Old 04-17-2013, 07:11 PM   #61
Snowbound
Oddometer: 877
+1 on #19 . Mine has been dropped , missing a tooth or two after it got dropped while running . Still pumps up my skid loader tire .
I use the CO2 to seat a tire and finish with the pump .
It has been used a lot in the three years that I have had it .
BMWMOA
ABC
Pikes Peak BMW Riders
2001 R 1150 GS 1978 R 100RS 1976 XT-500 1964 CL-72
1955 CJ-5 1975 F-250 Highboy
Snowbound is offline   Reply With Quote
Old 04-20-2013, 05:26 PM   #62
RomaDakota
Illuminatus!
RomaDakota's Avatar
Oddometer: 1,532
Here is a comparison between the pumps I have.
The Stop-n-go weighs in at just under a pound. The naked pump about 1.5 pounds and the Cyclepump around 2 pounds. I have used them all and all worked fine. The chuck on the Cyclepump is a bit fidgety. Due to size and weight, the Stop-n-go travels with me offroad and on trips (the gauge is nice also). The naked, stays in a sidecar bike and the Cyclepump stays in the truck.
КМЗ Dnepr MT11 // КМЗ M72 // ИЖ Planeta 5 // КМЗ MV750 // Урал М63 // BMW R1200GS 30th
RomaDakota is offline   Reply With Quote
Old 04-20-2013, 09:02 PM   #63
TUCKERS
the famous james
TUCKERS's Avatar
Oddometer: 12,190
Nice comparison, thanks Man.
The Stop and Go looka appealing
James and Colleen Tucker.
Aut viam inveniam aut faciam
DMV work/insurance/registration/titles/address use/room rental/motorbike&vehicle buying/travelers help/problems solved
TUCKERS is offline   Reply With Quote
Old 06-14-2013, 09:42 AM   #64
BigToad
The Bone Destroyer
BigToad's Avatar
Oddometer: 196
Originally Posted by TUCKERS View Post
I have a stripped version I concocted in my car, but on the bike I thought it may get full of grit and let me down.
Just wrap the pump in a rag, when you use it just lay the pump on the rag, did that for many years with no problems
R1200 GSA
XR650R dualsport/Rally Trainer
We should come home from adventures, and perils, and discoveries every day with new experience and character
BigToad is offline   Reply With Quote
Old 06-14-2013, 10:08 AM   #65
HaChayalBoded
Brooklyn Bored
HaChayalBoded's Avatar
Oddometer: 7,928
Add a 6" mini bungee to the pouch. Then hang the pump off the bike. This way you do not have to hold it up by one of the cables (cause it gets too hot to hold onto the pump directly) and you do not have to put it down on the ground where it will grind and drag around from the vibration.
HaChayalBoded is offline   Reply With Quote
Old 06-14-2013, 10:29 AM   #66
perterra
perterra's Avatar
Oddometer: 7,400
Originally Posted by Juggernaut View Post
Anyone know how much pressure you can get out of a CO2 cartridge? I've thought of switching over since they are more compact, but have no idea how they work on motorcycle tires.
This may have been answered already, on my goldwing the 12 grm cartridge would give me 5 psi, on the KLR one will bump the front to about 10 to 12 lbs and a rear to about 8 psi.
If you get a CO2 get one that doesnt have to be threaded and buy the 12 grm pellet gun cartridges, they are about $15 for a box of 25 or $20 for a box of 40
My Father was my maker. Poverty was my maker. Distrust was my maker. I have met them all my life.
IBA 22425
perterra is offline   Reply With Quote
Old 09-30-2013, 01:10 PM   #67
Quarterbore
Oddometer: 29
Glad to find this - I was looking for something small and I looked at the specs and that Stop and Go mini air compressor is rated at 6AMPs (12v) so she will be fine with the 7.5amp fuse on the standard battery tender hookup to supply power. $37 certainly sounds better then $100 but both sound better then a hand pump
http://www.stopngo.com/mini-air-comp...ers-atvs-only/
The Cycle pump is rated at 10 - 12 AMP at full load which might mean I would need to rewire my battery tenderer hookup assuming the 7.5Amp fuse they use is based on the wire then use?
Enjoying the ride on a Kawasaki Vulcan 800 for now!
Quarterbore is offline   Reply With Quote
Old 09-30-2013, 01:51 PM   #68
X1Glider
X1Glider's Avatar
Oddometer: 615
Why mess around with an electric pump? All bikes come with an air pump as standard. It's called your engine.
The OP has a boxer. Easiest solution is Engine-Air's spark plug hose adapter. I've been using a similar one for years for the 2 boxers and dozen american v-twins I've had as well as a handful of dirt bikes.These types of bikes make it easy to get to the spark plug so it makes good sense.
On my 2 cylinder FI bikes, I pulled the fuel pump fuse to make sure there were no gas fumes going into the tire and removed the other plug to make it easier work for the starter motor. The carb bikes, I just shut off the petcock and take out the other plug as well. Gave it a few cranks to get any residual fumes out before installing it into the plug hole. Then, the tire airs up quick and can even seat a bead...at least it can on a big twin. The smaller cylinders in a 4 might be a different story, I don't know about that.
If you don't mind gas fumes in your tires, you can leave in the other plug and let combustion happen to make the motor turn over instead of just using the starter.
I don't use this on my Ninja 1000 though. I'd have to remove the side plastics, lift the tank, undo the upper and lower halves of the airbox before being able to access a plug.
Bob Krzeszkiewicz - 2013 Christini 450E - 2011 Kawasaki Ninja 1000 - 2000 Harley Davidson FXDX - 1999 Buell X1
X1Glider is offline   Reply With Quote
Old 10-01-2013, 10:10 AM   #69
ERD
Custom Rider
Oddometer: 386
I'm using the Stop N Go kit, mostly because I am a dealer selling it. The Slim compressor works well too as the engine cylinder pump. I've had to use the pump a few times a all of them worked well but are slooooow to fill up. The only thing I do not like is the engine cylinder air pump. Not a fan of removing the spark plug on a hot engine so I can fill up the tire.
I have a real air compressor at home and at the shop for regular air top off so I only use the portable compressor on the road.
For the money, I would pickup a Slim compressor and sticky sting tire repair kit for a total of $20 from Walmart and call it a day.
ERD is offline   Reply With Quote
Old 10-01-2013, 12:15 PM   #70
gmiguy
You rode a what to where?
Oddometer: 1,336
I thought the Engine-Air pump design uses cylinder pressure to pump atmospheric air into the tire, meaning it won't pass any fuel to the tire.
gmiguy is offline   Reply With Quote
Old 11-14-2013, 01:02 PM   #71
se123
Sean
Oddometer: 14
the BikeGear looks solid
Originally Posted by farcall View Post
I've owned both of these http://www.webbikeworld.com/r3/motor...irman-sparrow/ and just recently bought this one from Bikergear in South Africa.
Slime and Airman worked OK, if not a bit slow, and are very lightweight. Whilst they fill the tyres with air OK, they don't fill me with confidence ... I remember reading somewhere they have some plastic internal bits (I'm not saying they do... just that I read it) which wears out over time.
Whilst I haven't tried it yet, judging by the weight and construction of it, the Bikergear pump seems to be everything their web blurb says.
I spend too much time hundreds of kms from any town and out of phone range to be second guessing whether my pump will do the job when needed most. That's why I've shelved the other two.
How much did that run, I didn't see a price
se123 is offline   Reply With Quote
Old 11-14-2013, 05:03 PM   #72
farcall
Bike-a-holic
farcall's Avatar
Oddometer: 1,903
788ZAR incl post which approx equals $USD77.
Ask them to pack it in heaps bubble wrap. The plastic feet on mine broke in transit. After 5 emails to them and not one reply I gave up.
Product 10/10. After sales customer service 0/10.
01 Africa Twin RD07A (x2)
05 HP2
11 K1600GTL
farcall is offline   Reply With Quote
Times are GMT -7.   It's 07:16 PM.
