Old 03-17-2013, 04:34 PM   #1
concours OP
WFO for 41 years
concours's Avatar
Oddometer: 5,432
Anyone else used a Dangle wheel balancer?
I bought this thing 27 years ago, used it a bunch of times, I always re-read the enclosed directions and follow them to the letter. I used it on the front wheel of my vintage Commando, but the thing took a TON of weight
I ran it all last season, it seemed to gallop pretty hard. I am suspect of it's accuracy, I just re-checked with the Dangle, it showed balanced...
but when I used a conventional shaft style balancer, it needed way less weight, in a total different area.
Does anyone else use one of these? Results? Comments?
concours screwed with this post 03-17-2013 at 05:16 PM
Old 03-17-2013, 05:01 PM   #2
speedracertdi
speedracertdi's Avatar
Oddometer: 985
The angle of the dangle is in direct proportion to the heat of the meat.
Roads? Where we're going we don't need roads.
-Doc Brown
speedracertdi is offline   Reply With Quote
Old 03-17-2013, 06:26 PM   #3
concours OP
WFO for 41 years
concours's Avatar
Oddometer: 5,432
That's clearly addressed in the instruction manual
Old 03-18-2013, 04:44 PM   #4
concours OP
WFO for 41 years
concours's Avatar
Oddometer: 5,432
Shhhhhhheeeeeeeeeeeiiiiiiiiiiit. I was the only dope to fall for the advertising hype?
Old 03-18-2013, 04:47 PM   #5
Spam16v
Squid Rocket
Spam16v's Avatar
Oddometer: 857
and the mass of the ass
Spam16v is offline   Reply With Quote
Old 03-18-2013, 05:03 PM   #6
HapHazard
Waiting for Gudenov
HapHazard's Avatar
Oddometer: 2,355
^Think of yourself as a brave pioneer, Concours!
At least, at some point it worked for you.
Over 30 years ago I bought a "Breezer Tool" thinking it would make changing tires easier
It worked slightly worse an a canoe paddle would have.
Remember this POS?
HapHazard is offline   Reply With Quote
Old 03-18-2013, 05:12 PM   #7
concours OP
WFO for 41 years
concours's Avatar
Oddometer: 5,432
Remember this POS?
HELL YES! I think they still sell them.. I never took the plunge, lol
Old 03-19-2013, 07:38 AM   #8
Bounder
ExternallyDisplaced
Oddometer: 958
I've seen an Old Dunlop bubble balancer which I assume works on the same principle.
Works OK on car wheels but it won't fit moto wheels.
Dynamic balancing is probably more accurate for Moto applications.
You could probably make one of these in a few minutes.
Bounder screwed with this post 03-19-2013 at 07:44 AM
Bounder is online now   Reply With Quote
Old 03-19-2013, 10:24 AM   #9
Ironwood
Friday Harbor, WA
Oddometer: 789
And just how would you make the threaded cones?
Ironwood is offline   Reply With Quote
Old 03-19-2013, 01:37 PM   #10
ttpete
Rectum Non Bustibus
Oddometer: 6,158
I have a Coats bubble balancer. It has a rod with 2 cones and the bubble on one end. You put it through the wheel and tighten it, then hang the wheel and rod on the balancer base. I've been using it for years, and it works fine.
2015 BMW R9T, 2010 Ducati 1098 Streetfighter S
2009 Kaw 650 Versys, 1967 Triumph 650 TT Special
Old 03-19-2013, 03:25 PM   #11
concours OP
WFO for 41 years
concours's Avatar
Oddometer: 5,432
Pics please....
Old 03-19-2013, 03:28 PM   #12
concours OP
WFO for 41 years
concours's Avatar
Oddometer: 5,432
Looks like the one I borrowed... which is a hand built (in a prominant turbine engine manufacturing facility) must have had an example like that to copy!
Old 03-19-2013, 03:38 PM   #13
ttpete
Rectum Non Bustibus
Oddometer: 6,158
Originally Posted by concours View Post
Pics please....
http://www.ammcoats.com/coats-motorc...ubble-balancer
Old 03-20-2013, 04:33 AM   #14
Bounder
ExternallyDisplaced
Oddometer: 958
I wouldn't make a threaded cone, Turn a cone to the size of the axle you plan on using, drill a hole and tap it for a set screw to lock onto the shaft.
HDPE would be fine for that, You only need to stop the cone sliding out of the bearing.
Old 03-20-2013, 07:11 AM   #15
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,744
Had one of them made at work out of Alu, easy job for the marine engineer.But I wanted brass..... Still have to drill and tap it but a note on the set screw is not to use a real Allen type set screw, they are pretty hard and will mark the shaft and then the cone won't slide off easy. Had that little problem on another application and then switched to a regular soft bolt as a set screw.
Have tools, will travel!
Times are GMT -7.   It's 12:59 AM.
