Go Back   ADVrider > Riding > The Perfect Line and Other Riding Myths
Old 03-22-2013, 01:16 PM   #1
HooliKen OP
Awesome is a flavor
HooliKen's Avatar
Oddometer: 3,018
Question Experts weigh in and/or dog pile....???
Only 500 motherlovin miles on this motherlovin tire that I had no choice but to get ass raped at an HD dealer for $320 installed.
So what does everyone think? Close enough to center to do a proper plug/patch from the inside?
"People in this country sleep peaceably in their beds at night because rough men stand ready to do violence on their behalf." George Orwell
950R Super Enduro - 450EXC - Gas Gas TXT 280 - 2000 Honda XR100R - 1988 Honda Z50R
HooliKen is offline   Reply With Quote
Old 03-22-2013, 01:19 PM   #2
some call me...tim
some call me...tim's Avatar
Oddometer: 282
I say just use one of the worm plugs and ride on. My buddy got a puncture like that in his tire and has put ~10k on since then on his gummy plug, no issues.
some call me...tim is offline   Reply With Quote
Old 03-22-2013, 01:34 PM   #3
Blue&Yellow
but orange inside...
Blue&Yellow's Avatar
Oddometer: 754
In my experience plug repairs are tougher than you think, I've had two like that and they lasted the rest of the life of the tyre with zero issues. One was right in the center too.
Depends a bit on what you're doing though: if you're going to be canyon carving at 100mph maybe not worth the risk?
Blue&Yellow is offline   Reply With Quote
Old 03-22-2013, 01:35 PM   #4
Mr_Gone
The Lejund!
Mr_Gone's Avatar
Oddometer: 8,620
I did the same thing. I rode another 3,000 miles on a plugged tire. No issues. Held air perfectly.
Mr_Gone is offline   Reply With Quote
Old 03-22-2013, 01:38 PM   #5
DSM8
Where fun goes to die....
DSM8's Avatar
Oddometer: 4,067
I typiucally put 15K on my rear tire.
During that time it will get 1-2 plugs in it.
Since it is not a sport bike the worm style plugs are the way to go and I slather the plug with the rubber cement before installation.
This does two things. Makes the install easier and helps to cement it all together. Over kill sure but I have NEVER had a worm plug I have installed like that fail and it has been both on the side like yours and in the center tread as well.
For the center tread I just wont wear the tire down as much as I would otherwise when it comes time to replace.
I would plug that one if it were mine.
Just my .02
Oh and don't use those mushroom style plugs, I have had those fail over time. They are a great temp fix to get home etc but I just cant trust them for the long haul.
DSM8 - A different kind of mean
SQL > SELECT finger FROM hand WHERE id=3
http://share.findmespot.com/shared/f...d5LbKWMz6cHxaH
DSM8 is offline   Reply With Quote
Old 03-22-2013, 01:49 PM   #6
fyrfytr
B.U.F.F.
fyrfytr's Avatar
Oddometer: 2,738
I would plug it on a trip, or patch it if close to home.
There's something kinda sad about, the way that things have come to be. Desensitized to everything, what became of subtlety?
fyrfytr is offline   Reply With Quote
Old 03-22-2013, 02:04 PM   #7
t-bills
mcs are dangerous
t-bills's Avatar
Oddometer: 291
My last PR2 had two plugs in it when I took it off. The first was at around 2000 miles on the tire. The other was at about 5000 miles on the tire. The tire lasted 9000 miles. Lots of people are scared to death of worm plugs. I've never had one so much as leak.
As for the location in the tire, not a problem at all. As long as you aren't in the sidewalls, you are doing just fine.
Keep riding it. Or put a new tire on it and send me that one.
t-bills is offline   Reply With Quote
Old 03-22-2013, 02:10 PM   #8
El Pescador
Oddometer: 249
Plug it.
El Pescador is offline   Reply With Quote
Old 03-22-2013, 02:11 PM   #9
murder face
murder face's Avatar
Oddometer: 36
I would have a patch put on inside the tire. If they would'nt do that then I would put a tire plug in it myself and keep riding.
Chuck Norris once broke the land speed record on a bike that was missing its chain, left pedal and back tire.
murder face is offline   Reply With Quote
Old 03-22-2013, 03:16 PM   #10
troidus
Oddometer: 16,257
Some people do both. The rationale is, the patch guarantees that it's airtight, and the string keeps foreign material from working down into the hole and causing delamination of the layers. I suppose you'd have to put the string in first, let it set up, then demount the tire and cut off the excess on the inside before applying the patch.
troidus is offline   Reply With Quote
Old 03-22-2013, 03:30 PM   #11
DAKEZ
DAKEZ's Avatar
Oddometer: 19,747
Rear? Patch and ride. Front? Patch and replace.
“Watch out for everything bigger than you, they have the "right of weight"
Bib
DAKEZ is offline   Reply With Quote
Old 03-22-2013, 03:42 PM   #12
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 54,408
http://www.jimvonbaden.com/Tire_Plugging.html
My vote!
Jim
Old 03-22-2013, 03:49 PM   #13
p0diabl0
Oddometer: 571
I plugged my PR2 with a staple in almost the exact same place - Slime kit and I had no prior plugging experience - it's held for a couple thousand miles with no problems. Just do it.
p0diabl0 is online now   Reply With Quote
Old 03-22-2013, 04:15 PM   #14
Warin
Retired
Oddometer: 2,327
Simple case of risk/reward
If a dealer does it they take the legal liability. Not worth the risk to them for the amount of money they will get.
If you want to save money then YOU have to do the assessment/repair.
I'd put a string repair in it myself. But then that is me for my riding.
Warin is offline   Reply With Quote
Old 03-22-2013, 05:48 PM   #15
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 8,502
Exactly. It's more of a fear of the liability issue than a technical one.
JvB's page shows a correct way to do it.
Go for it.
--Bill
'73 R60/5 Toaster
Times are GMT -7.   It's 10:52 PM.
