Old 03-25-2013, 11:43 AM   #1
Brennan OP
Food & Bikes
Brennan's Avatar
Oddometer: 848
OSM Navigation
I'm shit at this and headed into Istanbul tomorrow with a garmin Montana 600 I ordered on the fly in Bucharest. I've got some silky smooth maps loaded on the device but it won't use the maps to navigate me to a wayloint, POI, etc. Just a straight line from my current location to Istanbul, Sinbad Hostel.
Any guidance would be much appreciated.
p.s. Yeah I slipped a guidance in there, I'm without shame.
Brennan is offline   Reply With Quote
Old 03-25-2013, 05:06 PM   #2
TrotterD
Geek
TrotterD's Avatar
Oddometer: 17
Hello, hope you are well.
It sounds like to me you have routing set up as Direct Routing. If so try changing it in the settings. Open the Draw ^ then Setup -> Routing. Change the Activity setting to Motorcycle Driving or Automobile Driving.
This may work for what you want.
Regards,
Dave
Look where you want to go, not where your going.
TrotterD is offline   Reply With Quote
Old 03-26-2013, 01:54 AM   #3
dlh62c
Oddometer: 1,603
Make sure the maps are 'Enabled' on the Montana.
daryl
Old 03-26-2013, 03:10 AM   #4
9Dave
Bazinga!
9Dave's Avatar
Oddometer: 13,312
Not familiar with "silky smooth" maps - but whatever they are, if they must be created as routable maps by the manufacturer. Otherwise, you will just get a straight line.
Nothing will fix the issue if they are not routable maps.
And my guidance is don't buy a GPS and plan to rely on it on the go. It won't be easy, you will get furstrated, or worse have an accident while fiddling with it instead of paying attention to the road and surroundings.
dunno.....
Old 03-26-2013, 10:03 AM   #5
worwig
Oddometer: 1,277
I assume your maps do not have routing data.
It sounds like you would be better off, and likely cheaper, putting OSMand on an Android device. Then load OSM maps with routing data.
Hog mountain Weather
worwig is offline   Reply With Quote
Old 03-27-2013, 12:08 PM   #6
vintagespeed
fNg
vintagespeed's Avatar
Oddometer: 1,799
about all you can do without a routable map is to lay down a track instead. sucks, but it's better than nothing.
some OSM maps are routable, some/most are not.
530EXCR and a bunch of 2 strokes that you dont want to read about. :)
TAT-2013: http://www.advrider.com/forums/showthread.php?t=913898
SoCal_NoDak-2012: http://www.advrider.com/forums/showthread.php?t=829203
vintagespeed is offline   Reply With Quote
Old 03-27-2013, 10:43 PM   #7
Brennan OP
Food & Bikes
Brennan's Avatar
Oddometer: 848
Regards,
Dave
That was the answer, thanks dude! I forget the stock setting on the Montana that I had to change to "Automotive" but now I have routable OSM maps that worked in Bulgaria and Turkey.
Thanks for the all of the input everyone. For now I have routable maps but I'm not sure if that will still be the case when I head further east.
Times are GMT -7.   It's 07:18 AM.
