Old 04-01-2013, 04:55 PM   #91
notrivia OP
Oddometer: 65
Kudos's to you Kenny!
In the clutch of controversy, when simple facts would seem to elucidate a principal, it is always surprising if not beguileing, that cynicism and derision inhibit the search for a solution. Thankyou for making the case for the seriousness of this issue.
Let us hope my e-mails to EK, Regina, and Suzuki may shed some light on this matter.
It really comes down to a simple matter: who makes an honest chain?
notrivia is offline   Reply With Quote
Old 04-01-2013, 04:58 PM   #92
kenny61
Crazy Idiot
kenny61's Avatar
Oddometer: 24,813
Please keep us informed of their response, After todays spirited ride I had to add 5 clicks on my snails and only have about another 10 left
On the plains of hesitation lie the blackened bones of countless millions who at the dawn of victory lay down to rest, and in resting died.
Go forth and be a force of the awesome!
kenny61 is offline   Reply With Quote
Old 04-01-2013, 05:07 PM   #93
sieg
sieg's Avatar
Oddometer: 2,924
Originally Posted by Dirty in all View Post
I know it adds to the cost of new chains but what Im thinking about doing is buying 4 or 5 master links with my next new chain. Then shortening the chain when newly installed, then as the chain stretches Ill cut out a couple stretched links, add a couple of the previously trimed new links and a master link to reconnect. This way it will always be in the shortest of adjustments and Ill get the full stretch out of my chain. I think the chain will even last longer because the newer links will be starting thier stretch cycle in a delayed sequence. The only extra cost really will be the initial puchase of the extra master links but I can just keep those when buying the next chain and repeat from there. Might even save a few bucks by prolonging wear/stretch.
"Democracy is two wolves and a lamb voting on what to have for lunch.
Liberty is a well-armed lamb contesting the vote" Ben Franklin
Current bikes F800GS-EXCF350-Versys-690R-RZ350
sieg is online now   Reply With Quote
Old 04-01-2013, 05:26 PM   #94
Warin
Retired
Oddometer: 2,331
Originally Posted by kenny61 View Post
I'm very surprised to see your cynicism in this most important discussion when it appears you were a victim of a half worn chain problem yourself
Half worn? The teeth on the contershaft sprocket are hooked... I'd think that chain will be well beyond 5% stretch.
Replacing sections of worn chain with new does nothing for safety nor ware on sprockets... replace the chain - all of it when worn.
Kenny - when the chain starts to go ..it will go rapidly ... replace your chain (and probably sprockets) NOW. Don't wait.
If you want to save money ... replace the chain when only part worn - the sprockets will still be good. When that chain is again part worn - put the old chain back on .. and continue cycling the chains... this way you get more miles from your sprockets. Unfortunaly this is too difficult with "end less" chains - master links are the way to go here .. replace the master links every now and then as a safety measure.
Warin is offline   Reply With Quote
Old 04-01-2013, 05:35 PM   #95
kenny61
Crazy Idiot
kenny61's Avatar
Oddometer: 24,813
E] the hooked sprocket would not cause the chain to break. And its pretty simple to understand his chain would not have broken at that time if it wasnt purchased with the pins undersized a few thousands of an inc
Old 04-01-2013, 05:51 PM   #96
max384
Disgruntled Student
max384's Avatar
Oddometer: 3,557
Do you mean clip-style masters? No way I'd run a clip-style master link on the street.
'09 Suzuki SV650, '02 KLR250, CRF70 and 80 for the kids IBA # 56419
Newfoundland 2012
James Bay 2014
max384 is offline   Reply With Quote
Old 04-01-2013, 05:54 PM   #97
kenny61
Crazy Idiot
kenny61's Avatar
Oddometer: 24,813
Nonsense I have 3 on my xr and 2on my exc with no problems ever
Old 04-01-2013, 06:21 PM   #98
max384
Disgruntled Student
max384's Avatar
Oddometer: 3,557
And I've ridden without a helmet before and didn't die, therefore it's not dangerous...
Newfoundland 2012
James Bay 2014
Old 04-01-2013, 06:31 PM   #99
Boatman
Upward and onward!!
Boatman's Avatar
Oddometer: 10,531
The chain that did that damage had less than 5000 miles and was well within spec. My adjusters were no where near the end of adjustment.
08 KTM 950 SE, 09 KTM 950 SE, 04 KTM 950 ADV, 10 Husaberg FE390, 66 Kawasaki B8S Super 150
Hi/low beam conversions for: Trail Tech, Baja Designs
Boatman is online now   Reply With Quote
Old 04-01-2013, 06:34 PM   #100
kenny61
Crazy Idiot
kenny61's Avatar
Oddometer: 24,813
Just as I thought
That's proof right there. Did u save it?
Old 04-01-2013, 06:37 PM   #101
kenny61
Crazy Idiot
kenny61's Avatar
Oddometer: 24,813
Did you fall and severely impact your head? If not that's like saying I wore a string bikini and nobody laughed at me when you only wore it in your secluded back yard barbecuing. My chain us used as designed every time I ride...big difference
Old 04-01-2013, 07:06 PM   #102
Boatman
Upward and onward!!
Boatman's Avatar
Oddometer: 10,531
Just as I thought
I might have it kicking around somewhere. I'll look. If I have it, it's yours. All you'll need is a master link. ( I prefer clip style)
Old 04-01-2013, 07:08 PM   #103
kenny61
Crazy Idiot
kenny61's Avatar
Oddometer: 24,813
I don't want to run it. Just test it
Old 04-01-2013, 07:30 PM   #104
Dirty in all
Adrenaline Junkie
Dirty in all's Avatar
Oddometer: 168
Now we're into a whole new subject. Some tool company decides it's better to run a rivet on your chain instead of a clip to sell more rivet tools. Probably brothers with bad blood, one owns the tooling company and the other the clip manufacturing company. I can tell you how Ive seen rivets come loose. Not once have I seen a C clip come off, especially if you safety wire it on like the racers do. Not to mention I can find the end of my chain and keep track of the stretched links that need replacing.
Dirty in all is offline   Reply With Quote
Old 04-01-2013, 07:43 PM   #105
max384
Disgruntled Student
max384's Avatar
Oddometer: 3,557
My point was that anecdotal evidence is not nearly proof enough to call my post "nonsense." You have a total of five clip links and none of them failed. That is hardly an exhaustive study.
Look around the internet; it is full of stories of failed clip links. Sure, a failed rivet link will pop up once in awhile, but you can't deny that it happens far more often with clip links. Clip link guys commonly counter that it's most likely because they were installed incorrectly. That's fine and all, but they seem to be installed incorrectly quite a bit judging by how often they fail compared to rivet links.
Riveting a chain is easy, and it's cheap insurance in my opinion. Other than the initial cost of the tool (I got my Motion Pro riveter for about $70 if I'm recalling correctly), I can't see a real downside to riveting over clip.
Newfoundland 2012
James Bay 2014
Times are GMT -7.   It's 06:41 AM.
