Old 04-06-2013, 04:57 PM   #61
scrubby81 OP
Auto Builder
Oddometer: 138
Depending on the day its a goodin or its a
Thanks Scrubby
scrubby81 is offline   Reply With Quote
Old 04-06-2013, 05:01 PM   #62
scrubby81 OP
Auto Builder
Oddometer: 138
Been hammering on this all day on and off today. Sorry the pics are out of order but you get the just of it. Two carbs are still stuck thinking time to try some more drastic measures tonight.
Thanks Scrubby
Old 04-07-2013, 11:33 PM   #63
scrubby81 OP
Auto Builder
Oddometer: 138
Thanks Scrubby
Old 04-07-2013, 11:35 PM   #64
scrubby81 OP
Auto Builder
Oddometer: 138
Thanks Scrubby
Old 04-07-2013, 11:35 PM   #65
scrubby81 OP
Auto Builder
Oddometer: 138
Thanks Scrubby
Old 04-07-2013, 11:37 PM   #66
scrubby81 OP
Auto Builder
Oddometer: 138
Thanks Scrubby
Old 04-07-2013, 11:38 PM   #67
scrubby81 OP
Auto Builder
Oddometer: 138
Thanks Scrubby
Old 04-08-2013, 06:26 AM   #68
McJamie
STROMINATOR
McJamie's Avatar
Oddometer: 1,380
It does look like the mileage is legitimate, but that's not an original front tire( I can't see the back one ). The front is a Bridgestone F11, not an OEM tire. You can still buy them if you wanted to.
The Maxim X was basically the same chassis and running gear, but with a liquid cooled 5-valve motor, based on the FZ750, but with the cylinders upright, instead of angled downwards, and side draft carbs instead of down draft ones. They were nearly 100 horsepower, compared to about the 65 -70 of the air cooled model. Pretty rare, and pretty quick.
If you get far enough away, you'll be on your way home.
Piss off, I'm in my Happy place.
McJamie is offline   Reply With Quote
Old 04-08-2013, 09:38 AM   #69
scrubby81 OP
Auto Builder
Oddometer: 138
Front tire is a bridgestone spit fire hard to read with all the dry rot they are going in this week for renew lol getting new rubber haven't decided on what yet.
Thanks Scrubby
Old 04-08-2013, 02:27 PM   #70
zap2504
Dave E.
Oddometer: 618
Metzler ME880s work well.
Here's the info repository Chacal (XJ4ever) has amassed: http://www.xjbikes.com/Forums/viewforum/f=23.html
...and his current list of available parts (with specific model info integrated - not a whole lot of the XJ700 was used on other XJs):
http://xjbikes.com/Forums/viewtopic/t=2584.html
zap2504 is offline   Reply With Quote
Old 04-09-2013, 08:47 AM   #71
baloneyskin daddy
bikaholic
Oddometer: 2,102
Make sure to put those old tires on Craigslist,they have good tread on them yet.
baloneyskin daddy is offline   Reply With Quote
Old 04-13-2013, 10:06 AM   #72
scrubby81 OP
Auto Builder
Oddometer: 138
Thanks Scrubby
Old 04-13-2013, 10:08 AM   #73
scrubby81 OP
Auto Builder
Oddometer: 138
fender primed tank wet sanded and reprimed again having trouble getting this primer to lay down like I want.... tires are on it bearings and rear brakes done doing the fronts after I finish the paint work
Thanks Scrubby
Old 04-17-2013, 01:57 PM   #74
scrubby81 OP
Auto Builder
Oddometer: 138
well been threw the carbs six times just tool them to a local shop and the dam thing still wont run no fuel getting to the fire anyone got any ideas yes there is fuel in carbs and valves are working im out of ideas if i rip them of one more time and put all back together it dont run got parts for sale lots of new parts...
Thanks Scrubby
Old 04-17-2013, 04:37 PM   #75
zap2504
Dave E.
Oddometer: 618
No idea how experienced your local shop is in Hitachi carbs, but it is real easy to not be successful the first time around. They were all taken completely apart - right? All jets/emulsion tubes? Like, even the idle fuel mix needle valve that should be under the EPA aluminum plugs at the top/rear of each carb (right beside the enrichment valves that also should have been removed)? Microscopic jet pressed into the bottom of the float bowls is clean, right? If completely apart, you can use an ultrasonic cleaner (or just a mechanical agitator like an electric sander or such) with Pinesol or Yamaha's carb cleaner. I gave it to you previously, but here is one of the definitive guides on cleaning the XJ carbs: http://www.xjbikes.com/Forums/viewtopic/t=14692.html
Times are GMT -7.   It's 04:50 PM.
