Old 03-20-2013, 07:57 PM   #1
rightone1974 OP
rightone1974's Avatar
Oddometer: 19
Question !976 Dt 250c Ignition???
I have a 1976 yamaha dt250c that the coil is bad and they are expensive. I need to replace the points and condenser too. I was wondering if there was any way to convert my bike to electronic ignition. I have 6 volt system now. Would it be price effective switching over to electronic ignition if there are parts avaliable. Does anyone have any parts that they are selling to help me out in this project. I have money for the parts. Thank you for any assitance.
rightone1974 is offline   Reply With Quote
Old 03-21-2013, 11:54 AM   #2
Beezer
Oddometer: 5,746
if somebody makes one, it's more money than a new coil & points
picked at random from 100 examples...
http://www.ebay.com/itm/YAMAHA-DT125...a91e0c&vxp=mtr
new points & condenser are about $20... they will last years... prolly longer than the piston rings
Beezer is offline   Reply With Quote
Old 03-22-2013, 11:39 AM   #3
Strombony
Strombony's Avatar
Oddometer: 435
any good coil will work
I recently started fixing up a 1974 rv125 suzuki with a 6 volt system.
It had a no spark issue and I determined the coil was bad, replaced it with a
12 v motorcycle coil from a early 80's suzuki. I used it because the
coil mounts were the same. It had 2 wires instead of 1. I hooked 1 wire to the positive wire and the other wire I grounded to the frame.
It worked fine.
Replace the points and condensor with new, they are probably available, and put
any coil on it that works, even a gm-delco car coil.
matt
07 FXD SUPERGLIDE
02 DL 1000
06 640 adv
01 ktm 400 mxc
92 RMX 250, blown up!
Strombony is offline   Reply With Quote
Old 03-22-2013, 07:15 PM   #4
Beezer
Oddometer: 5,746
hmmmmm... I think the ignition system on the old DT is a magneto, but I could be wrong. if so a coil from a similar bike system would work, but a battery system coil has a higher primary... like between 3 & 10 ohms. a mag coil will be less than one ohm typically
Old 04-05-2013, 07:26 PM   #5
rightone1974 OP
Oddometer: 19
Laugh
what size flywheel puller do i need for this 1976 yamaha dt250 c enduro to remove the flywheel? Is it the left hand 27mm x 1mm threads?
Old 04-05-2013, 07:53 PM   #6
tHEtREV
Captain Awesome
tHEtREV's Avatar
Oddometer: 7,676
Sorry I took so long to read this, but I had a 76 DT 250 with points ignition.
I bought a 79 or 80 model DT 250 for parts with CDI.
It was a straight forward swap of parts to change the 76 to CDI.
I just used the 80 coil and backing plate I think, CDI box and wiring harness.
Took me about half an hour.
tEAM iDIOT.
A KDX is way cooler than what ever you ride...
tHEtREV is offline   Reply With Quote
Old 04-05-2013, 08:36 PM   #7
rightone1974 OP
Oddometer: 19
Wicked
cool i have to start looking for a parts bike then. Do you know what size the puller is to remove the flywheel
Old 04-05-2013, 10:28 PM   #8
tHEtREV
Captain Awesome
tHEtREV's Avatar
Oddometer: 7,676
I know I have the right size puller, but I have four and can't remember which one it is.
Sorry.
tEAM iDIOT.
Old 04-06-2013, 11:27 AM   #9
rightone1974 OP
Oddometer: 19
Wicked
Sorry.
Do you know the part # on it if there is one and brand or where you got it at? Other wise do you have a micrometer to measure the threads
Times are GMT -7.   It's 08:32 AM.
