Old 03-30-2013, 08:11 PM   #46
RichBeBe
All Hail Seitan!!!
RichBeBe's Avatar
Oddometer: 6,278
Originally Posted by 06CCDMAX View Post
All engines have a power band, 2-Ts tend to have a narrower one. You can always go to an adjustable powerband though... http://kalecoauto.com/index.php?main...products_id=36
No dice on a chain shrinker. I'd start with a sheet-metal shrinker and start modifying. F*ck the "man" and all he tries to get out of you.
That site has all of the best stuff.
"Remember that an enduro tests the endurance of three things: your machine, your body, and your wits. Only one has to fail to keep you from reaching the finish line." Cycle World March 1966
RichBeBe is offline   Reply With Quote
Old 03-30-2013, 08:15 PM   #47
06CCDMAX
Johnny 2-Stroke
06CCDMAX's Avatar
Oddometer: 20
I was gonna recommend the cross-drilled brake lines. I installed them in my truck. Cut my commute time in half. No longer would a red light make me stop. Did notice slight increase in wear on my front bumper but that's to be expected. Bike will get'em next.
2012 KTM 300XC Plated Dirtbike Ring-Ding-Ding
1974 RD250 Got on trade for XS400 (That I bought for $50 )
1975 RD350 Bought for parts, but wanna put on road now.... 1984 RZ350 Why not?
"I run on Caffeine and Klotz. Beer is a bonus
Originally Posted by kenny61 View Post
You wanna tag some poles together?
06CCDMAX is offline   Reply With Quote
Old 03-30-2013, 08:15 PM   #48
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,820
Sv is a 4stroke they don't use power bands
Old 03-30-2013, 08:19 PM   #49
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,820
Originally Posted by Transpomgr View Post
Maybe it's a bakers dozen kinda thing? If you take one or two links out of every chain you buy to make them the "right" length on installation, after a hundred or two new chains, you can put all the links together to make one free chain.
You've got this wrong, they aren't robbing you, they're being charitable. I wish more companies would do that.
Well, you'd spend a fortune in master links.
Old 03-30-2013, 09:30 PM   #50
Warin
Retired
Oddometer: 2,268
Originally Posted by baloneyskin daddy View Post
Maybe he got one of them new fangled pre stretched chains.
Do they go with his shrunk swing arm?
Or have the sprokets expanded? They should make adjustable sprokets to match the chains as they ware... Need someone into recycling (or should that be rechaining )
Warin is offline   Reply With Quote
Old 03-30-2013, 09:38 PM   #51
max384
Disgruntled Student
max384's Avatar
Oddometer: 3,549
That's why it's so important to spend the extra money to get your swingarm hardened before you put too many miles on the bike.
'09 Suzuki SV650, '02 KLR250, CRF70 and 80 for the kids IBA # 56419
Newfoundland 2012
James Bay 2014
max384 is offline   Reply With Quote
Old 03-30-2013, 09:52 PM   #52
notrivia OP
Oddometer: 62
Mein Gott! Vat is dat Linkage ...
I never for a moment thought that I was offering comic reprieve, but hey, if checking to see if the engine bolt holes have widened or the sprocket size is slightly larger than it should be, have at it guys. As for chain stretch, that is commonly done by all manufacturers, as far as I know. And As far as I and you all should be concerned, do we really want to pay TWICE as much TWICE as often because a simple technical question "Why is a new chain of correct specification already halfway gone" not answered?
We deserve an answer.
notrivia is offline   Reply With Quote
Old 03-30-2013, 10:38 PM   #53
max384
Disgruntled Student
max384's Avatar
Oddometer: 3,549
Wicked
Okay, well here is my serious answer:
If this is indeed a real issue (which I don't think it is, at all, no offense), I think you should be pointing the finger at the bike manufacturer(s), not the chain manufacturers. A chain is a chain. They are designed to fit thousands of different bikes. They are manufactured to a specification to be used on many motorcycles. The bike engineers would be the ones who would need to design the engine, swingarm, and sprocket(s) placement so that the swingarm adjustment would be all the way forward with a new chain.
My guess is that they purposefully designed it so that a chain with the recommended number of links on stock sprockets would fall in the middle of the swingarm adjustment range. This way, if a chain manufacturer built a chain that was a little shorter or a little longer, it would still work.
Go take a look at brand new bikes at your local dealer. See if they come from the factory with a chain that sits right about in the middle of the swingarm chain adjustment range. I don't know if I am correct on this, but I would guess that most new bikes do, and do so on purpose.
I truly think you're looking for an answer to an issue that isn't actually an issue.
Newfoundland 2012
James Bay 2014
Old 03-30-2013, 11:19 PM   #54
notrivia OP
Oddometer: 62
Eyesight yields Insight!
A very thoughtful answer Max, with a reasoanble analysis and proposition. The next time I am at a bike shop, I will do so. But if memory serves me right, my new '06 SV650 chain was at the start of the swing-arm mark. Which is a contributing reason for the 33,000 miles I got on that chain. It seems to me that I have a right to expect the same economy since the original specifications were not altered. And certainly not 1/3rd of the life of the stock DID chain with the standard sprocket size and good maintenance. The Emperor is looking for his clothes here partner. There is just too much deviance from an acceptable standard for something fundamental not to be wrong.
Old 03-31-2013, 05:13 AM   #55
kenny61
Crazy Idiot
kenny61's Avatar
Oddometer: 24,757
well if your swingarm is ok and the engine mount holes aren't worn.I think what you need to do is figure out if the chain is reaching its wear limit before it reaches the end of the adjustment range. A quick google search shows this if you checked your manual
You could check the Suzuki SV Manual which would tell you to measure the distance between 21 rivets (20 links). If the length is >12.6", your chain is done.
I would check the owners manual to verify that number but i saw it in a few places so it is probably ok and it appears to be industry standard.
http://www.renthalroad.com/File/chainwheel_fitting.aspx
Since a chain is not only a maintenance item that can leave you on the side of the road it is also a safety issue that can cause a wreck or broken cases I change mine as soon as I detect any binding or noticeable wear in the pins
Also it seems that you are going through a chain every 3 years or so on average. At around 176 bucks for a complete chain and sprocket kit or $58 dollars a year I fail to see how you would be saving big bucks. you could probably save more by using a cheaper chain lube
On the plains of hesitation lie the blackened bones of countless millions who at the dawn of victory lay down to rest, and in resting died.
Go forth and be a force of the awesome!
kenny61 is offline   Reply With Quote
Old 03-31-2013, 05:20 AM   #56
Boatman
Upward and onward!!
Boatman's Avatar
Oddometer: 10,462
Damn,,,, leave it to Kenny to be the man of reason!!
08 KTM 950 SE, 09 KTM 950 SE, 04 KTM 950 ADV, 10 Husaberg FE390, 66 Kawasaki B8S Super 150
Hi/low beam conversions for: Trail Tech, Baja Designs
Boatman is offline   Reply With Quote
Old 03-31-2013, 05:26 AM   #57
kenny61
Crazy Idiot
kenny61's Avatar
Oddometer: 24,757
Thats how I roll
Old 03-31-2013, 07:35 AM   #58
chollo9
Screwed the Pooch
chollo9's Avatar
Oddometer: 1,621
No Not a ruler wiseass.. I have his old micrometers and calibers, ruler and gauge ones
Not trying to be a wiseass, chains need no more accurate a measuring device than a ruler. Pull it tight, measure center of pin to pin down the line a given number of links. There's a standard length plus or minus a tolerance for a new chain, and an acceptable wear limit for when it should be replaced. This part of the discussion is nothing new. The Black Helicopter part, however, is.
"It's not that I don't like people...I just find I am happier when they're not around"
chollo9 is offline   Reply With Quote
Old 03-31-2013, 07:46 AM   #59
kenny61
Crazy Idiot
kenny61's Avatar
Oddometer: 24,757
I dont see what or why black heicopters have anything to do with this
Old 03-31-2013, 08:23 AM   #60
rwf
rwf's Avatar
Oddometer: 125
Remove a link and go for a ride. If you don't have enough slack to do this, I guess the chain was the right length.
"I was going faster than I ever went in my whole life, then I fell off." Little Fauss
rwf is offline   Reply With Quote
Times are GMT -7.   It's 12:01 PM.
