Old 03-31-2013, 08:37 PM   #31
DisTech OP
DisTech's Avatar
Oddometer: 616
Originally Posted by refokus View Post
Nice work, keep it coming. I am interested in hearing the final results on the build.
Thanks, me too!
DisTech - Suzuki (1993 DR350S & 1994 DR350, 1996 DR650/DR790), BMW (1999 R1100GS)
DisTech is offline   Reply With Quote
Old 03-31-2013, 08:55 PM   #32
Bronco638
Nobody Home
Bronco638's Avatar
Oddometer: 4,001
Wait! You have Boss 302 heads lying around the garage!? Dude, those are some valuable weights.
There are some simple thruths......and dogs know what they are - Joseph Duemer
Andy holds the lead. And he will, all the way to the Highway. Today is his day.
Bronco638 is offline   Reply With Quote
Old 04-01-2013, 04:47 AM   #33
Chinookmark
Oddometer: 283
Chinookmark is offline   Reply With Quote
Old 04-04-2013, 05:59 PM   #34
plutonic
Outsider
plutonic's Avatar
Oddometer: 4,020
Any news?
" ...my life is an endless battle against maturity... "
"You are born. And you die. And if you are very lucky in between you get to ride motorcycles."
plutonic is offline   Reply With Quote
Old 04-06-2013, 04:43 PM   #35
DisTech OP
DisTech's Avatar
Oddometer: 616
Rear wheel and linkage
I wasn't planning on replacing the linkage bearings because last time I was in there (few years ago on first build) everything seemed good and I greased everything thoroughly. Well the "Heavy Duty Axle Grease" that I used... lets just say it turned against me. So new bearings all around and Maxima Hi-Temp Waterproof Grease.
Out with the old!
Nice looking part when it's clean.
Swingarm and linkage with new bearings & seals. Got the rear wheel back from the Wheel Master this week. Looks pretty nice, 18x2.5 Excel, heavy duty spokes, 520 sprocket and new bearings & seals. D606 130/90 18 is on order!
New 18x2.5 rim next to old 17x4.25. Quite a difference!
The gear shift cover gasket arrived today and is installed.
Had some bad luck with the "good deal" I found on the fork springs. Actually had to file a claim through Amazon to get a refund. I did get the refund but that has delayed things. Springs are on order again, this time direct from Race Tech.
Old 04-07-2013, 04:14 PM   #36
BergDonk
BergDonk's Avatar
Oddometer: 3,719
Interesting stuff. I see that you have what appears to be a non standard shock? Does it have any more compression than stock? If so, a 130 18 might be a little to large. With my Ohlins, a 120 18 606 is right on the limit with the chain adjustment in the middle, and even then, some damage resulted.
shed time IS quality time
BergDonk's DR650 BergDonk's XT1200Z
BergDonk is offline   Reply With Quote
Old 04-08-2013, 06:20 PM   #37
DisTech OP
DisTech's Avatar
Oddometer: 616
Thanks for the info BergDonk. It's a Cogent shock so if there is a problem then the 130 will be for my DR350.
Old 04-08-2013, 06:33 PM   #38
DisTech OP
DisTech's Avatar
Oddometer: 616
Nav tower mount
Not knowing what I'm doing, this is how I secured the nav tower mount to be tacked into place.
After LOTS of fiddle forking around trying to get it straight.
Finally committed and it looks straight!
Masked.
Rattle can black.
Old 04-13-2013, 10:43 AM   #39
DisTech OP
DisTech's Avatar
Oddometer: 616
New fork spring arrived this week and I updated spring rate calc post #4.
Old 04-13-2013, 03:15 PM   #40
EBMOTT
Oddometer: 70
Thumb
Great build . I am interested to how frnt forks and rear wheal turns out. These are mods that i want to do.
EBMOTT is offline   Reply With Quote
Old 04-13-2013, 05:39 PM   #41
DisTech OP
DisTech's Avatar
Oddometer: 616
Reassemble
Thanks EBMOTT.
Reassemble progress! Let's see what we have here.
  1. 790cc motor
  2. Swingarm with new bearings
  3. Rear wheel with Excel 18, D606 and new bearings
  4. RMZ450 triple with new head tube bearings
  5. RMZ450 forks with new RaceTech .52 springs, seals and wipers
  6. nav tower mount
  7. stabilizer post
Old 04-15-2013, 04:42 PM   #42
PhiSig1071
What's ******width?
PhiSig1071's Avatar
Oddometer: 2,513
Looks awesome!
Excuse what may be a dumb question, why the switch in wheel width? And is 4.25 the stock width? That sounds closer to a SM tire.
Which one of you FF's was it?...FOUNDER!
Entia non sunt multiplicanda praeter necessitatem
PhiSig1071 is offline   Reply With Quote
Old 04-15-2013, 07:18 PM   #43
DisTech OP
DisTech's Avatar
Oddometer: 616
Originally Posted by PhiSig1071 View Post
Looks awesome!
Thanks. I'm going for the kick ass, low maintenance dual sport that runs good on crappy gas and has easy to source consumables (21 tires and 520 chain & sprockets). I looked at 18x4.25's (KTM 950/990's use them) but I wanted an Excel rim and the price jump over 2.5 width is big and over 3.5 is ridiculous.
Old 04-16-2013, 08:10 AM   #44
GRinCR
Oppressed Nomad
GRinCR's Avatar
Oddometer: 326
Thumb Me Gusta
Greg Smith
'90 DR650RS
Costa Rica: Trippin' with GR , The Bike Teardown
_ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _
"My father taught me to work; he did not teach me to love it." -Abraham Lincoln
GRinCR is offline   Reply With Quote
Old 04-16-2013, 08:48 AM   #45
zilla
zilla's Avatar
Oddometer: 1,627
SWEET!!!!!!!!!
" The lesser of two evils is still evil"
zilla is offline   Reply With Quote
Times are GMT -7.   It's 07:59 AM.
