Old 04-04-2013, 01:11 PM   #1
TheOtherBart OP
TheOtherBart's Avatar
Oddometer: 1,993
Pull down stairs without the frame?
I have a loft space in my garage that I would love to be able to access with some kind of pull-down ladder. I store fairly large things up there (partial sheets of plywood, etc) so a standard attic ladder with the rectangular frame wouldn't work.
What I'm picturing is some kind of pull-down ladder that only needs to mount to a perpendicular bulkhead (like a joist) at the top end. Does such a thing exist?
TheOtherBart is offline   Reply With Quote
Old 04-04-2013, 02:51 PM   #2
crawdad
Oddometer: 506
Guy I met awhile back was showing me his garage, walks over to a button on the wall and says "check this out". Pushes said button and a set of stairs drops out of the damn ceiling. He said he used a garage door opener for the mechanism but I'm sure you could use a rope/pulley too. I thought that was clever as hell, full stairway and a big hole in the ceiling to move big stuff up there.
crawdad is online now   Reply With Quote
Old 04-04-2013, 03:52 PM   #3
Hannda
Short, fat, bearded, slow
Hannda's Avatar
Oddometer: 28,281
The "frame" is only so you'll have something to sheetrock up to, and hold back blown insulation in the attic. The weight is carried by a header to which the top of the "stairs" are attached. Next time you're near a Home Depot that has the barns/sheds for sale outside that you can look at go into, look in the one that's tall enough to have a loft. It has the stairs, without frame, that you're talking about.
Or go here: http://www.atticladdersplus.com/?gcl...Fe8WMgod0n4A5Q
Hannda is offline   Reply With Quote
Old 04-04-2013, 05:19 PM   #4
TheOtherBart OP
Oddometer: 1,993
That Werner on there for small openings looks like the ticket. Looks like pretty much all the others have the lift assist springs that have to go back along the sides, and that's what I want to avoid. Now to see if my local Lowes has that Werner...
Old 04-05-2013, 03:27 PM   #5
syntec4
syntec4's Avatar
Oddometer: 1,421
I fit plenty of these here in the UK. I'm sure you can get something similar.
http://www.youngmangroup.com/product...ic-loft-ladder
My Smugmug
syntec4 is offline   Reply With Quote
Old 04-05-2013, 07:29 PM   #6
dfwscotty
dfwscotty's Avatar
Oddometer: 3,387
Was trying to remember where I saw it and I think it was on HGTV but you still have the framed pull down stairs but theres a company that makes a lift that fits in the ceiling and mounts to the roof rafters. I never looked into it but it can't lift much but enough to pull a big plastic tote up to the attic.
Search Google for "attic lift". There are several diy versions that might help you.
Traffick911
1999 BMW 1100GS
2012 Kawasaki Concours
dfwscotty is offline   Reply With Quote
Thread Tools
Times are GMT -7.   It's 06:35 PM.
