Old 03-19-2013, 07:20 PM   #1
eddyturn OP
Wannabe
Oddometer: 2,066
air deflectors
Looking for some air deflectors that might be from aircraft. Glue on part is a circle but the upper section is oval plastic - clear. Not a great description and cannot find it on Google images. Want to place a few on my windshield to see if I can alter the flow over the top just a bit to smooth things out. Anyone recall seeing these? Pretty sure they were on some aircraft here and there.
All things being equal... fat people use more soap
eddyturn is offline   Reply With Quote
Old 03-20-2013, 05:53 AM   #2
Flydog
Flydog
Flydog's Avatar
Oddometer: 101
Check Aircraft Spruce
Flydog is offline   Reply With Quote
Old 03-20-2013, 07:21 AM   #3
Maggot12
U'mmmm yeaah!!
Maggot12's Avatar
Oddometer: 5,347
They're out there and are louvered air vent covers. Under the little bubble is a hole in the aircraft skin with a flapper.
The hangar I used to work at and moved from last summer had a 45 gallon drum full of those things. If I was still there, I could send you a few hundred.
You could make similar using the bottom knubbies of a 2 liter pop bottle, to see if it'll work until you get the real thing.
They are about the size of a loonie or toonie in Canada, or a .50 piece in the US.
hope this helps.
good luck
Maggot
Don't sweat the petty things; Pet the sweaty things !!!
Maggot12 is offline   Reply With Quote
Old 03-20-2013, 08:12 AM   #4
the_gr8t_waldo
Oddometer: 2,126
"snapvent" has quite a few...this from aircraft spruce http://www.aircraftspruce.com/catalo...snapvents3.php
the_gr8t_waldo is offline   Reply With Quote
Old 03-20-2013, 07:11 PM   #5
eddyturn OP
Wannabe
Oddometer: 2,066
OOOOO thanks guys. I will call those guys at Aircraftspruce tomorrow. I want those Vortex Generators but not 80 of them. Maybe they'll have a few laying around. I just need to change the airflow and may do some pop bottle and/or cardboard work and see if I am on the right track.
Old 03-21-2013, 12:21 PM   #6
ttpete
Rectum Non Bustibus
Oddometer: 5,989
MRA makes a bolt on adjustable deflector/spoiler for any windshield. Twisted Throttle carries them.
http://www.twistedthrottle.com/mra-x...-blade-bolt-on
15 BMW RnineT
09 Kaw Versys
Times are GMT -7.   It's 06:59 AM.
