Old 03-28-2013, 01:30 PM   #1
Clayman18 OP
Oddometer: 5
Question.99' LC4 Enduro Rattle 5th gear low rpm
I just got a 99 Lc4 Enduro, has 12000 miles oil changed every 2500 miles and bearing replaced at 3,000 miles. This thing runs great! Valves Adjusted Every 4,000 Miles. I noticed today on the highway at 50 mile an hour shifted into 5th and rolled on the throttle and a clatter sounds like right side and maybe topend. It sounds like maybe timming chain? it stops once its not lugging or the RPMs plane out. This normal?
Clayman18 is offline   Reply With Quote
Old 03-28-2013, 01:36 PM   #2
bomber60015
Anatomically Correct
bomber60015's Avatar
Oddometer: 14,715
pre-ignition? have you changed the brand of gas you're using?
lugging the engine is bad. Stop it.
"Here is your country. Cherish these natural wonders, cherish the natural resources, cherish the history and romance as a sacred heritage, for your children and your children's children. Do not let selfish men or greedy interests skin your country of its beauty, its riches or its romance. T.R.
Old 03-28-2013, 01:42 PM   #3
Clayman18 OP
Oddometer: 5
lol I only use 100% gas Premium octane. I'm not really lugging it, I can be going 65 and roll on throttle and it will clatter until the RPM levels out then quite again.
Old 03-28-2013, 02:11 PM   #4
Droptarotter
Oddometer: 1,296
Are you sure it's not the drive chain slapping the swing arm slider??
Cheers
HP2 Sport, R1200S, R100S, KTM 640 Adventure, KTM 520 EXC/Motard, Yamaha RZ350, Hodaka 125 Wombat
Droptarotter is offline   Reply With Quote
Old 03-28-2013, 02:25 PM   #5
Clayman18 OP
Oddometer: 5
Yeah I checked drive chain.
Old 03-28-2013, 02:56 PM   #6
dolphins13
orange rules
Oddometer: 138
If your geared at 17/42 or even 16/42? That is lugging on my bike. (I have a 99 lc4e and its perfect) I have 16/42 and my bike cruises at 50 in 4th and I dont hit 5th til 60. If my cruise goes under 55 then I'm hitting 4th again. 17/42 would be really lugging in 5th at 50mph? Not sure about your noise tho? Hope it's nuttin serious?
dolphins13 is offline   Reply With Quote
Old 03-28-2013, 03:10 PM   #7
Clayman18 OP
Oddometer: 5
Yeah Dolphin you probably right its not to peppy in 5th going 50, as I said I just got the bike not use to the whole enduro scene. I'm going to put some good miles on this weekend and get a feel fo the thing! As of now tho im liking it alot!
Old 03-28-2013, 03:40 PM   #8
Droptarotter
Oddometer: 1,296
If you are lugging the motor...........that drive chain will really slap around and hit the swing arm............have another look at that........well.....don't really look at it while riding!!
Just try revving the bike higher in lower gears and see if the problem dissapears.
Cheers
Old 03-28-2013, 06:03 PM   #9
ChrisC
Amal sex?
ChrisC's Avatar
Oddometer: 6,316
Putting a 4 mm thick piece of closed cell foam between the plastic slider and top of the aluminum swing arm will really reduce any noise from the chain impacting the slider...
Chris
1974 Bultaco Sherpa T 350
1943 BSA M20WD
ChrisC is offline   Reply With Quote
Times are GMT -7.   It's 02:00 PM.
