Old 04-15-2013, 09:31 AM   #61
SpeedyR
SE in the SE
Oddometer: 870
just wanted to post so i can keep up with the jetting. looking forward to getting the filter for my SE.
SpeedyR is offline   Reply With Quote
Old 04-15-2013, 02:16 PM   #62
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,925
What air filter suits the 950 Adv?
The ITG JC30/65 "angular" fits, or do you suggest the sausage type? And is the trumpet cutting necessary?
Cheers.
gefr is online now   Reply With Quote
Old 04-15-2013, 02:28 PM   #63
Sporting Wood OP
I <3 Energizer Bunny
Sporting Wood's Avatar
Oddometer: 896
Cheers.
Standard oval or "angular" fits fine with no modifications on ADV and SM. Its only the SE or SM-R that require the sausage or domed version and need their intake velocity stacks trimmed. Either work well.
Sporting Wood is offline   Reply With Quote
Old 04-16-2013, 03:29 PM   #64
gaspipe
Wandering Soul
gaspipe's Avatar
Oddometer: 11,352
I'm in. Tired of wresslin' that damned airbox too.
gaspipe [the original]
Hair of the dog....
gaspipe is offline   Reply With Quote
Old 04-16-2013, 04:38 PM   #65
vwboomer
Buffoon
vwboomer's Avatar
Oddometer: 10,269
Got the filter set up today. Thanks
In all actuality I will probably wait a week or two to get it on. working lots of hours and feebly attempting to do a bath remodel at the same time
I doubt I have stock jets, so will wait until I pull it apart to order any. Probably use a set of 42 pilots until after the trip, the 45's after for more power/screw economy. I normally got 35mpg with the current set up - can't be much worse than that.
So you're generally not running a richer jet on the rear cylinder? Thought normally it was a little richer due to the heat......
vwboomer is offline   Reply With Quote
Old 04-16-2013, 05:49 PM   #66
Sporting Wood OP
Oddometer: 896
Old 04-16-2013, 06:20 PM   #67
Meathead
tin man
Meathead's Avatar
Oddometer: 16,659
Meathead is offline   Reply With Quote
Old 04-16-2013, 08:54 PM   #68
Thumper996
Thumper996's Avatar
Oddometer: 592
Look what showed up today, weekend project forth coming. Luckily i already have most everything already off the bike from recent valve check.
Thumper996 is offline   Reply With Quote
Old 04-17-2013, 08:41 AM   #69
Sporting Wood OP
Oddometer: 896
Nope, I run the same mains though I'm in the minority. Most everyone goes one or two up on the rear. Intake runs are unequal and there is an argument for heat in the rear...though the motor is water cooled.
35 isn't too bad if you're spanking it. Leisurely touring and yeah, not so great. This is more often than not caused by too high a float height. I bet its set at the factory 3mm? Guys generally bump the jets and raise the needle making it very rich through the bottom end. Let us know what you find when you dig into it...and good luck with the bath remodel.
Old 04-17-2013, 03:11 PM   #70
blublapp
Oddometer: 19
So guys here are the facts:
Look at the dyno graphs! I'm really impressed!
My jetting is: (Engine 990 SM '08)
175 mains
FP needle #2
Floatlevel 4mm
Screws at 2
Rest standard!
120.4 hp on the clutch
109.9 Nm torque on clutch
112.2 rwhp
104.6 Nm rw-torque
damn I'm not able to fit in the graphs.
Chris, please put it in. I've sendet them on mail to you...
blublapp is offline   Reply With Quote
Old 04-17-2013, 03:24 PM   #71
blublapp
Oddometer: 19
Torque in ft-lbs is: 81.06
for those who don't know Nm (Newtonmeters?
Old 04-17-2013, 04:00 PM   #72
Sporting Wood OP
Oddometer: 896
175 mains
FP needle #2
Floatlevel 4mm
Screws at 2
Rest standard!
112.2 rwhp
104.6 Nm rw-torque
This is a beautiful raw rear wheel dyno.
Sporting Wood screwed with this post 04-18-2013 at 07:21 AM Reason: Pic changed and incorrect comment removed
Old 04-17-2013, 05:14 PM   #73
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,925
175 mains
FP needle #2
Floatlevel 4mm
Screws at 2
Rest standard!
Great power output! How about your milliage?
Cheers.
Old 04-17-2013, 09:04 PM   #74
avocadofarmer
Fruit Coot
Oddometer: 267
Got mine today, looks great! Thanks for setting this all up Sporting Wood!
Hopefully nothing bad will happen with my stock exhausts...we'll see.
avocadofarmer is offline   Reply With Quote
Old 04-17-2013, 10:53 PM   #75
blublapp
Oddometer: 19
About the mileage I'm pretty happy.
Got 6.3l/100km, this is about 37,4mpg...
Was a 280km ride with highway, towns and and lots of speed
About the third clip: Think this will lower my mileage... I thougt about 0.5 more on the screws, I have a longer choke time now.
And next time I'm at the carbs I'll put my powerblades in
Times are GMT -7.   It's 04:52 PM.
