Old 04-08-2013, 07:49 AM   #1
Bigdog54 OP
MX X-Over Adventurer
Bigdog54's Avatar
Oddometer: 351
Cycle Pump vs Adventure Designs Micro Pump
I am scheduled to blast off on a week long ride in ONE WEEK.
http://www.advdesigns.com/mitipukitwit.html
http://www.bestrestproducts.com/p-30...o-w-gauge.aspx
Anyone have experience with either pump? Whats better? Whats smaller? ect ect ect.
Or is there a small hand pump that doesn't take 10 minutes of forearm busting pumping.
Thanks in advance
"Never spit at a competitor when you're wearing a full-face helmet"
Bigdog54 is offline   Reply With Quote
Old 04-08-2013, 08:21 AM   #2
LoneStrom
LoneStrom's Avatar
Oddometer: 339
The ADVdesigns pump looks a lot like the slime pump. I have been using a gutted slime pump for a few years now with no problems. Something like $10 at Walmart...
LoneStrom is offline   Reply With Quote
Old 04-08-2013, 08:44 AM   #3
RomaDakota
Illuminatus!
RomaDakota's Avatar
Oddometer: 1,441
The cycle pump is good, but too big and heavy for me; I ended up putting it in the auto.
I now carry a Stop-n-Go on bike trips.
КМЗ Dnepr MT11 // КМЗ M72 // ИЖ Planeta 5 // КМЗ MV750 // Урал М63 // BMW R1200GS 30th
RomaDakota is offline   Reply With Quote
Old 04-08-2013, 09:07 AM   #4
Twempie
Oddometer: 203
Cycle Pump
A Cycle Pump has lived in the luggage of my bike(s) for 6-7 years, never had a problem, check my tires weekly and can't remember the last time I used a gas station to air my tyres. I also carry a tyre repair kit from Sound Rider.
The only thing with the Cycle Pump is some valve stems don't like the filler chuck. No problem with Metzelers on my GS, but filling Dunlops on my old ST1300 needed the chuck to be held in place by hand. Not really a problem, I guess.
I tried the cheaper way of breaking the case off a Walmart pump. That didn't last very long.
Twempie is offline   Reply With Quote
Old 04-08-2013, 09:52 AM   #5
Juggernaut
Juggernaut's Avatar
Oddometer: 143
Anyone know how much pressure you can get out of a CO2 cartridge? I've thought of switching over since they are more compact, but have no idea how they work on motorcycle tires.
Juggernaut is offline   Reply With Quote
Old 04-08-2013, 09:57 AM   #6
ausfahrt
mach schnell
ausfahrt's Avatar
Oddometer: 1,782
Motopumps
I have hauled one around in my pannier for three years and used it exactly one time. It worked just fine but I can't really personally vouch for the longterm life of the unit.
That being said, Motopumps are sold by a fellow inmate on this vendor thread:
http://www.advrider.com/forums/showt...ight=motopumps
He also has his own website:
http://motopumps.com/
You can always count on the Americans to do the right thing, after they have tried everything else.
-Winston Churchill
ausfahrt screwed with this post 04-08-2013 at 10:24 AM
ausfahrt is offline   Reply With Quote
Old 04-08-2013, 10:11 AM   #7
El Buzadero
Armchair Anarchist
Oddometer: 31
For whatever it's worth, I've had the CyclePump onboard as a regular part of the standard loadout for a while. Love it. I keep some plugs, patches and tire tools in with it and am good to go. It's been there and been simple to use on a couple of incidents where I was glad it was so straightforward and didn't require a lot of fiddling around under the circumstances.
"The Lord Hates A Coward" -- Jimmy Malone
El Buzadero is offline   Reply With Quote
Old 04-08-2013, 10:26 AM   #8
JoshBMW
JoshBMW's Avatar
Oddometer: 351
The cycle pump is bigger but it works. It's the one I carry, will a smaller cheeper one work? most likley, do I want to find out 2 years down the road on the side of some trail with a flat..... No.
Josh
"Integrity, justice, courage, and action - without these, a person is of no consequence." Don Nelson my friend gone from us, 06/06/04.
JoshBMW is offline   Reply With Quote
Old 04-08-2013, 10:44 AM   #9
Canuman
Crusty & Unobliging
Canuman's Avatar
Oddometer: 4,634
The C02 cartridges don't give you much of a hit. They will pump high pressure, but at very low volume. A 10 gram cartridge, which is fairly common, holds a little over 5 liters of gas at standard temperature and pressure (that is to say, roughly 5 liters at atmospheric pressure at 68 F.) It's not that much.
I've found one cartridge is good for topping up a couple of times if you're a few pounds low. To reinflate a tire that's flat, I'd count on using three or four or more. Given that they cost a couple bucks each, it's hardly an economical way to roll.
The Rock 2013 RR
http://advrider.com/forums/showthread.php?t=915172
Dual Sport Luggage Racks: http://www.moto-racks.com
hONORARY mEMBER fIRST aMERICAN cHAPTER tEAM nONGA (pROVISIONAL wING)
Canuman screwed with this post 04-08-2013 at 05:18 PM
Canuman is offline   Reply With Quote
Old 04-08-2013, 10:48 AM   #10
lmychajluk
Oddometer: 1,925
It's not just the pressure, but the volume of air. A typical 16gr CO2 catridge will fill 1 bicycle tire (approx., depending on size and pressure). For a MC tire, 1 canister won't be enough air to fill a whole tire. Since the cartridges are a buck or two a pop, it's not cost effective to use them (IMO).
This thing is kind of cool, but I'm still leaning toward the Slime compressor myself - http://www.4wheelparts.com/Winches-W...n=AASPS01-3140
Edit - fixed link. & Canuman beat me to it....
-Lee
NE ADV Event Calendar (Request Additions here.)
2013 Triumph Tiger 800
2008 Suzuki SV650n (Sold... I miss that bike...)
lmychajluk is offline   Reply With Quote
Old 04-08-2013, 10:54 AM   #11
a1atcs
Oddometer: 83
This is what I carry
http://www.aerostich.com/tools/tire-...ompressor.html
I have used this little pump many times, it hasn't let me down yet. It is very compact, stows just about anywhere.
It will fill a rear tire to recommended pressure in less than 5 minutes.
09GSA
05 Road King Classic
IBA #49425
a1atcs is offline   Reply With Quote
Old 04-08-2013, 11:05 AM   #12
Happycamper
Have bikes, will travel
Happycamper's Avatar
Oddometer: 624
Thumb +1
Mine has also been very reliable.
Happycamper
2009 F800GS
2014 KTM 690 Enduro R
Happycamper is offline   Reply With Quote
Old 04-08-2013, 11:16 AM   #13
dwestly
Refuses to Grow Up!
Oddometer: 452
All I can say is I've had my CyclePump with me for years. It always works when (rarely) needed and I don't have to worry about it. I know it is bigger than some others on the market, but peace of mind is a wonderful thing...
Helmet laws merely delay Darwinism. I fully support an individual's right to be stupid...it eventually makes more room for the rest of us.
AMA, IBA, MSTA, BMWMOA, Ducatista, MSF RiderCoach, Track Coach, OEM Demo Team Manager
2012 R1200GS Rallye, 2013 Ducati Hypermotard SP, 2013 Honda NC700X DCT, 1990 Honda GB500 TT, 1976 Honda XL350 Enduro
dwestly is offline   Reply With Quote
Old 04-08-2013, 11:23 AM   #14
Juggernaut
Juggernaut's Avatar
Oddometer: 143
Thanks. I carry the Slime compressor with me, but damn it's big and weighs alot.
Old 04-08-2013, 11:24 AM   #15
U2U
Oddometer: 55
I have been using a Cyclepump for 4 years for all my bike and car needs. Used to leave it in a bag on my left tank guard. Went down on it twice in Alaska. It looks very beat up as a result but still performs like on day one. Now it resides in my left pannier for a little more protection although it gets wet on occasion. As noted above it can have issues with some valves. I would buy it again.
U2U is offline   Reply With Quote
Times are GMT -7.   It's 05:33 AM.
