Old 06-30-2013, 09:12 AM   #61
muttley92 OP
Oddometer: 66
A quick update. The camshaft has been changed! The engine is back together with fresh water pump seals too. It should be back in the frame tomorrow. I have a higher pressure rad cap to put on and a filler neck to make up before it will run again. And then the tank needs sealing. Should be a good week
muttley92 is offline   Reply With Quote
Old 07-13-2013, 12:40 PM   #62
muttley92 OP
Oddometer: 66
It runs! No nasty knocks or noises this time. Will soon have it back together. The tank has been sealed and should be leak proof. I've made up a battery box and had to relocate the filler neck, just waiting on some rad hoses and it'll be ready to mot! Can't wait to ride this thing!
Old 07-13-2013, 02:18 PM   #63
Kennon
Kennon's Avatar
Oddometer: 323
good to hear how far its come now.
Kennon
2009 Yamaha Jog 50RR LC sold 2011
2011 Rieju Marathon Pro 125 SM sold 2013
1990 Honda VFR 400 NC30 purchased 2013
Kennon is offline   Reply With Quote
Old 07-13-2013, 02:46 PM   #64
LC4nicator
Certified Wino
LC4nicator's Avatar
Oddometer: 522
That's a great job mate.
Agree with others regarding the front engine mounts versus vibrations though.
Keep an eye on that.
Once that LC4 starts to rev you'll feel it.
I've had 2 LC4's now.....620SC & the 640 Adventure
Bracing those mounts with some strips would be good insurance.
Make sure that oil tank is filled and bled correctly.
There's a great link on here on that subject:
http://www.advrider.com/forums/showthread.php?t=57107
Also put some wheely bars on it.....you wont be able to keep the front wheel down...HaHaHa!
Will be great to see it run....please youtube.
Cheers from Australia.
Con.
Conman62 in the "other world"......dirtbikeworld.net
The beatings will continue untill morale improves!
2006 KTM 525 EXC
2005 KTM 950 ADV
ARIEL MCC of SA
LC4nicator is offline   Reply With Quote
Old 07-22-2013, 05:17 AM   #65
muttley92 OP
Oddometer: 66
Still waiting on cooling hoses so i knocked up a temporary system to run it up.
http://www.youtube.com/watch?v=I71EnqFUtU4
I'm not sure the temperature guage on the koso clocks read correctly though. It reckons 160C before the rad is even slightly warm and I somehow doubt it. May have to run a temp lowering coolant in it.
On the other hand I bough a haiju battery which is excellent.
It weighs 670g! No joke and was a very reasonable 75.99 it's around 110CCA and has a useful little tester button on top. It doesn't drop off like lead acid batteries do as they crank and it starts the bike no problem.
Old 07-22-2013, 06:15 AM   #66
dnrobertson
Big Bike, Slow Rider
Oddometer: 852
Just found this thread and was going to suggest you go with one of the higher lift cams for more performance, but no point now.
Build looks nice.
David
2005 KTM 640A
2008 Wee-Strom
dnrobertson is offline   Reply With Quote
Old 07-23-2013, 07:08 PM   #67
Mercury264
Once you go Triple...
Mercury264's Avatar
Oddometer: 22,332
Originally Posted by muttley92 View Post
Sam, the wrap is only a tenner, well worth it I think.
Clint, thanks is for that, I'll make sure its full before starting it.
Kennon, im in Loughborough until the end of term.
I've found a guy in Hinckley that does self supporting carbon seat units with integral tanks that reckons he can seal mine inside as im not convinced it won't leak.
Is his name Richard by chance ? If so, small world.....he's my BIL.
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 07-24-2013, 12:55 PM   #68
muttley92 OP
Oddometer: 66
It was indeed. Funny how small the world is really, especially in building bikes. My tank is now leak proof for reference. My cooling hoses have arrived, hoping to test the bike tomorrow depending on the weather.
Old 07-25-2013, 08:37 AM   #69
muttley92 OP
Oddometer: 66
Jetting question
So I took the bike up the road today and it is going to be awesome! wheelies in second no problem... However it is a sod to start when it's hot! I've never actually managed it yet, just to flatten the battery (and it's a long push home). Does anyone know roughly what the jetting is for an FCR 41 with performance exhaust and a cone filter on it? It would be much appreciated.
Old 07-25-2013, 10:22 AM   #70
pennswoodsed
lizards,bugs and me
pennswoodsed's Avatar
Oddometer: 774
HOLY COw!
Build looks nice.
More performance ?!? wouldn't it already have twice the hp and 3-4 times the torque of the original engine ?
Best,Ed
pennswoodsed is offline   Reply With Quote
Old 07-25-2013, 12:11 PM   #71
Randy
Randy's Avatar
Oddometer: 2,451
Best,Ed
Yeah, maybe so. But, if replacing the cam anyway... More is better, ya know...
"some might call it a 'midlife crisis', I prefer to call it a renaissance of thought and action"... "Life is too short to do anything other than that about which you are absolutely passionate."..."Adventure is a frame of mind, set upon by action, not defined by equipment."..."It all boils down to your ability to say "SCREW IT" and really mean it"....Randy
Randy is offline   Reply With Quote
Old 07-25-2013, 12:51 PM   #72
muttley92 OP
Oddometer: 66
5 times the capacity, 4 times the power and 3 times the toque just all over the rev range rather than in 2k at the top just need to sort out the carb settings
Old 07-26-2013, 11:56 AM   #73
yokesman
Oddometer: 530
try starting when hot with the fuel valve closed and no throttle.
yokesman is offline   Reply With Quote
Old 07-28-2013, 09:32 PM   #74
kellymac530
motorcycle addict
kellymac530's Avatar
Oddometer: 1,052
Valve adjustment !!!
On every Lc4 motor I have owned, 3 of them from 400 to 620, if the valves were out of adjustment even a little they were a bear to start especially when hot. It was worse when I swapped to FCR carb from the Mikuni CV on my 400...what a PITA.
Really good valve adjustments always helped and once I got used to the Lc4's that is how I knew it was time to adjust the valves....that is all given that the jetting is right....Valve adjustments are a simple starting point though.
it is easier to ask for forgiveness than permission
kellymac530 is offline   Reply With Quote
Old 08-03-2013, 05:34 AM   #75
muttley92 OP
Oddometer: 66
The clearances were done when the camshaft was replaced. Sorted the hot start issue by taking the air screw out by a half turn. The current jetting is 168, 85, 45. I might go a size or two up on the main depending on a proper test ride after the cooling is sorted. The cooling problem has been put down to the water level in the rad being below the level of the pump, need to make a header tank or get a secondary electric water pump. I'm in Germany for the formula student event at the moment and will be back Monday. Hoping to make some progress then.
muttley92 screwed with this post 08-03-2013 at 07:26 AM
Times are GMT -7.   It's 04:53 AM.
