Old 04-16-2013, 08:51 AM   #46
bobfab
bobfab's Avatar
Oddometer: 1,501
Originally Posted by GRinCR View Post
me too! Moar!
CRF250L | KTM200SX
bobfab is offline   Reply With Quote
Old 04-16-2013, 06:08 PM   #47
DisTech OP
DisTech's Avatar
Oddometer: 616
Reassemble
Welcome lurkers!
More progress and she's a roller!
  1. Front wheel
    • RMZ450 front hub and rotor
    • Excel 21
  2. Exhaust
  3. Rear brakes functional
  4. Front brakes
    • RMZ450 master cylinder
    • DR650 brake line, was longer and beefier than the RMZ one
    • DR650 brake cylinder, identical to the RMZ one but already had Vapor speedo sensor mounting hole
    • Had to order a M6x12.7 magnet rotor bolt from TrailTech because the DR650 one is M8
    • Still need to bleed
  5. BRP Top clamp/sub mount for Scotts stabilizer
  6. HDB Top clamp
  7. Carb cables
  8. General cable, wire and vent routing. It is a puzzle!
DisTech - Suzuki (1993 DR350S & 1994 DR350, 1996 DR650/DR790), BMW (1999 R1100GS)
DisTech is offline   Reply With Quote
Old 04-16-2013, 06:21 PM   #48
Scubawerx
Scubawerx
Oddometer: 222
RMZ Build
Keep it coming. This is great stuff.
Scubawerx--Underwater Search Salvage and Recovery
Scubawerx is offline   Reply With Quote
Old 04-16-2013, 08:49 PM   #49
plutonic
Outsider
plutonic's Avatar
Oddometer: 4,150
" ...my life is an endless battle against maturity... "
"You are born. And you die. And if you are very lucky in between you get to ride motorcycles."
plutonic is offline   Reply With Quote
Old 04-17-2013, 07:32 AM   #50
Northwoods Yeti
Almost house broken
Northwoods Yeti's Avatar
Oddometer: 2,722
Thumb
Great build!
Northwoods Yeti is offline   Reply With Quote
Old 04-17-2013, 06:42 PM   #51
EBMOTT
Oddometer: 70
Question bars?
looks good ,I was wondering what bend are you running on your pro tapers? could be just photo but they look really tall. keep it up cant wait to see final out come.
EBMOTT is offline   Reply With Quote
Old 04-17-2013, 07:12 PM   #52
DisTech OP
DisTech's Avatar
Oddometer: 616
Pastrana FMX. I'm 6-5" so with the FMX, BRP top clamp/submount and ProCycle lowered pegs I can finally stand comfortably.
Old 04-18-2013, 04:36 PM   #53
DisTech OP
DisTech's Avatar
Oddometer: 616
Reassemble
This is good news!
Old 04-18-2013, 06:35 PM   #54
DisTech OP
DisTech's Avatar
Oddometer: 616
Fight the power!
Organized resistance.
Old 04-18-2013, 07:09 PM   #55
chasbo
chasbo's Avatar
Oddometer: 1,740
Sounds awesome man!
oooooooo........beer
You can outdistance that which is running after you,
but not what is running inside of you
chasbo is offline   Reply With Quote
Old 04-19-2013, 01:04 PM   #56
EBMOTT
Oddometer: 70
Nice
MILLER TIME
Old 04-20-2013, 06:06 PM   #57
DisTech OP
DisTech's Avatar
Oddometer: 616
DRZ400 key switch
The DRZ400 switch has four connectors and the DR650 has six. From the wiring diagrams you can see that the switches do the same thing (even same wire colors) except the DRZ does not have the O/Y & B/W circuit with the resistor. Here is my 100ohm 1/4watt 5% substitute resistor circuit.
This is the key switch I got from ebay, "New Genuine Suzuki Ignition Switch 2000-2011 DRZ400 S DRZ400SM OEM Keys #F99". I replaced the four connector with a six and put the resistor on the switch side of the coupling. Spade connectors and electrical tape is temporary because I wanted to test the switch but don't know how long the pigtail needs to be yet. The switch worked perfect.
Old 04-20-2013, 06:12 PM   #58
DisTech OP
DisTech's Avatar
Oddometer: 616
Nav tower
Mock-up!
Proceed to fabrication!
Old 04-20-2013, 07:16 PM   #59
Phreaky Phil
Oddometer: 1,930
I used the same ignition on my 650 and wired it so when in park position it kept power to my GPS and aux plug. This is great so the GPS stays on and doesnt keep wanting to turn off and our intercom stays on, so if we are sitting on the bike waiting we can talk.
Phreaky Phil is offline   Reply With Quote
Old 04-21-2013, 01:03 PM   #60
DisTech OP
DisTech's Avatar
Oddometer: 616
Nav tower
Given the lack of tools I have for bending metal, I'm pretty happy with how symmetrical the brackets turned out.
Times are GMT -7.   It's 07:18 AM.
