Old 03-27-2013, 07:45 PM   #1
scrubby81 OP
Auto Builder
Oddometer: 138
Resurecting a 85 with 457 miles...
I just picked up a barn fresh 85 Yamaha maxim 700 with only 457 miles on it. I cleaned all the grime off it that did not blow off in the ride home on the truck. So my idea is to get it going new tires ( org dry rotted to nothing ) run threw the carbs, but what else to look for at? Brakes are good free and not delamating forks are not leaking oil in engine is clean and going to be changed again but is the valve springs ok? timing chain ? ran a bore scope down it and cylinders are very clean no rust! Looking for tips hints or just tell me what to do lol thanks y'all
Depending on the day its a goodin or its a
Thanks Scrubby
scrubby81 is offline   Reply With Quote
Old 03-27-2013, 07:46 PM   #2
scrubby81 OP
Auto Builder
Oddometer: 138
Thanks Scrubby
Old 03-27-2013, 07:47 PM   #3
scrubby81 OP
Auto Builder
Oddometer: 138
Thanks Scrubby
Old 03-27-2013, 07:48 PM   #4
scrubby81 OP
Auto Builder
Oddometer: 138
Thanks Scrubby
Old 03-27-2013, 07:48 PM   #5
scrubby81 OP
Auto Builder
Oddometer: 138
Thanks Scrubby
Old 03-27-2013, 08:14 PM   #6
matey peeps
Bead Buddy
matey peeps's Avatar
Oddometer: 3,326
New battery, clean the carbs, fresh gas, oil change, and I bet you could ride the wheels off it with not a whole lot of work.
matey peeps is offline   Reply With Quote
Old 03-27-2013, 10:01 PM   #7
Beezer
Oddometer: 5,737
would only add a brake flush to that list
Beezer is offline   Reply With Quote
Old 03-27-2013, 11:03 PM   #8
troidus
Oddometer: 14,289
I would worry about the valvesprings having taken a set, so don't wind it out to redline. Also, it was parked for a reason. Maybe it needs a 500 mile service (valve adjustment on mine), so do more than just put oil and gas in it and ride it. Check the fuel tank for rust, change the fork, shock, and diff oil, and replace any rubber lines on it such as fuel, vacuum, and brake lines. Check the carb boots for cracks and see if they're still pliable. Make sure the air filter is sound; you don't want a "looks good" air filter to disintegrate on first startup and fill the engine with debris. Also, the cylinder bores may be clean, but the rings may be gummed up, so when you do get it rideable, take it easy until it's fully warmed up.
Check your wheel and suspension bearings to make sure they're smooth. They've been sitting in one spot for 20+ years and may have flat spots. Also, make sure the seat leather is still supple before planting your butt on it. It may need some work before trying to use it.
troidus is offline   Reply With Quote
Old 03-28-2013, 01:03 AM   #9
scrubby81 OP
Auto Builder
Oddometer: 138
carb boots are good, bearings are checked and repacked, tires are on order carbs are soaking new air filter oil filter on bench, haven't had to change fork oil before ? Pull forks off or leave them on tree and how is this done? Will order new valve springs in the am when parts houses are open just to be sure, think I should get fork seals at same time?
Thanks alot for the input
Thanks Scrubby
Old 03-28-2013, 01:07 AM   #10
scrubby81 OP
Auto Builder
Oddometer: 138
a
Thanks Scrubby
scrubby81 screwed with this post 04-06-2013 at 05:13 PM
Old 03-28-2013, 07:41 AM   #11
Johnf3
Oddometer: 1,050
That's a Maxim "X". It has a version of the engine right out of the old FZ sport bikes. Once it spins up, it rips pretty good. You will have fun with that one. You don't see very many around.
'06 950 Adventure S
'10 Husaberg FX 450
'01 KTM 520exc
Johnf3 is offline   Reply With Quote
Old 03-28-2013, 09:12 AM   #12
scrubby81 OP
Auto Builder
Oddometer: 138
? A maxim X? not sure what that means other than a package or trim level will this change parts that I should have ordered?
Thanks Scrubby
Old 03-28-2013, 10:07 AM   #13
Johnf3
Oddometer: 1,050
Maybe it is not the X version. My memory of the 80's is not good. The X was water-cooled. Sorry for the mis-information.
'06 950 Adventure S
'10 Husaberg FX 450
'01 KTM 520exc
Johnf3 screwed with this post 03-28-2013 at 10:18 AM
Old 03-29-2013, 07:56 AM   #14
scrubby81 OP
Auto Builder
Oddometer: 138
Got motor torn down, looks great no rust, now for the tar that was in the carbs that was fun only got one cleaned up so far...
Thanks Scrubby
Old 03-29-2013, 08:34 AM   #15
Boatman
Upward and onward!!
Boatman's Avatar
Oddometer: 10,269
Pine Sol is your friend!!!
08 KTM 950 SE, 09 KTM 950 SE, 04 KTM 950 ADV, 10 Husaberg FE390, 66 Kawasaki B8S Super 150
Hi/low beam conversions for: Trail Tech, Baja Designs
Boatman is offline   Reply With Quote
Times are GMT -7.   It's 09:07 PM.
