Old 03-18-2013, 12:09 PM   #16
broncobowsher
broncobowsher's Avatar
Oddometer: 444
I have used a vice a few times. Holds the tire fairly well. Same concept but I reverse it. I remove the wheel from the tire instead of the tire from the wheel. Same result, just I am holding the wheel in my hands after it is all apart. the vice was mounted to my welding cart. I found it easier to man handle the wheel as needed to match the tire then it is to work a tire over the wheel.
broncobowsher is offline   Reply With Quote
Old 03-18-2013, 12:42 PM   #17
clapped_r6
The Spoad Warrior
clapped_r6's Avatar
Oddometer: 2,167
http://www.advrider.com/forums/showt...hanging+thread
none of us are as dumb as all of us
clapped_r6 is offline   Reply With Quote
Old 03-18-2013, 03:38 PM   #18
D.T.
One wheel wonder...
D.T.'s Avatar
Oddometer: 6,261
Yep, that would be me.
"Tough times don't last, but tough people do." Robert A. Schuler
D.T. is offline   Reply With Quote
Old 03-18-2013, 06:28 PM   #19
clintnz
Trans-Global Chook Chaser
clintnz's Avatar
Oddometer: 2,690
The 3 lever technique as above usually works but I have popped a few stubborn ones in the trusty Record No5 too. Very easy. Set the tyre on a chunk of wood under the jaws so it sits at the right height. You need a good size vice to fit around a rear tyre, but you need a good size vice anyway
I have been thinking about making a steel version of the 4x2 wood setup above that will clip onto a leg of my bench for doing car/4x4 tyres though.
Cheers
Clint
'03 KTM 640 LC4 Enduro
The wilderness, the desert - why are they not crowded
.................................................. .....with pilgrims?
clintnz is online now   Reply With Quote
Old 03-18-2013, 07:33 PM   #20
Fly Molo
Crazy Sniffable
Fly Molo's Avatar
Oddometer: 61
Yes. Yes I have. That 17 year-old tire didn't see it coming.
My signature is over here.
Fly Molo is online now   Reply With Quote
Old 03-19-2013, 01:21 AM   #21
motu
Loose Pre Unit
motu's Avatar
Oddometer: 3,948
I have no problem breaking the bead of my front tyre with a vice, but my 100mm vice at home is too small for the rear tyre... if I have to go out to break a bead I'll stop at the tyre shop rather than go to work for a bigger vice.
I could make a lever type bead breaker - but as an apprentice we had a manual tyre machine, with a lever bead breaker. As a 16 year old I had to swing on this thing to break beads - that was over 40 years ago, and I'm still reluctant to go back there.
motu is online now   Reply With Quote
Old 03-20-2013, 07:52 PM   #22
richarddacat
breaking wind
richarddacat's Avatar
Oddometer: 2,568
My rear tire was shot too and had a spare used one with hopefully enough tread to wear out the front.
Anyway, the past 2 out of three times I let a shop mount my tires, the first time they did great, 2nd time they scratch my painted rims, the 3rd time they ruined a bearing.
So I'm doing it myself for now on.
I mixed up a solution of bodywash, mineral oil and water, nothing precise. I also sprayed the bead with a penetrating oil and let it sat over night.
I use the C-Clamp method to break the bead along with a Motion Pro Bead Popper. With the bead popped I sprayed the edges and tire with Pam non-stick spray and rubbed my mixture along with it. I used regular tire tools and didn't have any problem. Also used rim protectors from MP also.
I stopped in at Harbor Freight and got me a balancing stand and saw a bead breaker there for $40. that looked pretty handy and have also been scouting some newer tire tools that are out there, check out Mojolever.
* 05FJR/74R90s *
If we concentrated on the really important stuff in life, there'd be a shortage of motorcycles.
richarddacat is offline   Reply With Quote
Old 03-20-2013, 07:52 PM   #23
Giggity
But wait, there's more...
Giggity's Avatar
Oddometer: 637
With the wheel still on my GS I used two of these so I could replace a bad valve stem.
Giggity is offline   Reply With Quote
Old 03-21-2013, 12:08 PM   #24
Travlr
Oddometer: 53
best money spent for tire repair
Hello, as I am a fond believer in tubes. (yes that is my own dillusional thought process). I have found the best thing for breaking beads in the shop or on the side of a mountain is the best rest beak-brakr.
http://www.bestrestproducts.com/c-98-beadbrakr.aspx
I find if I use my kit tools in the shop it helps to sort out what works and what doesn't.
(no affiliation to best rest, just a happy customer)
Travlr is offline   Reply With Quote
Old 03-21-2013, 12:33 PM   #25
broncobowsher
Oddometer: 444
Used the vice last night in peeling the tire off a wheelbarrow rim. Tube is rotten. Now to find a wheelbarrow tube. I got it apart with no other tools.
Old 03-22-2013, 09:11 PM   #26
doorman
Aimless
doorman's Avatar
Oddometer: 79
I've used my bench vise to break a stubborn bead before. Clamped all the way down and the bead still didn't break. I then added a c clamp on either side of the vice and finally it came loose.
doorman is offline   Reply With Quote
Old 03-23-2013, 07:18 AM   #27
Hastelloy-X
Oddometer: 256
To break the bead on ATV tires I've seen people use their truck or car; they would line up the tire of their car so it would impact as close to the ATV rim edge as possible. Then drive over it.
Hastelloy-X is offline   Reply With Quote
Old 03-23-2013, 03:13 PM   #28
doorman
Aimless
doorman's Avatar
Oddometer: 79
I've done the driving on the bead method as well. I take a solid length of lumber and make a ramp on to the bead, which I then "skillfully" drive my truck up. I do this as a last resort. It has never failed. Apparently, no bead is a match for a 3/4 ton pickup.
Old 03-23-2013, 03:26 PM   #29
Ricardo Kuhn
a.k.a. Mr Rico Suave
Ricardo Kuhn's Avatar
Oddometer: 11,581
Send a message via Yahoo to Ricardo Kuhn
Originally Posted by mouthfulloflake View Post
I use a similar method but I substitute the car with a the second step on a starcase, very dependable and easy take the tires off that way..
I'm really Sorry but I'm "Out" of Rickybars, Actually I have a bunch of bars and a Ton of end pieces but Not that many clamps to offer them as a product anymore.
Ricardo Kuhn is offline   Reply With Quote
Old 03-24-2013, 08:46 AM   #30
Speedo66
Oddometer: 4,581
I'm surprised no one has mentioned the kick stand bead breaker method.
I've done this many times, although I sometimes use the C-clamp.
If you have access to another bike, lay the wheel on the ground, put the kick stand foot down on the bead area, and lean the bike into it. Sometimes it takes more pressure than others, but it has always worked.
I realize this requires another bike, tough if you're out by yourself, but great if you're riding with someone else, or in your garage with another bike.
'01 Kawasaki W650
'05 Yamaha XT225
Speedo66 is offline   Reply With Quote
Times are GMT -7.   It's 04:26 AM.
