Old 12-14-2013, 07:47 AM   #91
rocker59
diplomatico di moto
rocker59's Avatar
Oddometer: 15,840
Originally Posted by ph0rk View Post
What's to hate?
How often do you apply the front brake and wish to not apply the rear? I can't think of a single time I wanted that to happen.
Most modern linked brakes are linked at the front lever and the rear pedal operates the rear brakes independently. The linked brakes on my r1200r work brilliantly.
That's not "The Guzzi Way". Keep in mind that Guzzi was first to market with integrated brakes back in the 1970s.
On a Guzzi (California Vintage / 90 was the last with the system), the foot pedal controls the rear brake and one front rotor. The hand lever controls one front rotor. There was a proportioning valve that helped control front/rear bias for the integrated foot brake.
I guess it was that way from the Lemans of 1976, through the California 90 of 2012. The Small Block, Spine Frame, and CARC models never had the Guzzi Integrated Braking System. Only the Tonti-framed bikes.
Rocker59 (aka guzzimike), Aux Arcs
Moto Guzzi Sport 1100
IBA #24873
"Do what you can, with what you have, where you are." - Theodore Roosevelt
rocker59 is offline   Reply With Quote
Old 12-14-2013, 08:07 AM   #92
ph0rk
Doesn't Care
ph0rk's Avatar
Oddometer: 2,089
Well that certainly sounds bass-ackwards
--Semantics are everything.
ph0rk is offline   Reply With Quote
Old 12-14-2013, 10:06 AM   #93
rocker59
diplomatico di moto
rocker59's Avatar
Oddometer: 15,840
My '91 LeMans has the system. Works fine.
IBA #24873
Old 12-14-2013, 02:27 PM   #94
ph0rk
Doesn't Care
ph0rk's Avatar
Oddometer: 2,089
I'm sure I could get used to it, but I can see why some people might hate it.
Old 12-14-2013, 02:28 PM   #95
DFH
270 deg crank
Oddometer: 386
No it doesn't! Got into a horrible tank-slapper at high speed on a LeMans once. Eased off the throttle (as you do) but front end continued lockstop to lockstop, so eased I on the rear brake (as you should) which had the effect of locking the front wheel mid-oscillation. Muggings was instantly flicked up into a handstand to land back into the tank & RHS cylinder head (badly bruised nuts & knee) but my weight landing back on the front of the bike killed the tank-slapper & I was able to pull over in tears of pain. Biggest non-crash I've ever had. I delinked the brakes on my subsequent Guzzi's
BTW Rocker59 the small block Guzzi's had linked brakes as well. I have ridden three different v50 Monza's & two different v65 (one with those horrible pushrod 4 valve heads) and they all had linked brakes.
270 deg crank
DFH is offline   Reply With Quote
Old 12-14-2013, 11:33 PM   #96
Rox
Rox's Avatar
Oddometer: 222
" A ride a day keeps the doctor away...Unless you crash."
2012 Triumph Street Triple R
2002 Moto Guzzi V11 LeMans
Rox is online now   Reply With Quote
Old 12-15-2013, 08:12 PM   #97
rocker59
diplomatico di moto
rocker59's Avatar
Oddometer: 15,840
Must be quite the hard-charger to get an early LeMans into a tank-slapper!
Admittedly, my knowledge of the small block bikes grows weaker the farther back in time one goes. Guess I need to brush up on my V50/V65 info.
IBA #24873
Old 12-15-2013, 11:37 PM   #98
RonS
Out there...
RonS's Avatar
Oddometer: 20,756
What's to hate?
I rarely use the rear brake. Low speed maneuvers in parking lots and off road on dirt bikes/dual sports is about it. When you need to brake, the rear does not provide any breaking capability. It’s simple physics. Too little weight back there when you’re breaking hard.
RonS is offline   Reply With Quote
Old 12-16-2013, 05:22 AM   #99
ph0rk
Doesn't Care
ph0rk's Avatar
Oddometer: 2,089
So why not let a computer calculate the maximum amount of rear braking that can be applied in a given stop? I don't lift the rear wheel every time I stop (not that I could with ABS on). I'm not riding a supersport bike, and the rear brake is still able to provide 20-30% of my bike's total stopping power.
In that scenario, using only the front lever on a linked-brake bike will stop you faster than using only the front lever on the same bike with linked brakes disabled. (Assuming BMW, Honda, Yamaha style linked brakes). Maybe my bike is just heavy, but you can feel the rear pedal engage quite a bit in most stops and the rear wheel doesn't lock, nor does ABS engage.
Old 12-16-2013, 05:53 AM   #100
rocker59
diplomatico di moto
rocker59's Avatar
Oddometer: 15,840
Some of us ride motorcycles to get away from computers and other electronic intrusions into our daily lives...
IBA #24873
Old 12-16-2013, 06:05 AM   #101
JohninVT
Oddometer: 641
Exactly!
As far as using/not using the rear brake...if you choose not to, you're giving up a lot of control on a bike. A Guzzi has more rearward weight bias than many bikes and the rear brake is quite effective in shortening your stopping distance vs. Just using the front. It's also helpful in controlling weight transfer, settling the suspension and adjusting your lean angle during cornering.
I've never understood why some people choose not to take advantage of all the performance and control advantages that using the rear brake offers.
JohninVT is offline   Reply With Quote
Old 12-16-2013, 07:01 AM   #102
ph0rk
Doesn't Care
ph0rk's Avatar
Oddometer: 2,089
Originally Posted by JohninVT View Post
Exactly!
Well next someone will say that it is too hard to modulate both the rear brake and the front brake in a hard stop without locking up the rear, the front, or both. (Which is of course the point of the computer).
And, if stopping quickly is a good thing, a smart linked braking system will do it faster than a human can most of the time without being intrusive or acting weird, and you can still operate the rear brake manually for low speed maneuvers or weight transfers. You can even apply additional rear braking while the linked system is in-use.
If you want to be a luddite, fine, but don't pretend your super-human reflexes are as safe as reflexes plus technological aids. The computers only do what people program them to do, anyway.
Old 12-16-2013, 07:31 AM   #103
rocker59
diplomatico di moto
rocker59's Avatar
Oddometer: 15,840
I modulate front to rear braking bias all the time.
Just like shifting gears, it's something I prefer to do on my motorcycles.
Next thing, you'll be asking why motorcycles still have manual transmissions when a computer can do it better.
IBA #24873
Old 12-16-2013, 11:36 AM   #104
JohninVT
Oddometer: 641
Laugh
Anyone who argues your first point is not coordinated enough to ride a motorcycle. As for your second point, no...it can't. It will make itself obvious every dirt road you ride. I want neither linked brakes nor ABS.
I'm not a Luddite. I have a specific riding style and I don't like electronic aids. I'm also not a fan of throwing technology at solutions which require judgement. Exercise judgement...and you don't need the aids.
I grew up at the end of a ten mile dirt road. I learned to drive and to ride on gravel. I'm not willing to change how I've ridden for more than twenty years because the EU wants to protect everyone from themselves.
Back to the wonderful Griso. A beautiful, great Guzzi that doesn't have ABS or linked brakes.
Old 12-16-2013, 12:13 PM   #105
DFH
270 deg crank
Oddometer: 386
Not really. Caused by another Guzzi early tech adoption that was not well executed. Early LeMans & V50 Monza's had cartridge forks, the first I had ever come across. Sadly the cartridges looked like they came from the same factory that made flyscreen doors & were prone to bending & binding. Once that happened the forks would become unpredictable & stiction prone. And slappy on bumpy roads. The gun mod at the time was to fit Marzzochi damper rod forks believe it or not. A friend had a V50 Monza with replacement aftermarket cartridges from Paoli. That setup was brilliant.
As someone with history with old Guzzi's riding a 4-valve/cylinder 1200 Griso for the first time was a revelation. Wish I could afford one!
270 deg crank
Times are GMT -7.   It's 11:31 PM.
