Old 04-03-2013, 09:01 AM   #31
trc.rhubarb OP
trc.rhubarb's Avatar
Oddometer: 1,991
Didn't think of rolling. I'll have to check my options there. Thanks for the idea!
2007 BMW GS Adventure / 2000 Ducati 900ss / 2010 Harley Ultra Limited / 1975 BMW R90/6 / 2006 DRZ400S
Follow me here
trc.rhubarb is online now   Reply With Quote
Old 04-03-2013, 05:28 PM   #32
ttime4four
ttime4four's Avatar
Oddometer: 259
Can parts / nuts / bolts / tools drop down into the space below when the lift is up? How hard is it to remove the plates and get down to what you dropped?
'14 KTM 690 Enduro R
'14 BMW R nine T
'06 Husaberg FE450e (Oregon Plated)
ttime4four is offline   Reply With Quote
Old 04-03-2013, 10:29 PM   #33
trc.rhubarb OP
Oddometer: 1,991
Yes, yes they can :) I dropped a lot down there last weekend before the plates arrived.
You can reach right under the lift to get whatever you drop or use a magnet on a stick... It's good and bad. Bad that they went under the lift into a pit, good because they are in the pit and not in neverland with the trolls that steal everything that drops in the garage. :)
The plates right now are just sitting in place. I want to figure out a way to pin them but I might just end up using small recessed machine screws to bolt them in. My plan originally accounted for a friction fit figuring that they would be too heavy to move easily. They weigh about 50lbs each at most, so between the light weight and the smooth bottom they can shift when the lift is up.
Although they aren't heavy, they are awkward and do massive damage to anything they touch/graze, so I don't envision taking them off except to service the hydraulics in the event of a failure.
Follow me here
Old 04-04-2013, 06:18 AM   #34
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 52,307
I like Rustoleum. It goes on fairly thick, and dries hard, but doesn't chip easily. I use a short nap 4" roller.
Jim
JimVonBaden is online now   Reply With Quote
Old 04-04-2013, 09:37 AM   #35
bomber60015
Anatomically Correct
bomber60015's Avatar
Oddometer: 12,408
Jim
I, too, have had good luck with Rustoleum in a can . . . .
"Here is your country. Cherish these natural wonders, cherish the natural resources, cherish the history and romance as a sacred heritage, for your children and your children's children. Do not let selfish men or greedy interests skin your country of its beauty, its riches or its romance. T.R.
Old 04-04-2013, 09:56 AM   #36
SloMo228
World Class Cheapass
Oddometer: 1,729
Awesome project. Simple design, good execution, and great efficient use of space. I will have to keep this filed away in the back of my mind...
--------------------------- Steve----------------------------------------
'93 GL1500 frankenbike basketcase in progress
'96 DR350SE
SloMo228 is offline   Reply With Quote
Times are GMT -7.   It's 09:45 PM.
