Old 03-30-2013, 01:28 PM   #31
Low594
Adventuring Creep
Low594's Avatar
Oddometer: 1,130
Looking good!
Low594 is offline   Reply With Quote
Old 03-30-2013, 01:35 PM   #32
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,553
That looks like ton of fun. BTW they sell mandrel bent tubing so you don't have to make all those cuts for your next exhaust.
something similar must be in the UK
http://www.mandrel-bends.com/catalog...l-16-gauge-53/
We're not out here to rough it. We're here to smooth it . Things are rough enough in town.
Nessmuk
Old 03-30-2013, 01:38 PM   #33
muttley92 OP
Oddometer: 66
Thanks for that, I'm sure they do but mine cost a total of about 40, I have the satisfaction of knowing I made it and it just looks cool
muttley92 is offline   Reply With Quote
Old 03-30-2013, 02:06 PM   #34
Ironhead
But Itsa Dry Heat
Ironhead's Avatar
Oddometer: 772
what do you get if you combine and RS 125 and a 640 LC4???
The British version of "Hold My Beer And Watch This"???
"I wanta be the man that my dog thinks I am"
" Lord grant me patience, because if you grant me strength, I'll need bail money and a lawyer to go along with it"
Ironhead is offline   Reply With Quote
Old 03-30-2013, 04:08 PM   #35
muttley92 OP
Oddometer: 66
Clocks
I opted for the koso clocks because they come with their own temperature sensors and they look awesome
Old 03-30-2013, 04:13 PM   #36
muttley92 OP
Oddometer: 66
Fairings
from this
to this
Old 03-30-2013, 04:16 PM   #37
muttley92 OP
Oddometer: 66
Finished the exhaust
Old 03-30-2013, 04:19 PM   #38
muttley92 OP
Oddometer: 66
I got a seat cowel too
Old 03-30-2013, 04:20 PM   #39
muttley92 OP
Oddometer: 66
Got the tank back too
Old 03-30-2013, 04:22 PM   #40
muttley92 OP
Oddometer: 66
Headers
Because the headers were a little close to the cooling pipes i wrapped them
Old 03-30-2013, 04:28 PM   #41
muttley92 OP
Oddometer: 66
First proper run
So it ran properly for the first time with a complete exhaust system. and it made a horrid knocking noise.
http://www.youtube.com/watch?v=uSKuxUwipiQ
so I opened the top and found that the needle bearing had collapsed and caused this
http://www.youtube.com/watch?v=aqR0PApUiHs
Also knackered the camshaft. So much love for the T**t that sold me this engine. I've ordered a new camshaft and relevant bearings/ seals. It'll get done eventually, most likely in summer due to looming exams. This is my current state.
Old 03-30-2013, 08:17 PM   #42
Donkey Hotey
De Jo Momma
Donkey Hotey's Avatar
Oddometer: 11,504
Originally Posted by muttley92 View Post
That was considered. It's 3mm stainless 304 on both sides, since the engine deadweight is only around 40kg max and majority of the weight is on the rear mount I think it will be just fine. But I'll keep an eye on it and if it should crack I'll find a solution.
Dead weight is nice. That's your statics class. Have you taken dynamics? What about when that thing starts up and flexes those welds to death? The LC4 is known to be a paint shaker. I'd seriously rethink the design of that front mounting system.
Also: the LC4 doesn't need an oil tank at all. The original engines didn't have one, nor did the strictly off-road models. The oil capacity was to add some extra oil to wear out and burn, as well as a place to mount an external oil filter. On the original design, the filter was located where the e-starter lives now.
Have you considered something like an automotive remote filter mount and using the largest oil filter you can find? That should add 500cc of capacity and a filter without having to worry about that oil tank failing.
Donkey Hotey is offline   Reply With Quote
Old 03-31-2013, 03:52 AM   #43
muttley92 OP
Oddometer: 66
As mentioned before, I am well aware that these engines vibrate. I have done dynamics and vibrations, I'll keep an eye on it and if it cracks I'll do something different. Oil filters tend to be round. There isn't much space, the tank I've made fits nicely in the frame and there's no reason it should fail, there are several brackets on it that I just don't have photos of. But you get the just. The extra capacity won't hurt and it will lower the oil temperature. Can't be a bad thing. At the moment I'm more bothered about fixing the engine...
Old 04-02-2013, 01:46 PM   #44
sam_2555
Oddometer: 21
You've got some skills mate
Ben, I had no idea you were fabbing so much up yourself! Fair play mate, you've got some skills.
I'm pretty jealous at how well yours is turning out. Liking the black and orange colours.
I hadn't even thought of wrapping the headers to save the rad/cooling system. Definitely going to be doing that I think.
Keep up the good work (time permitting).
sam_2555 is offline   Reply With Quote
Old 04-02-2013, 06:17 PM   #45
clintnz
Trans-Global Chook Chaser
clintnz's Avatar
Oddometer: 3,425
That is some great work, that thing is going to be a tiny monster when it's done.
x2, no big deal though, IMHO all those tabs need is a rib welded down one side to stop side-side flex. For a few grams of steel you'd gain a lot of strength.
On the oil system, if you are using the standard circuit, be aware that the big end bearing will be getting no oil while your tank fills up. That's why it's standard practice on the 640 to fill the frame separately & bleed out the air so the crank gets oil asap.
That cam bearing failure is a bastard, haven't seen that before. I've always replaced that bearing & the other end one on mine when doing the cam followers (which are known to wear out) cos they're cheap but they've never been worn. Good luck with getting that sorted & I look forward to further updates.
Cheers
Clint
'03 KTM 640 LC4 Enduro
The wilderness, the desert - why are they not crowded
.................................................. .....with pilgrims?
clintnz is offline   Reply With Quote
Times are GMT -7.   It's 11:58 PM.
