Old 03-22-2013, 09:18 PM   #1
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,637
Handy air-lift "losing power".
Confession: I've not even bothered to look underneath the lift yet.. I'm being lazy and asking here first.
I have a standard pneumatic air lift.
It used to lift my 950.
Today it wouldn't go up (even with full PSI coming from the compressor).
I took the bike off, it went right up.
I put my lighter 500 on.. it went right up.
I put my 950 back on- it wouldn't go up.
Is there and adjustment or seal or something I need to address to get it back up to full strength?
It used to lift the 950 without hesitation...
tia!
Cheers,
Ed
Old 03-22-2013, 09:20 PM   #2
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,637
p.s. It is one of these type of lifts (not my photo but one similar)
Old 03-22-2013, 10:33 PM   #3
Droptarotter
Oddometer: 1,274
Can you hear any air leaks??
Try taking the cylinder apart and cleaning, lubing it...........mine was kind of rusty after quite a few years of use.
Could any of the bearing be going bad? Maybe just enough drag to stop the big bike from going up??
Cheers
HP2 Sport, R1200S, R100S, KTM 640 Adventure, KTM 520 EXC/Motard, Yamaha RZ350, Hodaka 125 Wombat
Droptarotter is offline   Reply With Quote
Old 03-23-2013, 05:22 AM   #4
gusanito
Mindless Wonderer
gusanito's Avatar
Oddometer: 238
Give Handy a call and get a new piston seal.
You'll have to pull the cylinder apart, clean it and replace the seal. Make sure the seal is installed in the right direction and oil the cylinder walls before you put it back together.
gusanito is offline   Reply With Quote
Old 03-23-2013, 05:42 AM   #5
vfroger
Not lost, just misguided
vfroger's Avatar
Oddometer: 116
Ensure you haven't crimped the hose to the foot control. Don't ask me how I know.
Roger
Knoxville, TN
vfroger is offline   Reply With Quote
Old 03-23-2013, 06:44 AM   #6
katbeanz
earthbound misfit, I
katbeanz's Avatar
Oddometer: 7,779
I just looked at mine, looks like the (weak) rod end of the cyl is what's used to lift. If you don't hear a leak around the rod seal, bypass the foot valve to make sure it's not sticky and put some light oil down the hose to lube up the cup seal on the piston.
The rod is only exposed when it's down, but sometimes you can lube up the rod and let it work back in. Don't forget the safety latch if you go sticking body parts in there.
katbeanz is offline   Reply With Quote
Old 03-25-2013, 08:48 AM   #7
cross-country
cross-country's Avatar
Oddometer: 1,669
I've had the rear leg "sit" on the hose when in the fully collapsed position, causing a similiar problem. I got in the habbit of pushing the hose over with my foot whenever I lowered the table.
cross-country is online now   Reply With Quote
Times are GMT -7.   It's 06:56 PM.
