Old 03-25-2013, 10:16 PM   #1
JOKER650 OP
JOKER650's Avatar
Oddometer: 1,586
MOTOZ and the SE
Spring is here and it's time to retire
.....and an oil change.
SO I thought I would try out the MOTOZ TRACTIONATOR DESERT.
My locaL KTM/HONDA/BERG/CAN-AM dealer has some prety good prices....$115
It's got "SCOOPS" ...and it's pat-pending
It took 60psi to seat the bead
Mmmm...that feels BETTAaah
Not sure if this shows it verry well...but it has a huge rim saver.(if that's what ya call it)
Decided to try the matching front.
The front also has a different PATENT PENDING tread design
If these tires work and last any where near what the previuos MOTOZ on the rear did...this will be my NEW tire of choice
YUPP......that's 3/4 inch of rubber on a street legal DOT tire for $115
Go measure that new tire you just installed
JOKER650 is offline   Reply With Quote
Old 03-26-2013, 03:04 AM   #2
Rodknee
sensitive? who, me?
Rodknee's Avatar
Oddometer: 2,659
anxiously awaiting a ride report...
Rodknee is offline   Reply With Quote
Old 03-26-2013, 03:08 AM   #3
biggus
biggus's Avatar
Oddometer: 378
I have the same tires on my 06 950S.
I am finishing up a 1 month, 2,000 mile plus ride in Laos riding the Ho Chi Minh Trail. Plenty of hard pack, sand, bull dust, rocks and mud with a few asphalt stretches of 100k or so in between. Ran the front at 18psi and rear at 15 psi. All I can say is great tires and wish I had them before I dented the rims from running those soft walled TKC 80s.
Will be finishing off the trip with about 1,000k of tarmac so will see how they look after that but the look great now. Wear excellent and no chuncking. A very very happy customer.
biggus is offline   Reply With Quote
Old 03-26-2013, 05:45 AM   #4
HooliKen
Awesome is a flavor
HooliKen's Avatar
Oddometer: 3,016
You running stock size rear 140/80-18?
"People in this country sleep peaceably in their beds at night because rough men stand ready to do violence on their behalf." George Orwell
950R Super Enduro - 450EXC - Gas Gas TXT 280 - 2000 Honda XR100R - 1988 Honda Z50R
HooliKen is offline   Reply With Quote
Old 03-26-2013, 06:02 AM   #5
biggus
biggus's Avatar
Oddometer: 378
4.25" and a 140/80/18...
Old 03-26-2013, 06:12 AM   #6
HooliKen
Awesome is a flavor
HooliKen's Avatar
Oddometer: 3,016
How big of a PITA was it to change?
Old 03-26-2013, 07:25 AM   #7
traveltoad
Aaron S
traveltoad's Avatar
Oddometer: 6,740
Hold on... the tire on the left is "worn out"?
traveltoad is offline   Reply With Quote
Old 03-26-2013, 08:38 AM   #8
ABuck99
0.0
ABuck99's Avatar
Oddometer: 608
If you cant get that bead to seat at max of 40psi- deflate , & spray-or add some soap solution to the entire bead of the tire, (murphy's oil soap works great and is non-corrosive) and try again. Its not necessary to use 60psi or more to seat the bead, and it could cause you some safety issues- like exploding the tire, and we dont want to see an inmate taking himself out with a tire explosion- Save the injuries for riding related mis-haps.
Note to LC8 ADV Owners: the SE has a 2.5" rim width which makes fitment of any 140/80-18 including the Motoz with in spec. Mounting a 140/80-18 on the 950/990ADV 4.25" rim width is very much out of spec.
I know there are some inmates that do this regularly, but keep in mind the sidewall profile of the MotoZ 140 mounted on the 4.25" wide ADV rim is stretched over 1.25" beyond engineered safe limit. Load and sidewall strength is compromised. The tire profile becomes quite square- (flat sidewall- flat tread contact) instead of a curved radius which affects on-road handling and off-road hook up. Yes its being done, but it doesn't make it particularly safe. I support anyone's choice to do as they wish, my comments are intended only to inform others that its "non-standard" and to do so at their own risk. I'm stepping off my soap box now.....
KTM: 06 KTM950S & 10 KTM450EXC
ABuck99 is offline   Reply With Quote
Old 03-26-2013, 10:12 AM   #9
Johnf3
Oddometer: 1,055
KTM from the factory specs the Dunlop 908 stock on the Baja Adventure with a 4.25 inch rim. Ya figure they might know a little bit about product liability? One company's tire measurement is not the same as another. Motoz specs this tire on rims up to 3.5 inches. You can look at many pictures of these tires mounted up on stock Adventure rims. They are not "quite square". They may not be perfect but they are not dangerous. Many of us have run these tires many years and tens of thousands of miles. 60 psi won't cause a tire to explode while getting it on the bead either.
Are you sure you ride a motorcycle? They are dangerous you know. Just making sure you are aware.
'06 950 Adventure S
'10 Husaberg FX 450
'01 KTM 520exc
Johnf3 is offline   Reply With Quote
Old 03-26-2013, 11:22 AM   #10
FakeName
Wile E Coyote SuperGenius
FakeName's Avatar
Oddometer: 1,818
I think he makes a legitimate point. People may be doing it (I do) but that does not mean it's technically correct, and I appreciate the observation. And, simply because the KTM chose to use the Dunlop does not mean automatically the Motoz WILL work. As you pointed out yourself, different tires have different profiles.
I've emailed Motoz directly and asked specifically about this application, and will let theis thread know their response, if any.
Worth pointing out though- this is a direct quote from their website:
It's had an overhaul since 2007 and is now 1kg ligher, making it an excellent tyre for adventure bikes and big bore enduro bikes with a 2.5 inch rim used in off road applications.
2011 White 990 Adv S
2014 500EXC Black
FakeName is online now   Reply With Quote
Old 03-26-2013, 11:31 AM   #11
Johnf3
Oddometer: 1,055
Sure it is a legit point. My point is too. Empirical evidence has shown that mounting these tires on a 4.25 inch rim will not specifically cause them to fail.
Also, if you look under "Tyre Selection" on the Motoz website is shows a diagram of the 140 Tractionator on a 3.5 inch rim.
'06 950 Adventure S
'10 Husaberg FX 450
'01 KTM 520exc
Old 03-26-2013, 01:56 PM   #12
ABuck99
0.0
ABuck99's Avatar
Oddometer: 608
[QUOTE=Johnf3;21038401]KTM from the factory specs the Dunlop 908 stock on the Baja Adventure with a 4.25 inch rim. Ya figure they might know a little bit about product liability? One company's tire measurement is not the same as another. Motoz specs this tire on rims up to 3.5 inches. You can look at many pictures of these tires mounted up on stock Adventure rims. They are not "quite square". They may not be perfect but they are not dangerous. Many of us have run these tires many years and tens of thousands of miles. 60 psi won't cause a tire to explode while getting it on the bead either.
Are you sure you ride a motorcycle? They are dangerous you know. Just making sure you are aware.[/QUOTE
Nope, I actually I dont ride a motorcycle, I just hang out in the virtual world of motorcycles and post booshit on threads with out researching facts or thinking at all of who might be looking in. The point is dispelling opinions vs. facts. Some people read posts with broad/generalized opinions like "Many of us have run these tires many years and tens of thousands of miles" or "60 psi won't cause a tire to explode while getting it on the bead either" and figure that its fine to do it and they misinterpret opinion as fact.
Yes I ride (a garage full of bikes), pushing the limits at times like most of us do, and I sell and install lots of tires, MotoZ included. If I were to mount a 140/80-18 on the 4.25 ADV rim, and there was a failure or crash- it would likely come back to me, I would or could be liable, or at least named along with everyone else. So Im a little more sensitive to the liability side of the issue, and why I posted the reply to put the facts into consideration. As soon as the manufacturer puts it in print Im on board. I think I was clear that I support making your own choices- Im not telling anyone not to do it, just that its not legitimately safe to do it. And unfortunately there is no deductible for empirical evidence, it will not protect me from liability.
I am aware of KTM putting the 908RR on the 2013 Baja. I was surprised at that choice vs the factory approved tire- 150/70 TKC80. Since that 990 model is a carry over fluffed & buffed for 2013 and only for the North American market, I question if KTM HQ in Austria and their legal department are fully aware of that KTM US is installing under rated tires on the 990 Baja. I'm not sure that these 990 Baja's are coming from Austria with the tires already mounted- (that is a fact we can research). There is no printed information that I have found that states the 908RR is recommended to be mounted on a 4.25 " rim. Currently the 908RR is spec'd for up to a 3.5" rim. Wondering about this weeks ago, I called Dunlop to ask about putting these on a 4.25" rim and the CSR I spoke told me that they could not recommend it. CSR said 4.0 rim width was possible but they still would not endorse or recommend it. I called KTM USA, and asked the same questions, and the CSR I spoke to had virtually no idea about the tire spec, or its limitations. On the KTM website, the 908 is not even spec'd as a factory approved tire. So maybe we're missing some information like Dunlop has made a special tire just for KTM (which they have not), or KTM is putting a 2.5" SE wheel on that bike(which they currently are not). Otherwise they are potentially opening themselves up to liability in the event of a crash claim.
Here are some links to factual data:
KTM Approved Tire List http://www.ktm.com/uploads/tx_downlo...07-2012_gh.pdf
Dunlop 908 Specs:
http://www.dunlopmotorcycle.com/tire...nture/d908-rr/
Old 03-26-2013, 02:18 PM   #13
dogsslober
No neck tie, Ti neck
dogsslober's Avatar
Oddometer: 931
Moto z on a SE
Man this thread took a wrong turn fantastic tire tho
dogsslober is offline   Reply With Quote
Old 03-26-2013, 02:23 PM   #14
traveltoad
Aaron S
traveltoad's Avatar
Oddometer: 6,740
Have you tried one on your SE?
Any feedback how "bad" they are on tarmac?
Old 03-26-2013, 02:28 PM   #15
dogsslober
dogsslober's Avatar
Oddometer: 931
Yes
I will not buy another 908 ever! Love the motoz.good as any other knobby on pavement
Times are GMT -7.   It's 08:46 AM.
