Old 04-17-2013, 09:15 AM   #76
kentnothstine
kentnothstine's Avatar
Oddometer: 615
2008 XT250(the new one for her to use)
2003 KLX400SR (the new one)
1997 Ural 650cc (SOLD)
Originally Posted by Thanantos View Post
Once your crotch gets wet it's all over.
kentnothstine is offline   Reply With Quote
Old 04-17-2013, 10:39 AM   #77
mikesova OP
mikesova's Avatar
Oddometer: 1,938
Originally Posted by kentnothstine View Post
You'll have to ride it. Kind of like the bear on the tiny bicycle...
2009 Kawasaki KLX250S
2005 Yamaha TW200 (Wife's bike)
2005 Yamaha FZ6
2009 Honda Ruckus
mikesova is offline   Reply With Quote
Old 04-17-2013, 11:04 AM   #78
kentnothstine
Oddometer: 615
Something like this?
Or would this be more appropriate?
Old 04-17-2013, 11:49 AM   #79
mikesova OP
mikesova's Avatar
Oddometer: 1,938
I like both!
For reference, this is Kent sitting on my FZ6:
2005 Yamaha FZ6
2009 Honda Ruckus
mikesova screwed with this post 04-17-2013 at 11:59 AM
Old 04-17-2013, 07:40 PM   #80
mikesova OP
mikesova's Avatar
Oddometer: 1,938
I ordered some new pegs for the front, since the right side had a mismatched peg.
They are for a Yamaha R bike, but the mounting part looks identical.
2005 Yamaha FZ6
2009 Honda Ruckus
Old 04-17-2013, 10:01 PM   #81
JerryH
Oddometer: 5,069
I would pull the plugs and put some oil in the cylinders if you have not already turned it over. Check the oil, if it looks like black paint, I'd change it. Otherwise ride it a few miles first.
I currently have 6 bikes running, registered, insured, and ridden. I have had as many as 11.
JerryH is offline   Reply With Quote
Old 04-18-2013, 10:11 AM   #82
mikesova OP
mikesova's Avatar
Oddometer: 1,938
I did turn it over a few days ago when I hooked up a battery. I guess I got lucky, since I didn't pour any oil or WD40 into the cylinder.
Holy cow, that's a lot of bikes to plate. I mean, I definitely subscribe to the "a different tool for a different job" theory...but man.
2005 Yamaha FZ6
2009 Honda Ruckus
Old 04-19-2013, 10:03 AM   #83
mikesova OP
mikesova's Avatar
Oddometer: 1,938
Today is my day off and I'm supposed to be working on a project for a class, but I took a break to try out the exhaust wrap that came in the mail yesterday.
Worked out pretty well. I just have zip ties holding it on right now. I haven't decided if I want to use the stainless zip ties or just use a stainless hose clamp. Any suggestions for something that would look a little cleaner?
I haven't heard back on the carbs yet, they must have really needed quite a soak. The z-bars should be here tomorrow.
I soaked the fuel pump in kerosene for a little bit and let it dry the last couple days. I am planning on picking up a battery tomorrow, so I'm ready to fire it up when the carbs are done.
Still need to check/adjust the valves, not looking forward to it since the only guide I found was text. I like pictures...
2005 Yamaha FZ6
2009 Honda Ruckus
Old 04-19-2013, 03:11 PM   #84
mikesova OP
mikesova's Avatar
Oddometer: 1,938
2005 Yamaha FZ6
2009 Honda Ruckus
Old 04-19-2013, 04:52 PM   #85
mikesova OP
mikesova's Avatar
Oddometer: 1,938
Pipes wrapped and re-installed.
2005 Yamaha FZ6
2009 Honda Ruckus
Old 04-20-2013, 01:20 AM   #86
ZZ-R Rider
Captain Fantastic
ZZ-R Rider's Avatar
Oddometer: 685
That is lookin' SWEET man!
Before you diagnose yourself with depression or low self esteem, first make sure that you are not, in fact, just surrounded by arseholes ...
ZZ-R Rider is offline   Reply With Quote
Old 04-20-2013, 04:06 AM   #87
kraven
Hegelian Scum
kraven's Avatar
Oddometer: 4,824
Yep. Looking good.
So there I was walking into a biker bar in Chattanooga with liberty spikes on my head and a drag queen beside me... - bcurvin
kraven is offline   Reply With Quote
Old 04-20-2013, 05:58 PM   #88
mikesova OP
mikesova's Avatar
Oddometer: 1,938
I bought and hooked up a battery today. The Z's came in:
They make me want to listen to this for some reason:
and the new pegs:
I just need those carbs and I think I'll have a running bike!
2005 Yamaha FZ6
2009 Honda Ruckus
mikesova screwed with this post 04-20-2013 at 06:07 PM
Old 04-20-2013, 09:35 PM   #89
JerryH
Oddometer: 5,069
Looking better all the time. I hope you don't decide to do an "earshave" on it, if the air filters are in those chrome pods. This is something commonly done to Vulcan 750s. Both air filter housings and the entire airbox are removed, and pod filters are attached directly to the carbs. This dramatically increases airflow, but the carbs can be rejetted to compensate for that. The problem is that it also drastically increases dirt flow as well. Dust goes right through the wire mesh filters, while nothing gets through the oiled foam stock air filters. You can shorten the engines lifespan by more than half by doing that. Most everybody does it anyway.
Old 04-20-2013, 10:11 PM   #90
k-moe
Oddometer: 2,788
The metal bands will look much cleaner than hose clamps, and will hold the wrap better. Don't forget to soak it in water before the final install or the wrap won't be tight enough.
k-moe is offline   Reply With Quote
Times are GMT -7.   It's 04:30 AM.
