Old 03-31-2013, 03:12 PM   #76
kingby
Oddometer: 87
Originally Posted by notrivia View Post
I ask the cynics to review my first post. Why did my 3rd chain get 9,000 miles and my first 33,000?
Is the 33,000 vs the 9,000 measured using the "super scientific XP aladocious I ran out of adjustment" method or the "measure 12 links and when it stretches more than the manual recommends change it" method?
Either I am missing something or you are? But something is missing here
kingby is offline   Reply With Quote
Old 03-31-2013, 03:17 PM   #77
Warin
Retired
Oddometer: 2,122
Originally Posted by Railbender View Post
I have no easy way to place it under tension to check for any stretch.
By placing it under tension you are not checking for stretch, just taking out the free play.
To place under tension - hang it up on a wall... a hook or heavy nail will do -
Placing a little weight on the end may help displace that grease faster... leave it overnight to be sure.
There are many reasons why one chain will ware faster than another
Differences in the sprockets;
ware
alignment
size
Differences in the care;
lubrication (including environment - dust/water/dirt)
power application
sliders
tension
Differences in the chain;
materials (pin, barrel?, grease,O rings)
quality of manufacture (surface finish, sizing [pin diameter etc], grease quantity)
I'm sure there are other factors too...
one of which would be cost - you cannot get a great chain for a dime.
It behooves us to consider that this issue has a direct and lasting financial impact as one of the prime consumables for our vehicles. Considering the cost, it makes motorcycling implausible as economic transportation for the working class,
Get real! Motorcycling ceased being transport for the working class many decades ago. Small cheap cars are more economical to run than motorcycles and have been for some time.
Notrivaia if you want cheap transport - sell the bike and buy a small car!
Warin screwed with this post 03-31-2013 at 03:33 PM
Warin is offline   Reply With Quote
Old 03-31-2013, 03:31 PM   #78
Railbender
Oddometer: 1,033
It is not my chain that is in question. I'm not putting anymore time into it. As I said until somebody gets off of their butt and actually measures the one in question we are just peeing in the wind. All it would take is a little time and a tape measure.
The shortest distance between two points is boring.
Railbender is offline   Reply With Quote
Old 03-31-2013, 04:22 PM   #79
06CCDMAX
Johnny 2-Stroke
06CCDMAX's Avatar
Oddometer: 20
The OP said he uses stock gearing only.
OP, did you change your sprockets each time you changed the chain?
Did the sprockets look good enough to use again?
What's the story there..... Inquiring minds want to know.
2012 KTM 300XC Plated Dirtbike Ring-Ding-Ding
1974 RD250 Got on trade for XS400 (That I bought for $50 )
1975 RD350 Bought for parts, but wanna put on road now.... 1984 RZ350 Why not?
"I run on Caffeine and Klotz. Beer is a bonus
Originally Posted by kenny61 View Post
You wanna tag some poles together?
06CCDMAX is offline   Reply With Quote
Old 03-31-2013, 05:06 PM   #80
notrivia OP
Oddometer: 62
A The Chain Stretches ...
Thankyou Railbender for your insight.
Thankyou Warin for your info. The comment about a small car is apposite. But I imagine you understand that I would fain to resort to that.
Ah, Kingby, I change my chain when it runs out of the alloted adjustment space or when it can be pulled off the sprocket, as recommended. All the appropriate maintenance was done, as has always been the case in the 17 bikes I've had.
But never in my experience do I remember chain installations being half-way through the adjustment cycle. Hence this post, to discover if others have experienced the same thing or what they may know. It seems to me a crucial matter both for economy and safety.
notrivia is offline   Reply With Quote
Old 03-31-2013, 06:50 PM   #81
06CCDMAX
Johnny 2-Stroke
06CCDMAX's Avatar
Oddometer: 20
.... I change my chain when it runs out of the alloted adjustment space or when it can be pulled off the sprocket, as recommended..
When you run out of adjustment or it can be pulled off the sprocket?
When was the last time you changed the sprockets? Seriously..
Old 03-31-2013, 07:06 PM   #82
bwringer
Gimpy, Yet Alacritous
bwringer's Avatar
Oddometer: 2,187
Chuck said it best...
"I am not able rightly to apprehend the kind of confusion of ideas that could provoke such a question."
—Charles Babbage
1983 Suzuki GS850G, Cosmic Blue
2002 Suzuki Vstrom DL1000, Midnight Blue
2005 Kawasaki KLR685 - Turd II.2, The ReReTurdening
"Do not crinkle your food wrappers loudly. Be considerate to others, or I will bite your torso and give you a disease."
bwringer is offline   Reply With Quote
Old 03-31-2013, 10:20 PM   #83
notrivia OP
Oddometer: 62
Sprocket to Spock?
Every time I change the chain I change the sprockets Max just like the manufacturers conditions. Nothing in any way has been done that is not the normal procedure for the chains. Which prompts the question as to why some ware so quickly and other's haven't. The only clue we have is that my 3rd chain and this most recent were in the middle of the adjustment zone, my first two were at the beginning.
Old 04-01-2013, 11:36 AM   #84
bomber60015
Anatomically Correct
bomber60015's Avatar
Oddometer: 12,222
Notrivia
have you considered it might simply be a mistake in the spec for numbers of links for the stock chair?
or that the spec leaves room to alter your gearing?
my exposure to humans makes be very suspicious of conspiricy theories, as most folks are simply not bright enough to make one work.
Thought this was an April Fools thread, til I saw the date of the first post, btw.
Remove some links and ride.
None of us have enough time to obsess over this . . . . check that . . . you may, but I sure don't.
Enjoy, whatever your decision.
"Here is your country. Cherish these natural wonders, cherish the natural resources, cherish the history and romance as a sacred heritage, for your children and your children's children. Do not let selfish men or greedy interests skin your country of its beauty, its riches or its romance. T.R.
Old 04-01-2013, 03:34 PM   #85
notrivia OP
Oddometer: 62
Too Short!
The individual links are just slightly longer than the adjustment marks, making removing a link too tight a chain. I'm not going to take a chance of cracking my crankcase Atomic, as shown in a pic earlier by Boatman. That's why I replaced the old chain, only to be miffed that the new one, a different brand, showed the same "middle-length", unlike the original chain and My 2nd, a Regina,
which were at the first adjustment mark.
Thankyou for your suggestion.
Old 04-01-2013, 03:54 PM   #86
Dirty in all
Adrenaline Junkie
Dirty in all's Avatar
Oddometer: 168
I know it adds to the cost of new chains but what Im thinking about doing is buying 4 or 5 master links with my next new chain. Then shortening the chain when newly installed, then as the chain stretches Ill cut out a couple stretched links, add a couple of the previously trimed new links and a master link to reconnect. This way it will always be in the shortest of adjustments and Ill get the full stretch out of my chain. I think the chain will even last longer because the newer links will be starting thier stretch cycle in a delayed sequence. The only extra cost really will be the initial puchase of the extra master links but I can just keep those when buying the next chain and repeat from there. Might even save a few bucks by prolonging wear/stretch.
Dirty in all is offline   Reply With Quote
Old 04-01-2013, 03:58 PM   #87
bomber60015
Oddometer: 12,222
Notrivia
I've never heard that the adjustment marks had any relation whatsoever to link length . . . . a quick look in my motor pool says this just isn't the case . . . .
but, hell, man, enjoy yourslef!
Old 04-01-2013, 04:03 PM   #88
kenny61
Crazy Idiot
kenny61's Avatar
Oddometer: 24,576
Originally Posted by Boatman View Post
Ya mean like this......
I'm very surprised to see your cynicism in this most important discussion when it appears you were a victim of a half worn chain problem yourself
On the plains of hesitation lie the blackened bones of countless millions who at the dawn of victory lay down to rest, and in resting died.
Go forth and be a force of the awesome!
kenny61 is offline   Reply With Quote
Old 04-01-2013, 04:05 PM   #89
kenny61
Crazy Idiot
kenny61's Avatar
Oddometer: 24,576
While that may very well work it will not solve the issue of the manufacturers selling us a chain with looser tolerances than what they are supposed to be
Old 04-01-2013, 05:48 PM   #90
Dirty in all
Adrenaline Junkie
Oddometer: 168
OP, is there a chance your bearings are worn both in the wheel and the swing arm pivot? You have ALOT of miles! Making it seem like it is indeed the chain who is at fault? In essence shortening the distance between the sprockets and resulting in the chain seeming to be long???
Times are GMT -7.   It's 07:24 PM.
