Old 03-27-2013, 11:57 PM   #76
seetomgo
d00d
seetomgo's Avatar
Oddometer: 32
Originally Posted by Reislust View Post
Had a great time and I look forward to seeing some of the video you shot! Glad you didn't catch my spill
this, despite the bounty that was offered! come on!
2007 Kawasaki KLR650 (fully pimped)
2006 Suzuki DL1000 (being pimped)
2003 Kawasaki ZR7S (for sale)
seetomgo is offline   Reply With Quote
Old 03-28-2013, 12:02 AM   #77
seetomgo
d00d
seetomgo's Avatar
Oddometer: 32
Originally Posted by blaster11 View Post
I'm guessing direct hit to skid plate punching the mounts through the motor....either way it looks expensive!
actually a loose crash bar due to vibrated out screws knocking the cover askew on the head...
Old 03-28-2013, 04:28 AM   #78
Dorito
Dreamer and Doer
Dorito's Avatar
Oddometer: 5,301
What was the final verdict on the broken crash bars:
A) Realign the screws and add oil, no harm no foul
B) The loose bars actually did some damage, but no charge and I got a new ride for the rest of the weekend
C) Wowsers, the BMW parts sure are expensive, and but hey I negotiated the broken part as a wall trophy for the $$$ I spent fixing that one!
BlastOff Adventures
Nothing (ad)ventured, Nothing Gained
Everything you want is on the other side of fear.
Dorito is offline   Reply With Quote
Old 03-28-2013, 04:54 AM   #79
EOD3MC OP
What will break next
EOD3MC's Avatar
Oddometer: 4,777
Oh, there was definate damage, but I didn't hear what the final $$ verdict was...
EOD3MC is offline   Reply With Quote
Old 03-28-2013, 04:02 PM   #80
Reislust
Still alive
Reislust's Avatar
Oddometer: 106
me neither?
Reislust is offline   Reply With Quote
Old 03-28-2013, 04:47 PM   #81
Dorito
Dreamer and Doer
Dorito's Avatar
Oddometer: 5,301
we headed back to the compound for lunch
Any riding after lunch or were you in a food induced coma
BlastOff Adventures
Old 03-28-2013, 05:09 PM   #82
EOD3MC OP
EOD3MC's Avatar
Oddometer: 4,777
almost....the food was that good
Old 03-28-2013, 06:07 PM   #83
Dorito
Dreamer and Doer
Dorito's Avatar
Oddometer: 5,301
I bet those chefs didn't try anything as complicated as hard boiled eggs. Wait, no food porn yet?
BlastOff Adventures
Old 03-28-2013, 06:55 PM   #84
EOD3MC OP
EOD3MC's Avatar
Oddometer: 4,777
After a fantastic lunch, the class gathered up for our after lunch festivities. We started out with a little “get back into it” trail ride. This one included a few more challenges then the previous ones. After looping around the ranch a bit we were back at the hill we left off with before lunch. A couple more times down and we were headed off to a longer, steeper, more rutted down hill.
Using the techniques the coaches had provided with the before lunch drills, the hill was actually pretty easy.
With everyone getting to practice this down hill a few times we reversed course and started our hill climbing exercise. Balanced on the foot pegs, holding the tank with your knees and leaning into the hill…it was a piece of cake even with the street tires. Though it was a steeper and longer incline then we had gone up previously, it was still not what I would call really steep.
The key item of knowledge the coaches made sure we got was the downhill wheel was the one that controlled the braking of the bike. When you were headed downhill, being able to stop the bike on the decent was only possible with good front brake control, often to the point of threshold braking. Quite a few times, the front wheel started skidding on me. By releasing the brake slightly and reapplying kept things under control.
After the hill climbs we were off to the sand pit area…no not to ride the deep sand but to use the flat grassy area near it to do counter weighting drills. Del set out a couple sets of cones in a square about 3 feet across. The object was to circle the cones in as small of a circle as possible by putting your weight over the outside foot peg. To do this you straightened your inside leg and bent the knee on the outside leg. You also moved “Moesha” outboard. “Moesha” was what Del referred to when he wanted you to stick your backside somewhere. Yes, he demonstrated…and yes, every time I hear that name I picture a Del shaking his “Moesha” to emphasize his point .
Once we had a few goes at going around the cones, he moved them a bit farther apart…and had us turn inside the cones. To do that, you pretty much had to keep your handlebars turned to the stops and shift your weight to control the turn. Of course Del thought that was still to easy for us, so he had us do figure eights. The key to staying within the coned off space there was to shift your body position pretty quickly and smoothly. Just to make things interesting after that, they open up the “pen”. The pen was a fenced in area with very tight S-turns. The turns were so tight that if you tried to turn the bike without leaning it way in, you would go wide and have to back up to make the turn. Very tight, very technical and very fun…no, I didn’t make it through without baking up…a couple times.
Then it was time to pick up the pace a bit. Slide turn time…
The cones were rearranged into a series of S-turns about 20 feet apart. Del and the other coaches demonstrated the affects of skidding the rear wheel then trying to turn and starting a turn, then skidding the rear wheel. Big difference in the amount of travel of the rear wheel with starting the turn then skidding. The goal was to pick up speed, start the turn and skid the rear end to pivot around the cones. Took a bit of practice, but just about everyone was able to do that fairly well.
Every one seemed to do it better in one direction then the other. By One direction or the other, I don’t mean left or right, I mean coming or going. If they were coming back towards the group, there was a lot of room, not that anyone used it, but it was there. Going away from the group, you were headed towards a ledge. You still had all the room needed to do the exercise, but I think just the thought of going towards it kept the going away speeds a bit lower and we got less pivot out of the turns. A few times during the day, I had missed the brake pedal on the F800…and sure enough headed into the turn closest to the ledge I missed it again. Nothing like expecting to stop and your foot not touching anything to get a bit of vacuum at the seat. Had plenty of room to slow down and turn, but still got my attention.
Another trail ride around the ranch and it was back to the off camber switchback section we started on in the morning. This time we were using a new slide turn skills to pivot around a couple of these switchback turns. If done right, you could make the turn much sharper then trying to round the turn.
Time for another trail ride. These trail rides got progressively harder each time we headed out on them. They generally included something new that used the skill exercise we just completed. They got longer and more challenging. On this trail ride we headed down a long, fairly steep down hill the had quite a few twists and turns as we headed down. The whole track down was a mix of hard pack, loose dirt, small racks and grass. It was cool being able to use the slide turns out on the trail. It really proved the usefulness.
On this trail ride we ended up stopping near the teeter-totter area. This area also had a few hillclimbs and Del was letting those who wanted to climb the hills. From left to right the hills got more challenging. The first slope was just a straight up run. The one next to that had a small step at the top so you had to get your speed right or you would get a bit more air than a BMW should see. To the right of that was another step up, but this one was about halfway up and consisted of two rail road ties.
(Andrew headed to the rail road tie step up)
Being an unruly bunch of hoodlums, we asked about when would we get a chance to try it….No time like the present, so off we went…It was actually quite a bit easier than it looks. Proceed up slow and steady, hold your position as the other side drops and be ready for the bounce…then roll off. Easy…but fun.
(Mark and Roman conquering the teeter-totter)
That ended the class for the day...back to the compound.
EOD3MC screwed with this post 03-30-2013 at 04:34 PM Reason: adding videos
Old 03-29-2013, 09:04 AM   #85
JonnyCinco
JonnyCinco's Avatar
Oddometer: 91
That's what a good portion of the class was headed out to do yesterday while I was flying back
Base camp alpha is fun....however, I would highly recommend the CV. Includes Base one day out to base camp plus much more!
JonnyCinco is offline   Reply With Quote
Old 03-29-2013, 10:09 AM   #86
Mikehusa
Mikehusa's Avatar
Oddometer: 270
I took that class last year and came away with a lot of knowlege. I would say it is a must if you have an adventure bike and plan to take it off road. Prior to the class I did a ton of off road riding and some racing, I didnt think I would learn that much going into it. I had about 3k off road on my 800XC and thought I could get around pretty well. The lesson on how to ride in the sand was awesome. I couldn't believe how simple body positioning, clutch control and 2000rpm could get you thru anything. I have 10K+ of riding with a buddy of mine who happens to be one of the instructors. For years he bugged me to take the class and is one of the main reasons I bought an ADV bike. The students, instructors and staff are top notch. The food was great and the open bar was a nice plus. I hope to go back and take another class and or do the CV ride some day.
Mikehusa is offline   Reply With Quote
Old 03-29-2013, 07:42 PM   #87
EOD3MC OP
EOD3MC's Avatar
Oddometer: 4,777
Finally got some of the gopro video converted...
I've gone back and added the videos to previous posts
Old 03-30-2013, 04:28 PM   #88
blaster11
Ramping up fast!
blaster11's Avatar
Oddometer: 6,883
Thanks for posting the videos today Dave!
blaster11 is offline   Reply With Quote
Old 03-30-2013, 04:41 PM   #89
EOD3MC OP
EOD3MC's Avatar
Oddometer: 4,777
More videos and day 2 still to come
Old 03-31-2013, 07:19 AM   #90
Dorito
Dreamer and Doer
Dorito's Avatar
Oddometer: 5,301
BlastOff Adventures
Times are GMT -7.   It's 08:08 PM.
