Old 03-19-2013, 08:43 AM   #1
clawdog60 OP
clawdog60's Avatar
Oddometer: 69
Plastic panniers
Anyone running the HB plastic panniers and thoughts on them.
clawdog60 is offline   Reply With Quote
Old 03-19-2013, 09:52 AM   #2
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 52,929
Check over in Orange Crush. The KTM guys use them a lot, and seem to find them pretty good.
Jim
Old 03-19-2013, 10:44 AM   #3
abruzzi
abruzzi's Avatar
Oddometer: 985
Which panniers are you asking about? HB sells a number of models that are plastic. My brother has HB Journey cases that came on his Ulysses, and I have a set of Gobi cases on my 640 Adventure.
Geof
http://tigertriple.com/
abruzzi is offline   Reply With Quote
Old 03-19-2013, 10:46 AM   #4
lanceputnam
Hayden's Dad
lanceputnam's Avatar
Oddometer: 446
Most of my buddies that ride 950/900's have the gobi's and they love them. Plus... Its kinda like owning the worlds largest set of frame sliders.
So others may live...
2012 BMW R1200 GS-Rallye
COBDR, AZBDR
lanceputnam is offline   Reply With Quote
Old 04-12-2013, 08:38 AM   #5
clawdog60 OP
clawdog60's Avatar
Oddometer: 69
I think they are the Gobi's, will have to recheck the site. They have a semi-top opening lid, they look durable but I dont want something that will be warped after a summer in the sun.
Old 04-12-2013, 09:14 AM   #6
Dan Alexander
Ride Far - Ride Fast
Dan Alexander's Avatar
Oddometer: 7,533
Most of the knock is that they are big for their capacity, mostly because of the integrated water bladder/liner but also don't tuck in anywhere as the bike they were meant for has dual exhaust. Also they aren't as thick plastic as a Pelican case so corners can be ground much easier.
Beemers Past and Present: 74 R90S, 77 R100RS, 85 K100RS, 2x 87 K100RS, 96 R1100GS (getting hacked), 99 R1100S, 2002 R1150GS, 2005 F650 Dakar, 81 GL500/Velorex
Plus the occasional Triumph, BSA, Yamaha, Honda, Suzuki and KTM but who's counting
Dan Alexander is offline   Reply With Quote
Old 04-12-2013, 11:14 AM   #7
fubar201
fubar201's Avatar
Oddometer: 256
I had both the Journey and Gobi on my Uly. Hated the Journeys because of the *very* fragile latch. Bought the Gobis after breaking my third latch. I bought them because they fit the same racks for side and top cases. I liked them much better. Not my first chioce on the GS tho.
fubar201 is offline   Reply With Quote
Old 04-12-2013, 11:45 AM   #8
abruzzi
abruzzi's Avatar
Oddometer: 985
Te Gobis are basically indestructible. I've beat the living **** out of mine and they continue to work fine. I used them in heat up to 125F. (I live in the desert where we get 100+ for usually 30 or more days every summer. Their one drawback is the thick walls which means they waste a fair amount of bulk. If I remember correctly, they are something like 35 liter on the inside, but they take up the space of a 40+ liter case.
Geof
Old 04-18-2013, 10:31 AM   #9
clawdog60 OP
clawdog60's Avatar
Oddometer: 69
Do you think they are on the heavy side with the double wall construction? Can you give me a overall width with the mounts?
Old 04-18-2013, 03:42 PM   #10
abruzzi
abruzzi's Avatar
Oddometer: 985
They're no heavier than most other panniers I've used. I don't know the width partly because I've never used them on a GS, just on a KTM 640 and a KTM 950. HB says the cases themselves are 20" wide each. So you have 40" there, plus the width of the frame.
Geof
Old 04-21-2013, 05:29 PM   #11
clawdog60 OP
clawdog60's Avatar
Oddometer: 69
thanks. roomy but way too wide for me.
Old 05-11-2013, 01:50 PM   #12
fubar201
fubar201's Avatar
Oddometer: 256
That's pretty funny when looking at your avatar. :o
Old 05-11-2013, 06:07 PM   #13
HeatXfer
Bad knees
HeatXfer's Avatar
Oddometer: 698
I recently picked up a pair of HB 40L Juniors for my '07 990 Adv: They're wider than Gobis and Jesse's, not as deep (=higher center of gravity) and they open from the side. In short, I found out they're OK for daily commutor use but not ideal for camping or long trips.
HeatXfer is offline   Reply With Quote
Old 05-13-2013, 04:23 PM   #14
what car??
down the road
Oddometer: 372
I had a chance to check out the HB plastic and older set of TT for my bike, 2010 KTM 990A. After checking out the two of them I decided NOT to get the HB's. I didn't like the dead space, which in my mind, equates to an airbag for your belongings. I didn't want a wider box for less space, to me it doesn't make sense. Makes me wonder how many of the owners of those boxes use them for water anyway. I know I wouldn't. Thought about it actually for fuel but scraped that idea.
In short I feel it's a pretty poor set up for the cost and size of the things. I also felt the mounting system to the rack was subpar. Just my opinion however.
Here is a link from OC:
http://www.advrider.com/forums/showthread.php?t=883293
what car?? screwed with this post 05-15-2013 at 06:16 PM
what car?? is offline   Reply With Quote
Times are GMT -7.   It's 05:17 PM.
