoToil, but they say not to use NoToil cleaner - I usually use dish soap or laundry detergent when cleaning my other foam filters) and put a heavy ring of filter oil or grease around the edge of the base plate to insure proper seal. After the filter is in place it might look like:
I used a UNI UP-124 filter on the crankcase breather and zipped it to the frame.
I wanted to check the clearance between the seat bottom and the rear edge of the filter.
It's close, but the seat does not compress the filter top. Now put the tanks, and plastic bits and crash bars back on and ride. I need to find a source for filter skins to use on longer rides in dusty conditions.
I had already done the canister removal and SAS removal. If you have not done that, then you need to either do that or deal with where you will mount the SAS plumbing which used to be attached to the rear of the air box.
My bike has Wings cans with small size spark arrestors/DB reducers. Before installing the air filter, I ran the stock 2007 map and the bike ran well but border line lean giving around 44 MPG when running on pavement at speed. It will need another map to accommodate the new air filter. In a later post I will give some details of what I plan to do with TuneECU.
2008 KTM 690 Enduro
DirtJack screwed with this post 09-30-2013 at 07:29 AM
Old 09-24-2013, 09:14 PM   #255
renogeorge
Oddometer: 1,382
I just installed mine today.
What a great upgrade! I have fought the stock air box on my 950 and 990 and have the skinned knuckles to prove it! This setup really opens things up and provides MUCH easier access for jetting, plug change and valve adjustment. And the weight reduction is always a good thing.
As 50 year dirt bike guy, I am more than comfortable with the foam filter. Beats $40 for a paper filter from KTM!
It runs pretty darn well as is. But I am going to tune with Tune ECU tomorrow. Looking forward to seeing what it will do!
FWIW
KTMs--300, 518, 990
renogeorge is offline   Reply With Quote
Times are GMT -7.   It's 07:04 AM.
