Old 03-18-2013, 12:36 AM   #1
rocketman1 OP
rocketman1
Oddometer: 127
Final Drive on R1200GS oil drain?
I was considering buying a 2004-2007 R1200GS , but was concerned about the lack of being able to change the oil in the final drive. Apparently there is no filler or drain plug in some models. This seems ridiculous.
I dont consider having to remove the rear wheel etc and fill through a abs sensor hole much fun.
Does anyone know if BMW have returned to their senses and installed drain and filling holes like the older R1150gs models have?
If so what 1200 year models have this capablility.
rocketman1 is offline   Reply With Quote
Old 03-18-2013, 04:03 AM   #2
jdub
Dawg bytes reel gud
jdub's Avatar
Oddometer: 1,807
Many threads on this subject, and you can still change the oil easily in the FDs with no drain plug on the bottom. Well, I guess easy is a relative term depending on your wrenching ability/interest and this is about a 15 minute job.
Remove the rear wheel, remove the ABS/speedo sensor, remove the bolt that attached the top of the FD to the torque arm above the driveshaft housing and the FD pivots downward 90 degrees. Pull what now serves as the drain plug (positioned directly rearward before the FD is pivoted down) and drain the oil. Reinstall the plug, pivot the FD back up while re-engaging the driveshaft splined adapter to the FD input shaft splines, reinstall the bolt, refill FD through the sensor hole, reinstall the sensor and wheel and you're done.
Late build model year 2007 bikes and after got the bottom drain plug.
Current: 2014 R1200GSW
jdub is offline   Reply With Quote
Old 03-18-2013, 10:34 AM   #3
cjack
cjack's Avatar
Oddometer: 855
It's really a good chance to grease the final drive input splines. I have seen some so rusted that they could not be separated.
My other bike is a BMW
Jack
RA & MOA #224
cjack is offline   Reply With Quote
Old 03-18-2013, 11:45 AM   #4
k12lts
k12lts's Avatar
Oddometer: 346
Do it everytime you replace the rear tire, wheel is already off. Works out about right.
Andy
2010 BMW R1200RT
2011 Ural Patrol
1981 BMW R100RS
2006 KLR 650
k12lts is offline   Reply With Quote
Old 03-18-2013, 12:22 PM   #5
Dan-M
Dan-M's Avatar
Oddometer: 979
I don't know what year they added the fill hole but it is on the left so you still have to remove the wheel.
Dan-M is offline   Reply With Quote
Old 03-18-2013, 01:36 PM   #6
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 52,243
It is pretty simple. Follow these directions: http://www.jimvonbaden.com/R1200_Final_Drive.html
Jim
Old 03-18-2013, 08:15 PM   #7
trc.rhubarb
trc.rhubarb's Avatar
Oddometer: 1,989
This may sway you yet...
In order to get all the juice out, you have to drop the FD by unbolting it from the tele?lever. In order to do this and not break your wire for the ABS sensor, you have to remove the sensor anyhow. Since it's out at this point, pretend it's a fill hole and fill-er up.
2007 BMW GS Adventure / 2000 Ducati 900ss / 2010 Harley Ultra Limited / 1975 BMW R90/6 / 2006 DRZ400S
Follow me here
trc.rhubarb is offline   Reply With Quote
Old 03-30-2013, 11:41 AM   #8
seaswood
seaswood
seaswood's Avatar
Oddometer: 170
Final drive
Any one know if the newer bikes which have a drain hole are filled the same way? 2012
Removing the rear wheel looks like it is as no fill with wheel on.
Approaching. A 600 mile oil change.
1200GSA /7/5
seaswood is offline   Reply With Quote
Old 03-30-2013, 12:11 PM   #9
cjack
cjack's Avatar
Oddometer: 855
New bikes have a drain plug in the bottom and a fill hole on the side closest to the wheel that is above the center of the drive. Seems like I remember it being at 10 to 11 o'clock or so. I always drop the drive the first time though to grease the driveshaft splines.
Jack
RA & MOA #224
Old 03-30-2013, 05:53 PM   #10
chewnaut
Rob
chewnaut's Avatar
Oddometer: 72
On my '12 GSA the fill hole is at 3 o'clock when the wheel is off. If you lube spline then you can just fill thru speed sensor hole, since you'll have to remove it anyway.
chewnaut is offline   Reply With Quote
Old 03-31-2013, 11:24 AM   #11
Multiplicity
Oddometer: 172
The new FD's hold 200ml of gear oil. Don't over fill it.
Multiplicity is offline   Reply With Quote
Old 03-31-2013, 11:28 AM   #12
LaurelPerryOnLand
Oddometer: 3,478
What YEAR(s) are you referring to?
LaurelPerryOnLand is offline   Reply With Quote
Old 03-31-2013, 04:15 PM   #13
seaswood
seaswood
seaswood's Avatar
Oddometer: 170
Max sent a 207ml bottle of oil & sealing ring for the drain & fill hole & speed sensor it looks like. Doing the 600 oil change.
1200GSA /7/5
Old 03-31-2013, 04:37 PM   #14
Callisto224
Callisto224's Avatar
Oddometer: 1,056
On my 2009 12GS after trying several times to loosen it, I couldn't budge the fill hole bolt. I used the sensor hole instead! Just take your time, the fluid goes in very slowly!
Also, after checking several sources, I couldn't find a consensus on the amount of fluid for my 2009 so I filled it with 200ml and hoped for the best. So far, so good!
Callisto224
2009 1200GS
Callisto224 is offline   Reply With Quote
Old 03-31-2013, 04:44 PM   #15
Multiplicity
Oddometer: 172
Anything with the vent from 2010 and up. Mine is a 2013 BMW has changed it about 3 times, IIRC. From 180ml to 220ml and back to 200ml.
Times are GMT -7.   It's 11:33 AM.
