Thread Tools Search this Thread Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 03-14-2013, 08:16 PM   #1
gtj OP
Oddometer: 30
Sena SMH10 and Garmin Montana 650
Anyone using the Sena SMH10 and a Garmin Montana 650 together successfully?
I have a Scala Rider G9, but it interferes with the GPS satellite reception to the point that it makes it unusable.
http://advrider.com/forums/showthread.php?t=861427
gtj is offline   Reply With Quote
Old 03-14-2013, 08:39 PM   #2
bighopper
Oddometer: 190
I am using a Sena SMH10R with SM10 which is connected to the Montana via the rugged mount audio out. The SM10 mutes when directions are given of where to go. I have no issues at all with interference.
I Just Like To Ride
'03 BMW R1150GSA
'06 BMW K1200LT
bighopper is offline   Reply With Quote
Old 03-14-2013, 09:28 PM   #3
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,690
I have both a Sena SMH10 and an Interphone F5 that I pair with an iPhone and neither interferes with the sat reception on my Montana.
Old 03-15-2013, 11:40 AM   #4
gtj OP
Oddometer: 30
That's interesting. The Sena instructions state the the GPS navigation would be heard in the background of an intercomm conversation.
From Manual:
A GPS navigation or a radar detector which has headphone jack or audio line-out could be connected to the SR10 by wire. The GPS voice instruction or the radar detector alarm is also heard in the background via SR10 while having an intercom conversation or a phone call. Please refer to the SR10 user's guide for details.
Old 03-15-2013, 05:13 PM   #5
bighopper
Oddometer: 190
From Manual:
I am using the SM1O, which has 2 input ports. 1 is for stereo, & the other is only mono & this one I use the output from the Montana & when directions are spoken the stereo port mutes down so that you can hear the directions. And I will say that it works great.
I Just Like To Ride
'03 BMW R1150GSA
'06 BMW K1200LT
Old 04-10-2013, 07:59 PM   #6
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,693
I just bought an SMH10 and a SM10 to hook up the Montana. I also planned to pair my Droid with the headset.
After lengthy conversations and emails with Sena, it won't work. The SM10 uses A2DP comms as well as the Droid and the SMH10 only will connect to one at a time so you would lose the turn by turn.
They recommended going to the SR10 instead which uses HFP and the headset will recognize voice guidance to mute the radio.
Anyways I need to return the SM10 so hopefully that saves someone else form making the same mistake.
We're not out here to rough it. We're here to smooth it. Things are rough enough in town.
Nessmuk
Old 04-10-2013, 09:07 PM   #7
BlueLghtning
Riding is my passion
BlueLghtning's Avatar
Oddometer: 5,264
Yep, see a lot of people making this mistake. The SMH10 has 2 HFP profiles and 1 A2DP. So if you plan on using the SM10, you can't listen to music from another device BT in like your smart phone.
The Mulit-Point pairing connection is the "2nd" HFP connection and what you'll pair the SR10 still allowing an HFP & A2DP connection for your smart phone.
You technically could plug your droid directly into your SM10 for music, but then you'd lose the ability to talk on the phone and the ability to control your music via the jog dial.
Since voice guidance is fine in mono anyways, the SR10 does make more sense.
Just a word of warning though. Any audio from the SR10 is "mixed" in if you are on an intercom call or phone call, however if you are just listening to music, it gets muted while SR10 audio is being fed in. In places where the GPS is giving frequent directions, sometimes it gets annoying having the music muted so much. I actually put a ticket in with Sena to see if they could add an option to change that, but they said it wasn't possible in the current generation SMH10.
BlueLghtning - Follow me on my SPOT Messenger
Mine: KTM 650 ADV (Katuki), 09 DL650, 08 Husky TE610, 08 WR250R
Hers: 07 Ninja 650R, 13 CRF250L
Smugmug Pics - Save $5 <-- Click Here
BlueLghtning is online now   Reply With Quote
Times are GMT -7.   It's 08:58 PM.
