Old 03-20-2013, 01:17 PM   #1
Johnny Locks OP
Johnny Locks's Avatar
Oddometer: 112
Where are the early 90's BMW K Bike experts?
I'm considering purchasing an early 90's K100RS that looks to be in really good condition. Long ago I had a K75s, so I know enough to know I really like those K bikes. But I was too young and dumb to fully appreciate the bike then, or learn much about it. Now that these bikes have been on the road for two decades, I'm sure there are people out there who know a lot about them. What are the things I should pay special attention to? What are the weak links on these bikes?
Johnny Locks is offline   Reply With Quote
Old 03-20-2013, 02:59 PM   #2
Jimmy B.
Jimmy B.'s Avatar
Oddometer: 112
K bikes
Get on over to
http://www.motobrick.com/
Or here...
http://www.k11og.org/
They know there stuff.
If you want to read even more, try this.
http://www.ibmwr.org/ktech.shtml
K75 triple, always smooth. K1100 has better brakes & suspension than a K100 and both have more HP & torque than a K75.
I went from an 81 R100RS that I put on over a 100,000 miles on to a 94 K1100RS. Big change. Only had it home & got crashed out. Went & bought a 93 about 3 weeks later. Got it from a guy at the universtity near the twin cities by you.
I'd rather be riding.
Jimmy B. is offline   Reply With Quote
Old 03-20-2013, 03:26 PM   #3
oldenuf
Oddometer: 500
info
+1 on internet BMW riders www.ibmwr.org . The tech section has good Kbike info.
Art
oldenuf is offline   Reply With Quote
Old 03-20-2013, 03:33 PM   #4
duck
duck's Avatar
Oddometer: 10,403
If it's in cosmetically good condition then there's a very high likelihood that it's been mechanically well-maintained as well. (All that really matters is engine oil changes. Maybe a transmission input spline lube if it has more than 40k on the clock.)
Just buy it.
duck is offline   Reply With Quote
Old 03-20-2013, 03:42 PM   #5
Mr. G
Normal Dude
Mr. G's Avatar
Oddometer: 1,780
Make sure the ABS pump cycles correctly at start-up (lights go off at 8 mph)
Check the front rotor for axial play (worn button bolts)
Check all rotors for min thickness, they seem to wear fast
The handlebar risers are mounted in rubber bushings that wear out, check for looseness.
The side panel mounting clips seem very fragile on these bikes. Check to see if they are in tact or if they have been ghetto engineered.
Check condition of the fuel lines, it's a big job to replace them if they are cracked and failing.
None of the above are a deal breaker (well maybe the ABS) but they can be negotiating points.
Good luck with the purchase.
LATER...........Gregg
"If we can manage to convince the Chinese that Jihadists' testicles are aphrodisiacs, within ten years they'll have disappeared..."
Mr. G is online now   Reply With Quote
Old 03-20-2013, 03:50 PM   #6
oldenuf
Oddometer: 500
K's
The only problem with my 85 K100 was the speedometer would shut off on occasion, and there was a article for the fix on ibmwr site that gave me a fix for it. They are good machines but dated. Most have lots of miles on them. Resale should be better.
Art
Old 03-20-2013, 05:29 PM   #7
duck
duck's Avatar
Oddometer: 10,403
What? It's not that hard. To access the lines to the FPR all you have to do is remove the bottom half of the airbox.
Old 03-21-2013, 06:01 PM   #8
Johnny Locks OP
Oddometer: 112
Originally Posted by Jimmy B. View Post
Get on over to
Or here...
Thanks for the resources. All good, I've been checking them out.
Old 03-21-2013, 06:08 PM   #9
Johnny Locks OP
Oddometer: 112
Dated or Classic?
Art
I've seen quite a few K bikes for sale in good condition with low miles. Nostalgia and availability has got the wheels turning in my head. They may be dated, but with fuel injection, liquid cooling, twin rotor front brakes, and maybe even ABS they are a hell of a lot less dated than the R100GS I'm riding now. I love that thing, and would never cast aspersions on airheads. Just saying something like "If I never move on past 90's technology I'll never know what I'm missing." Right? Lot's of things could be called dated. But almost nothing modern can be called classic.
Johnny Locks screwed with this post 03-21-2013 at 06:12 PM Reason: clarity
Old 03-21-2013, 11:54 PM   #10
A. T. T-W
Can't be bothered.
A. T. T-W's Avatar
Oddometer: 4,422
They were bloody good bikes in their day, just not fashionable.
They're still bloody good bikes today. Even the earliest and least encumbered with funny drive-shafts, ABS and multi-piston brakes can easily cope with today's road and traffic conditions.
On top of that, they're pretty simple, easy to work on, aided by their "unitary" construction and the quality of parts isn't too shoddy either. Reliability is another strong point, almost legendary.
There seems to be an increasing interest in the Bricks among those who were told by the Press not to bother and even among a generation for whom they weren't available as a new option.
Grab a good one, or even a shoddy one, while they are still relatively cheap. They're never going to be worth vast sums but prices are picking-up.
Archibald Tarquin Throttle-Whistle Esq.
A. T. T-W is offline   Reply With Quote
Old 03-22-2013, 06:41 AM   #11
eric2
®egister this:
eric2's Avatar
Oddometer: 3,810
Things to look for include oil leaks, there's an o ring in the clutch area that will harden and leak, and combo water\oil pump at the front of the motor.
Brake fluid been changed? If not you could end up having to replace the master or slave cylinders or worse if it has ABS.
Make sure it hasn't set up too long, as the fuel pump mount is rubber and will disintegrate.
Other than that its a pretty bulletproof bike, only other issues would be if it has high mileage, as the ujoints in the driveshaft should be checked if it has over 100k on it
Eric
'06 R12GS, '13 s1000RR
Originally Posted by Big Steve View Post
I've yet to see a poor person driving a real gas hog......
lottery: A tax for people bad at math
eric2 is offline   Reply With Quote
Old 03-22-2013, 11:54 AM   #12
CrashBar
Just Wanna Ride
CrashBar's Avatar
Oddometer: 133
Check the exhaust for cracks
I couldn't find anyone to weld mine, bought a Remus instead
I got 99,600 miles out of my u-joint. Looked like a hand grenade had gone off
While I was fixing that, I replaced this
Lots of good info at the links above. Go for it. This is mine at 126K miles
....to trade in these wings on some wheels...
1993 K1100 LT (132,000 miles and counting)
1973 CB350F / 1978 CB550K / 1973 TR5T
CrashBar is offline   Reply With Quote
Times are GMT -7.   It's 06:28 AM.
