Old 03-21-2013, 05:47 AM   #1
xy500 OP
Loser
Oddometer: 73
XL250r Carbies fuel level too high
I've got a problem with a 1985 XL250r, i have been having many problems with the dual carbs. But i've eliminated as many problems as i can, but one remains; too high fuel level in the carbs.
What happens is the fuel level will reach a good level, then slowly creep up until the level is above the gasket face of the carb bowl. The carbs won't overflow though for whatever reason.
If i try set the level any lower, no fuel will enter the carb bowls at all.
I've renewed the floats and needles. This problem happens with both primary and secondary carbs.
The bike runs great if i shut the fuel off and let the level drop, so the fuel level is definitely a problem. Any insights would be appreciated.
Experience is wasted on the old
xy500 is offline   Reply With Quote
Old 03-21-2013, 09:14 AM   #2
CycleDoc59
Wrench Rider
CycleDoc59's Avatar
Oddometer: 981
I believe the float needle seat on those is
pressed in with a O ring seal which has likely
failed. A photo here shows what that would look like:
http://tinyurl.com/btnsfm7
Also, does the needle cushion spring work ok?
If it sticks, it causes float height problems. And,
sometime the float(s) get bent slightly such that
the float sides drag...
CycleDoc59 is offline   Reply With Quote
Old 03-21-2013, 07:41 PM   #3
xy500 OP
Loser
Oddometer: 73
cheers for the insight.
The carbs on this model don't have removable seats though:
http://www.servicehondapsn.com/fiche...85&fveh=131787
I have checked with the bowls off and the fuel on, when i lift the float to when the spring on the plunger engages the fuel cuts off completely.
so the seat seems good.
The secondary float was dragging, but i bent it back straight so thats not a problem anymore...
Keep throwing those ideas at me!
Old 03-21-2013, 08:35 PM   #4
Danjal
Insert wit here.
Danjal's Avatar
Oddometer: 2,755
Possible vacuum in the bowls? There's normally a vent on carbs,could be clogged partially not letting enough air in to offset the vac.
Danjal is offline   Reply With Quote
Old 03-21-2013, 09:34 PM   #5
qkenf4u
Oddometer: 201
you say you fixed a dragging float.... maybe cut down your bowl gasket (or is it o-ring style on these ??) so it doesnt hold the float up ?
qkenf4u is offline   Reply With Quote
Old 03-22-2013, 12:03 AM   #6
xy500 OP
Loser
Oddometer: 73
The bowls overfill with the motor off, so no vacuum present. I gave them a spray out though just in case
They're o-ring style rubber gaskets, thankfully as i have had to take the bowls on and off too many times! The float is two piece, and the one of the floats was dragging against the jet holding section in the middle.
Old 03-22-2013, 04:12 AM   #7
Danjal
Insert wit here.
Danjal's Avatar
Oddometer: 2,755
Ok,so it's purely a mechanical problem then.
Times are GMT -7.   It's 08:46 AM.
