Old 03-27-2013, 05:20 PM   #1
Bleemus OP
Oddometer: 1,138
UNlowering a 1999 F650 Strada SE? Can it be done?
I have a line on a 1999 F650 SE for a fair price. This one has been lowered. I have sat on one that has been lowered before and found it too low for comfort. Being a newbie to F650s is it possible to undo the lowering myself or is it something permanent that I cannot undo? Sorry if this is a stupid question. Long time lurker ready to join into the fray.
Bleemus is offline   Reply With Quote
Old 03-27-2013, 06:36 PM   #2
Scottysix9
Shhh...
Scottysix9's Avatar
Oddometer: 919
Yes, it can be done. The rear end components are the same for both the ST & the Fundo.
To raise it you will need new linkage plates and remove the spacer on the spring. Then drop the forks. A stock side & center stand will be needed as well. Or have yours extended.
The ST has an 18" front wheel vs. the 19" on the Funduro so it will be a bit lower.
BMW 650 KDX 220 TS 400
If they can't hear you, they won't know you're there.
Scottysix9 is offline   Reply With Quote
Old 03-27-2013, 07:14 PM   #3
Bleemus OP
Oddometer: 1,138
Thanks for the reply Scotty. Are these mods you mention expensive enough to modify my offer?
A Funduro should be fun right?
Times are GMT -7.   It's 11:04 AM.
